WE UNPLUGGED OUR TOSHIBA MV19H01 TO HOOK UP ANOTHER TV, WE LATER RECONNECTED THE TOSHIBA BY TURNING THE TELEVISION ON ITS SIDE OR COULD HAVE BEEN FACE TO SEE THE CONNECTION SITES BETTER AND NOW THE COLOR IS CONSIDERABLY OFF AND THE COLORS ARE EXAGERRATED, PARTICULARLY THE BLUES AND GREENS. ANY SUGGESTIONS?
  • 130 Answers
SOURCE: Toshiba 55hx70
Macrovision causes a blue band at the bottom. Its a copyguard Are you using the RCA cables from the unit to the tv or the coax? are you trying to feed the dvd out into the vcr input? Copyguard does some strange things, its a shame they have to put in all this stuff that can cause other problems to prevent people from stealing.
Posted on Apr 18, 2006
likha
  • 790 Answers
SOURCE: Loss of color - all green
yes! the problem is in the CRT board the RGB colors! you have lost of blue and red! thats why your unit is green! and only green is worked the blue and red is not work! maybe you have lost contact of them! resolder all CRT board to comeback the normal picture!
Posted on Sep 28, 2007
ChadL777
  • 69 Answers
SOURCE: Color of people's faces in movies played via DVD is now blue since connected to LCD TV
The reason the picture is blue on the DVD is because you have poor video cables running the feed, probably RCA yellow cable im guessing. Get some nice component cables for the DVD feed and it will fix you right up.
Posted on Dec 26, 2007
SOURCE: Toshiba 24"TV VCR/DVD Combo
Hello firstly switch the tv off at the wall socket and leave overnight, If the fauld still there in the morning then the degauss thermistor inside the tv has failed and requires replacement.
Posted on Jan 16, 2008
willwildy1
  • 5 Answers
SOURCE: Resetting TV Color Settings.
Generally 50 is the middle setting. try setting the color bars all to 50 and see what happens.
Bill
Posted on Jan 21, 2008
Menu keeps popping up ever few seconds, wont go away.
Check and replace the main system control memory IC. It is faulty.
Feb 11, 2013 | Toshiba 35A44 35" TV
Hitachi 51F520 keeps turning off and on
hi, the tv is not set on sleep timer is it. the other fault could be a dry joint or a swollen capacitor a loose board with the power off you will need to do a visual check make sure you've got a good light hope it helps
regards
shaun
Dec 06, 2011 | Hitachi 51F510 51" Rear Projection...
Re:toshiba 55h70 tv i unplugged the tv to paint. when i plugged back in a wk later i have no picture or sound. nothing. can't access the menu - completely dark screen. the red lite "on" button...
I would check the fuse on the main board. Check the Capacitors on the Power Supply board. Seeing that you unplugged it and replugged it in you might have bad caps that were weak to begin with. Please learn how to safely work on a TV before attempting . Even when a tv is unplugged it has enough power to kill you. Discharge all Capacitors first. make sure its unplugged of course.
Jan 06, 2011 | Toshiba 55H70 55" Rear Projection...
Toshiba shuts dowm
pls .check your tv power cabel pin and plugg bitwin sparked or luss canaction [pls unplugged cabel pin and see tv. power cabel pin on top side black spot.]
pls try power cabel properly canact if loose replace with new.
NOTE:most of tv poblum is making power cabel loose. so canacting tv power cabel or power bord check with electrician
Oct 08, 2009 | Toshiba 42H81 42" Rear Projection...
Phillips rear projection tv (60P8341) won't power up
make sure its tv you are plugging in. still no power check main fuse in back panel ,
Mar 10, 2009 | Toshiba 57H81 57" Rear Projection...
Tuning TV onto AV chanel
unplugged every cable and then reconnected them - Bob's your Uncle - it worked!!!!
Apr 01, 2008 | Toshiba Televison & Video
Plugged in, worked, turn on later, did not work
First thing i would do would be to check convergance amp ics
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Toshiba 55H70 55" Rear Projection...
Lite in the front of the TV when you turn on keeps blinking and no picture.
Q510, Ta1316 is your sync processor and probably the problem you're having here. It's a common one for this unit and you could pull the board and check the solder connections it has with the foil - - but you may need to replace it...
Nov 05, 2007 | Toshiba 50H81 50" Rear Projection...
No Picture, Menu screens or anything video - Sound still working!
Yes... Look for F851 and replace it with a slow blow 3.15A fuse per Toshiba. Bill
Jul 01, 2007 | Toshiba 43AX60 43" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
