Question about Dell Dimension 2400 PC Desktop
NO LED LIGHTS COME ON WHEN THE POWER BUTTON IS PRESSED
The computer makes no sound and does not power up. The outlet and
power cord have been checked and the CMOS battery has been replaced.
Could it be the power switch or the power unit? Please reply. Thank you.
  • Dell Master
  • 4,338 Answers
If there aren't any lights and the fans do not spin up,it is definetly the power supply. Unplug the Ac from the back of the computer.
Then take the power connector from the power supply off of the motherboard. wait 30 secs. then plug it back into the motherboard. Plug the AC back into the PC and power it up. If this does not work then it is the PSU.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 28, 2008
    Sergeant:
    Champion:
  • 251 Answers
Yes it possibly is ur power supply unit u can usaly pick one up cheap at a local used computer shop
  • 282 Answers
Make sure that theres power on the motherboard by checking on the flea light on the board,if its off,it could be the power supply has gone bad or the mother board itself
When i turn the computer on theres no picture no sound and pretty sure its not powering anything on
please check if you can see any light or LED display when you press the power button.
If none. Check if the power cable is tight on the back of the computer and check if it's plugged into a power outlet.
You can also try plugging it into a different power outlet just to make sure it's not the Power outlet that has a problem.
You can also try to switch the power cables.
Hope this works, if it doesn't you will have to tear down the parts of the computer to check where the fault is coming from.
Jun 01, 2011 | HP Hewlett Packard Pavilion Slimline...
Hp officejet 6500 all lights are flashing and mechine says turn off and on . Please can someone Help??
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
Unplug the power cord from the wall outlet.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
  1. Disconnect the power cord from the product.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while reconnecting the power cord.
  4. When the product turns on, release both buttons.
  5. Try printing again.
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
My printer will not come on at all. i have the adapter in to the wall jack but nothing happens. i have checked to ensure the wall jack works.
Solution one: Make sure the electrical outlet works
Unplug the power cord from the electrical outlet.
Plug another appliance into the electrical outlet to make sure the outlet works.
If the electrical outlet does not work , plug the product into another outlet that does work.
If the electrical outlet works, but the product still does not turn on , continue to the next step.
Solution two: Make sure the power supply is compatible with the HP product
The term power supply refers to both the power module and the power cord.
NOTE: To make sure that your product and power supply are compatible, HP suggests you use the original power supply shipped with your product.
Example of a power module Example of a power cord
NOTE: The power module might have a permanently attached power cord, or the power cord might detach from the power module.
Make sure the voltage and amperage specifications printed on the power supply match the voltage and amperage specifications printed on the HP product.
Voltage and amperage specifications printed on the power supply Voltage and amperage requirements printed on the HP product
If the voltage and amperage specifications between the product and the power supply are compatible, make sure the connector on the power cord is the same shape and color as the connector on the HP product.
WARNING: Do not force a power cord into an HP product that is incompatible with the HP product (different shape or size).
If the power cord is not compatible with the product, replace the power cord with a compatible cord. To buy a compatible cord, right-click the following link, How to Buy HP , and then click Open in New Window .
If the power cord is compatible with the product, but the products still does not turn on, continue to the next step.
Solution three: Reset the power module and test the power
Step one: Reset the power module
The power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
Unplug the power supply from the rear of the product.
Unplug the power cord from the electrical outlet, power strip, or surge protector.
If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
Wait 15 seconds.
Reconnect the power cord to the power module.
Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
Check to see if the power module has an LED.
If the power module does not have an LED, continue to the next step.
If the power module has an LED, check to see if the LED lights up.
If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
If the LED lights up, continue to the next step.
Step two: Test the power on the All-in-One
Follow these steps to test the power on the product.
Reconnect the power supply to the rear of the product.
Press and quickly release the Power button to start a Power On/Off cycle. Do not hold the button down.
Figure 1: Press and quickly release the Power button
If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button again.
If these steps resolved the issue , there is no need to continue troubleshooting.
If the issue persists , see the next step.
Solution four: Test the power with a compatible power cord from a different product
If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
If the product does not turn on with the alternate power cord, continue to the next step.
Solution five: Service the HP product
If you have completed all the preceding steps and are still experiencing a problem, service the product.
Mar 26, 2011 | HP PSC 750 All-In-One InkJet Printer
I press the power button but the machine does nothing. It's pluged in and the lcd lights up
  1. Unplug the power cord from the electrical outlet.
  2. Plug another appliance into the electrical outlet to make sure the outlet works.
    • If the electrical outlet does not work , plug the product into another outlet that does work.
    • If the electrical outlet works, but the product still does not turn on , continue to the next step.
    • The power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
      1. Unplug the power supply from the rear of the product.
      2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
      3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
      4. Wait 15 seconds.
      5. Reconnect the power cord to the power module.
      6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
      7. Check to see if the power module has an LED.
        • If the power module does not have an LED, continue to the next step.
        • If the power module has an LED, check to see if the LED lights up.
          • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
          • If the LED lights up, continue to the next step.
      Step two: Test the power on the All-in-One Follow these steps to test the power on the product.
      1. Reconnect the power supply to the rear of the product.
      2. Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down. Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
      • If these steps resolved the issue , there is no need to continue troubleshooting.
      • If the issue persists , see the next step.
      Solution four: Test the power with a compatible power cord from a different product If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
      • If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
      • If the product does not turn on with the alternate power cord, continue to the next step.
      Solution five: Service the HP product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jan 17, 2011 | HP PSC 2355 All-In-One InkJet Printer
Can not get hp 1210 to start -power is getting to machine but it will not start..
  1. Make sure the voltage and amperage specifications printed on the power supply match the voltage and amperage specifications printed on the HP product. Voltage and amperage specifications printed on the power supply Voltage and amperage requirements printed on the HP product c01962881.gif c01962212.gif In this example, the voltage (+32 V) and the amperage (2000 mA) from the power supply is compatible with the voltage and amperage specified on the HP product.
  2. If the voltage and amperage specifications between the product and the power supply are compatible, make sure the connector on the power cord is the same shape and color as the connector on the HP product. WARNING: Do not force a power cord into an HP product that is incompatible with the HP product (different shape or size).
    • If the power cord is not compatible with the product, replace the power cord with a compatible cord. To buy a compatible cord, right-click the following link, How to Buy HP , and then click Open in New Window .
    • If the power cord is compatible with the product, but the products still does not turn on, continue to the next step.
Solution three: Reset the power module and test the power Step one: Reset the power module The power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
  4. Wait 15 seconds.
Solution five: Service the HP productIf you have completed all the steps listed above and are still experiencing a problem, service t
Dec 01, 2010 | HP PSC 1210 All-In-One InkJet Printer
If I open and close the printer it starts as if it is doing printer prepeartation, but nothing comes on. The screen will not turn on.
  • SOLUTION 1 If the HP All-in-One is turned off, press the On button to turn the unit on.
  • Unplug the power cord from the back of the HP All-in-One.
  • Wait 15 seconds.
  • Plug the power cord back into the HP All-in-One.
  • Turn on the HP All-in-One by pressing the On button.SOLUTION 2: Reset the power module and test the power Step one: Reset the power moduleThe power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
    4. Wait 15 seconds.
    Step two: Test the power on the All-in-OneFollow these steps to test the power on the product.
  • Apr 07, 2010 | HP Photosmart C6180 All-In-One InkJet...
    Wont switch on
    Solution three: Reset the power module and test the power Step one: Reset the power moduleThe power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
    4. Wait 15 seconds.
    Apr 07, 2010 | HP Photosmart C5180 All-In-One InkJet...
    Fast green blink
    Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure:
    1.Disconnect everything from the computer, including the power cord.
    2.With the power cord disconnected , press the power button on the front of the computer for five seconds. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
    NOTE: If the power supply fan makes an inconsistent grinding sound or stops and starts erratically, replace the power supply
    3. With the power cord removed, flip the red voltage selector switch to the opposite position. Wait about five seconds, and then switch the red voltage selector switch back to its original location. Ensure that the voltage selector switch is on the correct setting, 115V for North America.
    Performing this step ensures that the voltage switch is engaged and set correctly for your country/region.
    4. Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
    5. Plug a lamp into the same outlet to see if the wall outlet has power. Try the computer in a different outlet in order to eliminate the outlet as a possible source of the issue. Test both to see if the wall outlets have power.
    6. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet. Test for power. If this fixes the issue, find the device that is causing the issue and do not use it.
    NOTE: If you find the device that was causing the problem was a surge protector, resetting a breaker or fuse on the surge protector may fix the issue.
    8. Remove all attached devices except for keyboard, mouse, and monitor.
    9. Remove any internal component that was recently added, such as video card, memory, CD, DVD, and hard drives. An added device may take more power than the power supply is rated for. If the problem goes away when the component is removed, the only option is to upgrade the power supply to power supply with a higher wattage rating.
    10. Check the power switch:
    a. With the power cord disconnected, press the power button on the front of the PC. The button should release easily and not stick in the socket.
    • If the button sticks, it should be replaced or serviced.
    • If the power button does not stick and appears to be functioning, continue using these steps.
    11. With the power cord disconnected, remove the case or side panel.
    • Follow the wires from the power button on the front of the computer to their connection on the motherboard.
    • Look at the power switch cables connected to the motherboard. If the cable has become disconnected, connect the power switch cable connector to the connector on the motherboard.
    • Replace the side panel, plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
    12. Find the defective part:
    • With the power cord disconnected, remove the case or side panel.
    • Disconnect all power cable connectors from their connectors on the motherboard and from the back of internal devices (the back of drives). Make sure to label or remember where each cable connects for future reference.
    • Replace the side panel, plug in the power cord, and examine the light on the back of the power supply:
    13. If the LED is on solid and is not flashing, the power supply is probably good and the problem is most likely caused by a defective component (processor, memory, PCI card) or a defective motherboard. Have the computer serviced, or remove the components and replace them, one at a time, to find and replace the defective component.
    14. If the LED is still flashing (it should not flash with all connectors removed), plug the power cable into a different power outlet that is known to be good. If the LED still flashes, the power supply should be replaced.
    15. If the LED light is now off, plug the power cable into a different power outlet that is known to be good. If the LED stays off, the power supply should be replaced.
    NOTE: If an electrical storm or power surge has recently occurred, then it is more likely that the power supply, the modem, or motherboard is damaged and requires replacement.
    Apr 11, 2009 | HP Pavilion a340n (DQ099AABA) PC Desktop
    My hp desktop computer will not turn on
    If you cant see or heard any boot up sounds, fans and especially if you dont see any power or green led lights at all ;
    If your power cord is plugged into a power strip or surge protector, power cycle your strip or surge protector by turning off and on.
    If power outlet has a wall switch make sure its on
    Check that your power cable is securely plug in to both ends
    Check that at the back of computer, specifically on the back of the power supply unit that the switch is on "1" position and NOT on the "0" position ( 1 is "ON" , 0 is "OFF" )
    Check that the power outlet is not damaged by pluging in another good known device (such as a blowdryer, shaver, lamp, radio, etc, etc) to see if its the power outlet or not.
    Can you see power or green led lights and hear the fan on but no display ? If this is the case , check your monitor connection at both ends. If they are secured open up your case and see if you can smell any burnt smell or check that all cards especially video cards are properly seated.
    Jan 21, 2009 | E-Machines eMachines Desktop PC
    Will not power up when the power button is pressed.
    Check your outlet to make sure there is power.  Use an extension cord and try at a different outlet if necessary.  If that fails, you may have a control board problem and needs to be addressed.
    Sep 02, 2007 | LG WM-0532HW Front Load Washer
    Dell Dimension 2400 PC Desktop Logo
    Alun Cox
