Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer
I have two issues with my washer, one is that I get the SUD error message even when very little soap is added and second the estimated timer shows one minuet when it runs for another 30 minuets?
  • 11 more comments
  • Anonymous Nov 08, 2007
    shows sud, even though i changed my soap to he. runs forever even when it says 1 minute left and now it's showing an f2 error code. it won't get through the wash cycle without having to be reset multiple times, and i have a load of laundry that's been stuck in the washer for a day since it won't unlock the door either.
  • Telegadget Dec 01, 2007
    Just wanted to tell everyone that I had the exact same problem. The He4T washer got worse over the course of a few weeks until the F2 and SUD error codes showed up during every load. The cycle would run forever!.
    I removed the front panel, unscrewed the white drain blug (lots of water came out) and found not one but three color catchers!!! No more color catchers for us!
    We have run 4 loads since and every load is now finishing quicker then the initial timer setting!!! Yea!!!!
  • merdealors Feb 04, 2008
    I have the SUD signal on. How do I fix it?
  • merdealors Mar 05, 2008
    What kind of screw driver did you use to open the front bottom?
  • quagga Apr 03, 2008
    No problem anymore. I pulled the white plug and found two small socks, lint and general disgust. I'd recommend using a wet/dry vac for the initial draining of water if you were not able to run through the cycle before fixing the problem. You do not have to open the plug all the way. This way you can **** the water directly into the vac. I filled my large vac 1 1/2 times, but I had a full basin. After the water is drained pull the filter. As with any electrical appliance and water, unplug it before working on it. As a precaution, I would also check the drain hose at the back of the machine. I had initially checked this and found it filled with gunk (at the low point) from the slow water flow caused by the blockage.
    Oh, the sound of a smoothly working washing machine. By the way, this might be a good to check out every six months or so.
    Thanks for the initial help.
  • Anonymous Apr 04, 2008
    This site is awesome. Called sears after getting F02 message. they said it was my detergent and they would not come out and fix it (great warranty). Found your site opened the front, pulled the plug took out two socks a plastic coin and other assorted items. Now its running fine. Thank you!!
  • Mbrott May 11, 2008
    Had the same problem and the fix on the website worked like a charm...Found 2 socks and a bunch of lint.
    Mbrott
  • MillySF May 25, 2008
    We have the same problem (F2 error) and followed the instructions below. Worked great, until we opened the filter and found a pair of tights stuck in there. They won't come out - the end of them seems to be stuck on something below the drum.
    Any ideas??
    thanks!
  • spartin Jun 07, 2008
    Wow, I had the same problem & followed the instructions (KCwasher) below (KCwasher giv, solution #3). Filter had 3 toddler socks, toothpick, copper & gunk. Will add that we used a large grocery bag (Target) with a hole in the bottom to funnel the water to our bucket. Ours is on a pedestal so the filter was above the bucket. At least a gallon and a half of water came out. Thanks!
  • keub Jul 17, 2008
    THANK YOU! I'm so happy I fixed the washer myself - now, if I can just get my husband to do the laundry...
  • Anonymous Mar 19, 2009
    I'M GETTING A F2 CODE AND SUD MESSAGE WHEN THE WASH LIGHT IS ON
  • Thomas Huff May 11, 2010
    The posted solution does work! I found two small kids socks in the filter, so it is likely that cleaning it out will solve the F 02 error.
    I disconnected the filter assembly from the three red rubber support feet so that I could drain the tub into a bucket. If you do not disconnect it, the remaining water will fill the various chassis trays and leak out all over the place.
  • Ginger Sanders Oct 03, 2012
    We also had the same error messages and my husband spent the afternoon tearing into the machine per your instructions and found the same nasty mass of color blockers. I picked up the box today, prepared to call the 800 number and give them a piece of my mind. Fortunately I stopped and really looked at the box before calling. Right there in plain sight were instructions for a front loading washer. You are supposed to put the sheet in a mesh laundry bag and put in the back of the drum before loading. I guess we are all guilty of not reading the directions.
A BEST AND DETAILED SOLUTION TO CODE F2 AND SUD ERROR MESSAGE.
If you are getting an F2 error message or a SUD error message, and are observing some water in the tub that is not draining at end of cycle, and your washi cycle is taking a lot longer that normal to complete,then here is what to do.
This solution is easy, and will take no more that 15 minutes, from start to finish, and most of that time is in the --prep-- (getting tools, towels, etc.). This WILL save you a expensive service call.
There are 3 small 9/32 hex head screws that hold the front panel on. The front panel I'm speaking of is --below-- the washer window.
These screws can be found::
a. if you have the optional washer storage drawer unit,, they can be found by opening the drawer, and observing the 3 screws (left, middle, and right side, that hold the front panel on.
or
b. if you DONT have the optional drawer assembly, then they are found on the front, bottom, of the washer, again holding the front panel on the washer.
1. unscrew the 3 hex head screws (9/32 socket or nut driver size)
2. lower/remove the front panel, and set it asisde on some towels, so as not to scratch the front panel.
3. get something now to soak up at least a gallon of water that WILL empty onto the floor.
4. observe large WHITE drain cap, at front center of washer.
5. unscew white drain cap --WARNING-- lots of water WILL drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
6. clean out the front and bottom of the filter trap. I'm sure lint, and gosh knows what else have cloged some of the holes
7. wipe out the inside of the housing for the filter trap (observe lots of -gunk- there too).
8 put back in filter trap, tighten white cap, and put front panel on washer with same 9/32 screws you took off earlier.
Now I ran a test --express wash-- cycle, just to be sure all was OK,, and it was.
Now go get your wife and have her complete that laundry that was waiting for the washer to get repaired. OK sorry,, maybe you should just do the laundry your self, and get some points later.
Hope this step by step was helpful... Have a great day.
Washer Guy in Kansas City, MHE
Posted on May 05, 2008
  • DarleneG Jan 01, 2011
    THANK YOU! I have 4 children and I wash 24/ 7 or so it seems. I had a washer repair person come and change the water pump last year $284.00 and the same thing happened again. I tried your suggestion and it worked I am now thinking I was "taken for a ride" last year. Happy New Year!
  • Laura Zazzarino
    Laura Zazzarino Mar 09, 2015
    This was wonderfully helpful. Thank you. I see that someone has posted below on removing rubber tabs and removing the filter housing to collect the water. I didn't do that. however, I did wrap a large plastic garbage bag round the filter before taking out the plug. That caught most of the water. The rest of it went in the drawer, where i had put a couple of towels, so very little mess.
WE WOULD LIKE TO THANK YOU VERY MUCH FOR YOUR ADVISE OUR WASHER HAD THE SUD CODE POPPING UP AND WOULD NOT COMPLETE THE RINSE CYCLE. WE TOOK OFF THE 3 SCREWS ON THE BOTTOM COVER REMOVED THE FILTER AND THERE WAS LENT AND LITTLE BIT OF EVERYTHING ELSE. WORKS LIKE A CHAMP. THANK YOU ONCE AGAIN.
Posted on May 07, 2008
There are some rubber tabs that hold the filter housing in place if you unlatch these you can have a bucket ready to collect all this water - especially if your washer is on a pedalstool. No more towels to wash after cleaning the filter. Make sure you reattatch the rubber tabs.
Posted on Sep 07, 2009
  • Cem Basu
    Cem Basu Nov 16, 2013
    Thank you very much for this info - helped me tremendously. Once I got the filter out, there were baby socks (we bought our machine before our first child, now over 9 yrs) and those pesky color catchers. We now know never to put thing tiny in there :-)
    New Friend:
If you think you fixed it and the codes come on again...look further behind the filter. Mine worked good for a couple of days and then stopped working again. I looked further and found an entire sock that was not easy to get out! I think I will check it again after a couple loads and see what else comes out!
Posted on Feb 23, 2013
Just completed this repair on our machine and when I cleaned the filter housing like so many others found 3 - 1 washer/dryer sheets, coins, dollar bill etc. I took the pump out completely out to be thorough in cleaning, out of curiousity I removed the black rubber boot attaching the bottom of the drum to the pump housing and sure enough there was even more trapped up in there, it seems as if there is a bar that goes across the drain hole for stuff to get caught up on. Hopefully this extra cleaning step assures me not having to return to clean out the filter any time soon. (to remove the boot there are spring clamps on both sides that need to be removed) I used a pair on vice grip pliers to compress the spring loaded clamps to remove them.
Posted on Jan 31, 2011
Man let me tell ya!! The advise to take the 3 screws off and clean out the lint trap is AWESOME!! Worked like a charm. One thing is for sure, there is alot of water that comes out of there so make sure you have PLENTY of towels. Beware though, the cover plate is a pain to put back on as well as the 3 screws. I got it after a few tries, but everything worked out perfectly! Thanks a BUNCH!!!
Posted on Nov 01, 2010
I had the f02 code and did the steps to clean and clear the filter and hose, but I still can't get it to work and other solutions you can suggest.
Posted on Apr 13, 2010
  • Bubba Bravo Jan 25, 2013
    Me too! We also accessed the Drain Plug and cleaned out minor lint and a candy wrapper. Thought this would fix the F02 and Suds Errors but unfortunately after putting the machine back the F02 error continued. Someone PLEASE help??
I don't have a solution but I followed the advise here because I was getting the Suds and F2 error code to the point that the machine would not get past it. anymore.The advise worked like a charm!!!! Thank You! The culprit was baby socks and lint. You saved me a trip to the laundermat and a repair bill. By the way, make sure you have lots of towels on hand because a lot of stagnent smelly water comes out when you remove the white plug.
Posted on Mar 05, 2008
Had a problem with my HE3 washer. Have tried for over an hour to get this fixed. Checked the drain and filter and found a color catcher in there. Our warranty just ran out so you saved not only our week-end but a ton of money. Thank you. Hope we can help someone out someday with a fix.
Posted on Nov 24, 2007
THANK YOU for the fix to this problem. saved us a ton of money. We used a shop vac to suck up the water as we undid the drain cap and that worked very well, esp since we had a lot of water stuck with the load still. and for the dumb ppl like me out there, the drain is the white circle thing right in the middle. you unscrew the cap and then pull the filter straight out.
Posted on Nov 08, 2007
Thank you for your suggestion! FYI be sure to have a good amount of towels handy to absorb the water that will empty when you remove the cap off of the drain. I found a small sock, some pen caps, and a lot of lint. Thank you so much! As a single mother of three, a service call can mean the difference between eating cheese sandwiches all week and eating right.
Posted on Sep 29, 2007
    New Friend:
A small quarter to half turn of the white drain cap and a wet vac pointed to the bottom of the cap and there is no water mess. Took about five minutes to suck up the trickle out of the cap. Awesome and super easy solution! Thanks.
Posted on May 28, 2013
    New Friend:
Thank you for the useful info. I got a he4t that suddenly showed the Sud error. I followed your instruction, got lots of towel ready and opened the drain cap. Although I didn't see anything blocking the filter, I cleaned it anyways. After putting everything back, the thing is working again. Thanks again!
Posted on Dec 21, 2012
BE CAREFUL WHEN REINSTALLING THE LARGE WHITE DRAIN CAP. THE OUTER PORTION OF THE CAP IS DESIGNED TO SPIN INDEPENDENTLY OF THE INNER FILTER TRAP. IT IS DESIGNED THIS WAY TO KEEP THE FILTER TRAP AT THE BOTTOM OF THE RESERVOIR. IF THE FILTER TRAP IS ORIENTED INCORRECTLY OR CROSS THREAD THE WASHER WILL STILL SHOW THE F2 CODE.
Posted on Oct 19, 2010
My kenmore elite washer he4t shows 06f, what does that mean?
Posted on Sep 09, 2010
Wow, this was so easy. Thank you for the solution. The washer is working like new again. I was afraid I was going to get stuck with replacing some control board that would end up costing me a fortune. Plus now I have the satisfaction of doing it myself. It is always a great feeling when you can fix a problem like this on your own.
My machine was taking forever to complete a load(would start spinning, then slow down, then try again, over and over) and I got an occasional SUD code.Thanks washerguy for the detailed solution. Guess what I found in my filter? Three Purex 3-in-1 laundry sheets(along with a few other things). I wonder how many other service calls have been made because of these making their way out of the drum? I have emailed Purex to see what they have to say.
Posted on Mar 18, 2010
I found 2 kids socks, about a 2" ball of gunk in the filter and a drill bit that wedged the drain ball closed. Thanks a million KCwasher giy, you saved me a lot of money........
Posted on Mar 15, 2010
The tip worked like a charm to fix washer.
A helpful tip, instead of using many dirty towels and worrying about the clean up afterwards, borrow a wet vac and have it running as soon as you remove the lid on the filter. The vac fits perfect inside the filter and not only reduces the 4+ gallon of stagnant water on the floor but also helps clean the remainer of the water tubing out.
Thanks again for helping with this issue washer guy!
Posted on May 17, 2009
  • 3 Answers
I, being the appliance repair guru of the house, did all of this about a week ago. I had also noticed a rattle sound in the pump area. It's starting to make the same noises again, and is not spinning out. I've checked the little storage area and it's clear. Could this be the pump? I've also checked the drain tubes that go up and out the back, and they're clear.
Anyone else come across this? A new pump is a little over $100, so not that bad, and the work doesn't look too hard. BUt I'd rather not deal with that if I don't have to.
Thanks!
Posted on Jun 06, 2008
Wow this is great! I found coins, 1 child sock, 1 infant sock, a stick on nail of my daughters, a few tags and even a plastic tie. Some plastic from who knows where and sand!
Thanks so much for saving me a tech call!
Posted on May 25, 2008
Wow!! I thank you all!! I was just about to freakin snap and take a crowbar to my kenmore!! Your advice seems to have fixed everything! I bow down to you all!
Posted on May 06, 2008
Best Solution - Worked
This one worked for me. We had Baby Wash cloth in drain blug. Now we do not have SUD message and it runs for approx. 1 min when it says 1 min remaining.
Thanks a lot.
Regards,
Nirav
Posted on Mar 06, 2008
F2 and SUDS problem gone after trying the drain clean-out
Thanks for the tip!!
Posted on Jun 20, 2007
I just had the same problems. My washer is 16 months old - but used daily! I took off the bottom, front panel of the washer (there are 3 little screws on the front bottom). I opened the drain and found it to be clogged with *a lot* of Shout Color Catchers (and a small amount of fuzz). I have been happily doing laundry since without the SUDS and F2 error!
Posted on Feb 13, 2007
This saved me a TON of money...I found a sock and two dimes!! JUST MAKE SURE YOU HAVE LOTS OF TOWELS...Thanks a bunch
Posted on Dec 01, 2007
SOURCE:
My Kenmore Elite front loader keeps on showing the same problems
Cut down on your soap i only use very little soap and it works great.No more SUD code
Jul 02, 2014 | Kenmore Elite 45986 Front Load Washer
Sud flashing on kenmore elite he5t washer
Are you getting the little melody chimes! Mozart? I read that about the Kenmore's. Your adding either too much soap or the wrong kind. Read owners manual for proper amounts of soap! More does Not mean more clean!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Jan 16, 2014 | Washing Machines
Error code "SUD"
SUD error means there is to much soap being added, the washer will shut down, if it cents to much soap
Jan 12, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Kenomore Elite HE4t Washer. I am getting an F02 error message. I've tried to rerun washer & get SUDS on and off. Fo2 message appears again and cycle shuts down. Door will not unlock. Any...
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 14, 2009 | Kenmore Elite HE4 Electric Dryer
Sud/F35
if your using more than 2 tbl spoons of HE detergent, you WILL have the same problem with your new washer." sud "stands for TOO MUCH SOAP
Jul 24, 2009 | Kenmore Elite 45986 Front Load Washer
F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
"F02" and/or "Sud" error are directly related to a common problem in this case. You have something clogging your drain line and/or drain pump. The error will not go away until you clear the problem. The following links explain how:
http://www.fixya.com/support/r629564-suds_error_whirlpool_kenmore_front
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
In some cases, the drain pump may require replacment. If something has been lodged in the pump reservoir for any period of time, sometimes the pump impeller can become damaged to the point where it does not pump water. Replacment pumps can be found at searspartsdirect.com or repairclinic.com. Just type in your model number inthe search menu. I hope this helps you resolve your problem and that you do not require parts. Let me know if you require additional assistance.
Jul 18, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
I believe the SUDS error is in direct relationship to the clogged drain problem. Yes...the error can be generated by the use of too much soap. But, it is also caused by too much air in the drain pump. This is caused by a clog somewhere. A clog in the drain area of the gasket is not going to cause this. The problem is your drain line and/or drain pump. If you click on the link below, I have step-by-step instructions on how to access the drain pump and clean it out.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
I have experienced on one occasion where the drain hose coming from the bottom of the wash tub was clogged. This, ironically, was from someone washing a rug that had a ton of sand and dirt in it. I had to remove this hose from the bottom of the wash tub and clean it out. I mention this just in case cleaning the drain pump is not enough.
I hope you find this information helpful. Reply back if you need further assistance.
May 14, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
WE had a person with the same problem with her HE4 front loaded washer. What we discovered was when we opened up the soap resivour was that soap built up around the float valves causing them to stick.
A technician I knew put vinegar down the soap dispensor and ran the cycle, with the washer empty. He put it on in the hot water mode and ran it for four or five complete cycles like washing clothes.
It worked for him. Try it like it did for him to see if it helps. If not, you will need to contact a service technician to see if the SUD error code means something else.
Sometimes the timer boards get a bit of moisture on them and cause a corrosion headache. I have yet to see anyone figure out a way to dry them off, and when condensation builds up, it usually means there is a problem causing the condensation to get that far up. On some versions a foam seal gets worn out from time, often needs to be replaced to prevent moisture built up.
Another thing that sometimes does it is the back of the machine, will be too close to the wall or have debris back behind there causing it not to be able to breath.
May 14, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
7,882 people viewed this question
Sal De
fordexpert
yobo007
yobo007
