Question about HP Office Equipment & Supplies
Just bought a photosmart all in one printer scanner/fax. It did not come with usb cable I know I need one 2.0 .but there several made...which one do I wand?
  • 37 Answers
The most important thing that you need to know is the plug set-up. Almost all printers use a male A- male B connection. I have included a link to show you what that looks like.
http://www.paperchaseproducts.com/catalog/images/EX041264.jpg
Now the other options are quality and length. Get a cable that will reach from your computer to your printer with some slack but not too much. I usually stay under a 6 foot cord. The quality is dependant on you and your budget. The higher the quality the higher the price. The main quality selling point is less interfierance from outside sources.
Hope this helps.
Posted on Nov 28, 2008
How to fix HP photosmart 3310 printer Error:Oxc18a0106
someone else's answer:
If you get an error message on your printer screen (HP Photosmart C5180) which says " 0xc18a0106 ink system failed ", you'll need to carry out a Master Reset on the printer.
Something usually causes the error to occur and this is usually a failed microchip, out of date chip or interruption when installing a new cartridge and this will have to be rectified before continuing. Most problems are usually from the last cartridge inserted, so start by replacing that cartridge. You will also need to have all cartridges with some ink in them or you'll need to replace any empty ones before continuing. Once the problem cartridge has been replaced, keep it as it may still be ok to use at a later date once the error has been reset.
To reset the printer:
1- Unplug the USB cable from the printer.
2- Press the On/Off button to turn off the printer, unplug the power lead from the printer, press and hold both the "OK" button and the "HELP" button, then plug in the power lead, wait a few seconds and release the two buttons, then press the "On" button.
Your printer will now initialise and you'll need to follow the on-screen instructions and choices on the printer. This may take several minutes to complete. Your error code should now have disappeared and you will now be able to Copy and Print.
3- Replug the USB cable from the printer.
Aug 18, 2014 | HP Photosmart 3310 All-in-One Printer...
We have( several years now) a HP photosmart 2575 All-in-One , we need to scan documents, it was never set up to do that ,we have misplaced the manual as to set it up to our computer. can you help
1) Make sure that you have the HP driver and full-software installed. Go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=&cc=us&product=441240& , select your OS and click Next. Then click on Driver to download it. If you installed the generic driver from the OS, uninstall it and unplug the data cable (if USB) before installing. For some of OS versions, even if you do have the full software, check the version you have, some need to be patched. All of the support for this all-in-one is available here: http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=&cc=us&product=441240 .
2) Place the document to scan face down on the glass or face up in a Automatic Document Feeder (ADF).
Next you can scan from the computer before you can scan using the buttons on the printer. If you want to use the scan buttons, you will need the full software installed and the monitor program running. Then you need to set the button destinations in the HP Solution Center before the buttons will work. Launch the HP software (Start > All Programs > HP > HP Solution Center (some HP printers have a slightly different program but it will be in the same HP folder). Launch the scan and set the resolution and destination folders. Windows computers can also scan from the computer with Paint (File > Import from Scanner or Camera) or Windows Fax and Scan (Vista and Win7).
If you have problems, check the USB cable first. Scanners require bi-directional communication with the computer. Thus they fail when the printer works. Make sure that the scanner is unlocked if a lock exists.
I hope this helps.
Oct 08, 2010 | HP Photosmart 2575 All-In-One Printer,...
I get a message Printer Not Connected when I try to print with my HPC6280
Jackinvero, here are some solutions you may want to try when troubleshooting this problem.
1. First off, make sure the printer/scanner is plugged in to the computer, and that it is in your Printers and Faxes list. Also, ensure that the printer is turned on, and the LED display does not indicate any errors with the printer.( the basic stuff)
2. reset the printer, by turning it off, then on again. Try to print something as a test. If it still says that, unplug the printer cable from both the area it plugs in to the computer, and the printer itself. Check for any breaks or creases in the cable. (if any are found, replace the cable). Plug the USB cable back in to the computer and printer, restart the printer, and attempt to print another page. )
3. if the above 2 options don't work, try plugging the USB cable into a different USB port on the computer. If this fails, you may need to try another USB cable, to test- if everything listed here fails- you will have to contact HP for technical support/repairs.
hope these help.
Jul 02, 2010 | HP Photosmart C6280 Printer
Getting a scanner error have tried several times and cannot get it to clear it will print from computer but will not scan My printer/scanner is an HP Photosmart 4700 but could not find on list
your need to install the driver from you cd/dvd driver which is included when you purchase it. try to reinstall driver, much better install anything what drivers available from your cd/dvd driver. connect all cables, the power cable and the usb from your scanner to computer, then restart the computer and try to scan.
Mar 22, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
I'm getting a color line going down the page on my pictures and the quality of the picture is no good
IssueWhen you copy, fax, or scan an original, the resulting output contains vertical bands, lines, or streaks in one or more colors.When you print the original, the output is normal. Figure 1: Sample output with vertical white or black linesc01892760.gif Figure 2: Sample output with vertical colored bands or linesc01892761.gif
NOTE: This article does not apply to most PSC products, to the Photosmart C6100 or C7200 series, or to the Photosmart Premium C309a and C309c All-in-Ones.If you are using a PSC product other than the PSC 2400 or 2500 series All-in-Ones, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c01887564) (in English).If you are using a Photosmart Premium C6100 or C7200 series All-in-One, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c00899181) (in English). If you are using a Photosmart Premium C309a or C309c All-in-One, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c01622189) (in English). Solution one: Reset the All-in-One If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product.
  1. Make sure the product is powered on, and then disconnect the power cord from the product.
  2. Disconnect the USB cable from the product, and then disconnect it from the computer.
  3. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
  4. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
  5. Reconnect the power cord to the product.
  6. Press the Power button (c01892763.gif ) to turn on the product.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , see the next solution.
Solution two: Clean the All-in-One and print a blank copy If the scanner glass or the white underside of the lid has fingerprints, smudges, lint, dust, or other debris, this can slow performance and affect copy and scan quality. To resolve this issue, clean the All-in-One. Before you begin, gather the following materials:
  • Several clean, soft, lint-free cloths
  • Mild glass cleaner
Step one: Clean the scanner glass and lid
  1. Press the Power button (c01892763.gif ) to turn off the product, and then disconnect the power cord from the product.
  2. Open the scanner lid. Figure 3: Open the scanner lidc01893292.gif
  3. Spray a clean, soft, lint-free cloth with mild glass cleaner.
  4. Wipe the scanner glass and the white underside of the scanner lid with the dampened cloth. Figure 4: Scanner glassc01893293.gif Figure 5: Scanner lidc01893294.gif
  5. Dry the scanner glass thoroughly with a clean, dry cloth, or chamois to prevent spotting, and then dry the white underside of the scanner lid.
  6. Close the scanner lid.
  7. Reconnect the power cord to the back of the product, and then press the Power or Start button (c01892763.gif ) to turn on the product.
Step two: Make a blank copy
  1. Remove any originals from the scanner glass.
  2. Load plain white paper in the input tray.
  3. Press Start Copy Black to make a blank copy.
If the copy is clean, there is no need to continue troubleshooting.If the copy has vertical bands, lines, or streaks, there might be dust inside the product, poor internal connections, or the product might be damaged. See the next solution. Solution three: Service the All-in-One If you have completed all the steps listed above and are still experiencing a problem, service the product. Causes
  • Static interference
  • Loose USB cable or power cord connection
  • Fingerprints, smudges, lint, or dust on the scanner glass
  • Dirt or debris on the scanner lid
  • Scratched or damaged scanner glass
  • Poor internal connections
  • Dirt or debris inside the product
  • Damaged or faulty scanner bulb or parts
Jan 27, 2010 | HP Photosmart 2610 All-In-One InkJet...
Computer prints to hp 2575, but computer will not detect scanner and scanner will not detect computer. what to do?
open control panel and go to Scanners and Cameras check any scanner driver is there what .....try to use the driver if its not working install the all software for the printer and check ..............
Dec 14, 2009 | HP Photosmart 2575 All-In-One Printer,...
Fax test fails on "Using Correct Type of Phone Cord with Fax"
HP printer will support only cable with 2 wire in it.
they are designed in such a way. use the cable that came with the printer
Sep 29, 2009 | HP OfficeJet 6310 All-in-One Printer...
Scanner on my "All in One HP 6110" refuses to work any longer
Please get back to me with the following information to assist you further.
  1. How is your printer connected to computer? (USB or Network)
  2. Have you installed Full feature software?
  3. If you are connected with USB cable make sure the cable is connected directly to the printer without any USB hubs.
  4. What is the OS?
  5. Are you able to copy a document on the printer (stand alone copy)?
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Can't re-load hp photosmart 7150 on windows xp. Gets to the point where the installshield should come up, lingers awhile, and then says check printer power and usb connection. The computer has already...
1.It could be the USB cable. Try a new cable.
2. Could be USB port, use another if available
3. You should be able to install the software without the printer connected.
4. Uninstall all hp printer software, and restart computer.
5. Delete any instances of the printer from the printer/fax located in control panel
Apr 15, 2009 | HP PhotoSmart 7150 InkJet Printer
Windows vista installer msi errors and fatal error
it cood be the wrong type of photo paper try some other type
I HOPE THIS HELP
SHORTY
Jan 08, 2009 | HP OfficeJet 6310 All-in-One Printer...
16 people viewed this question
Ben Johnson
