Question about Kyocera Mita FS 3800 Laser Printer
How to set up network ip address to a fs3800. Can not seem to find it on the menu
    Problem Solver:
  • 10 Answers
Press Menu, scroll to Interface and press the right arrow key. Scroll using the down arrow and you should see the TCP/IP setting. Press the right arrow and turn off DHCP. Then you can move around to change the IP.
Posted on Jan 09, 2009
Ip address where can i find my tv ip address
Are you sure your TV has an IP address? Not all TVs are networkable.
Like most devices, most TVs expect to be given an IP address when they connect to the network through a process called DHCP. You can probably change that in settings.
If your TV is IP-enabled, you should be able to find the network section of the menu, and find the IP address there. If you decide to manually set the IP address, be careful, because only certain IP addresses will work on your network.
Aug 16, 2015 | Computers & Internet
Kyocera printer hookup to iMac using Ethernet connection
check the network printing settings in the printer, its a problem in the settings somewhere, unless theres a fault somewhere.
Jul 24, 2008 | Kyocera Mita FS 3800 Laser Printer
My network printer not taking ipadress as i have provided static ip through laptop.is there any settings in printer to add ip address . thanks , kalyan
First, make sure you have plugged in a network cable CAT5 or CAT6 into the printer's network card (if you don't have one, then you can't use it as a network printer). Also, the network cable should go to a switch, hub or router.
Second, the IP address needs to be set on the printer, not through laptop. You should browse to the menus of the printer, until you find a menu Network, under this menu you should have TCP/IP sub-menu where you need to set the IP address, also there must be a Subnet Mask sub-menu and a Gateway sub-menu. This two options should be set up as well.
Nov 23, 2010 | HP LaserJet 4250n Printer
I need to add IBM Infoprint 1116 to my home network using IP address. How can I change already setted IP and gatway addresses on it to needed?
If you know ip address of printer then you can access your printer with web interface for that type your printer ip address in internet explorer address bar.
then you can access configuration of printer.
But if you don't know ip then you need to check network configuration menu of printer .
For that press menu button of printer then enter in network settings then you can know the printer ip address.
Let me know if you need further assistance.
Thanks for using FixYa.
May 20, 2010 | IBM Infoprint 1116 Laser Printer
I changed the IP address range of my LAN and need to assign the new range of addresses to my HP printer P2015dn
Press the Menu button on the printer to open the printer’s menu and enable the Network Card – these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network).
Then set the Subnet Mask IP address to 255.255.255.0
Jan 13, 2010 | HP LaserJet P2015dn Printer
Dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
Jul 16, 2009 | Dell 5100cn Laser Printer
How to put an IP address on the CopyStar CS-1820 printer
putting an ip to 1820, just go to system menu, scroll down look for the network setting, you will find ip address, then fill it up.
Apr 21, 2009 | Copystar CS-1820 Copier
How to reset the NIC to use DHCP
If you press the test button once on the network interface (a small black button near the network port) This should print out the network settings, you can then confirm the IP Address etc set on the printer.
I belive the defult setting on the network card is for DHCP= OFF, so if you default the network card you may not get the result you required.
The netword card can be set to defult by holding down the test button for more than 10 seconds. This should reset the network settings to factory defults.
You can unlock the menu on the 6312 by pressing the MENU and ENTER buttons and keep them held down for 5 to 6 seconds you can then access the menu.
The IP Address, Sub Net Mask and Gateway can be set via the control pannel menu on the pritner.
If the IP Address set in the pritner is valid for the network you should be able to get to the printers web page, you can then make changes to the pritners and network card configurations.
Mar 28, 2009 | TallyGenicom 6312 Matrix Printer
Hooking up my Kyocera FS3800 printer to my iMac using the Ethernet connection
sometimes the crossover cable doesn't work.. try a network switch and two regular ethernet cables...
Putting right the ip address ?
Before you proceed you need to know the static IP, Subnet Mask and Gateway address for this printer. Once you have them: -Enter the menu mode by pressing the + button -Press the + button till you come to the Network Menu. -Press the Enter button. You should now see TCP/IP. Make sure it says Enabled which is the default setting. -Press the + button till you come to IP address then press the Enter button. - IP addresses (for now) consist of four octets or four groupings of three numbers such as in this example *192.168.001.123*. Using the + or - buttons (+ counts up 0,1,2,3?.; - counts down 255,254,253?..) you are going to set the number of the first octet or in the case of the example *192*. Once you?ve set it correctly hit the Enter button. -Do the same for the other three octets. Hitting the Enter button after setting the fourth octet will set the new IP and take you back to the TCP/IP menu. - Press the + button till you see Subnet Mask and press the enter button. - Just like the IP address the Subnet Mast consists of four octets. Set the value to you needs just as you did with the IP address. Again when you hit the enter button after setting the fourth octet you will be taken back to the TCP/IP menu. - Again press the + button till you come to Gateway Address and hit enter. Enter the Gateway IP address exactly like you did when setting the IP address. Don?t forget to hit the enter button to set the address. You should now be at the TCP/IP menu again. -To exit the menu press the On-line button on the printer. Your printer should now be configured with you IP address, subnet mask and gateway address. As an added check I would go back into the menu by pressing the + button, going into the Information Menu and printing selecting the Print Menu Map option. Verify the setting we just made with what is printed out at the top of the page. If everything matches you?re ready to go! Let us know how it goes and please don?t forget to rate this posting.
Jan 22, 2007 | OKI C5100n Laser Printer
Kyocera Mita FS 3800 Laser Printer Logo
427 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
