Question about Epson Stylus Photo R320 InkJet Printer
R320 WILL NOT LOAD PAPER , ANY SIZE
IT WAS WORKING FINE , THEN IT WOULD NOT LOAD PAPER I HAVE TRIED DIFFERENT SIZE PAPER , STILL WANT WORK
I DID NOT HEAR ANY SOUND THAT MAKE ME THING A GEAR HAS STRIPED.
SHOULD I REPAIR THIS OR GET ANOTHER
    Sniper:
  • 54 Answers
If you only use one brand or type of paper try switching to a different brand, you can also get what is called platen restorer, this is used to clean the paper feed rollers.
Posted on Dec 05, 2009
    Genius:
  • 1,447 Answers
Hi
Better get a new, call epson at 562-276-1300 so that you can have a discounted brand new printer from them.
Hope this helps
Posted on Nov 29, 2008
My Xerox Phaser 6128MFP printer flashes a red light with a "Load paper in Tray" message, when the specific paper size and type are already same in the tray.
If the paper size is correct in the printer and the printer and it's possible to print off a test print in both the printer control screen or directly from the print driver utilities if that works then the only thing I can suggest is the item you want to print is defaulted to a different size. i.e. Check that the word processor your using is set to the size you have in the printer. Imperial size pages will look very similar on screen as does the A4. Printers don't automatically fix paper print sizes you just have to check and recheck for differences. Removing the tray only reafirms to the printer that the size might be incorrect and your going to fit the correct size.
As for the red light all printers behave differently in certain error conditions. Have you also tried to print out something you printed at a time the printer was working correctly. In other words try printing out a different file. Maybe, trying to print off a test print of one line of the alphabet, and then go from there.
Good luck,
Apr 02, 2015 | Xerox Phaser 6125 Laser Printer
Why will paper not load in Epsom R320 printer
It could be many reasons.
Correct printer not selected.
Printer not recognized by computer.
USB connection malfunctioning dirty or damaged.
Different printer on default.
Aug 15, 2014 | Epson Stylus R320 Digital Photo Inkjet...
We have a Canon Image Runner 3235 that is hooked up to a network. Every time we try to send more than one document to print off we get the error message to load paper and it doesn't need any paper. ...
if the message add paper related with specific paper size i.e. add A4 paper in drawer, first you need to check is the paper senzor in drawer set to correct paper size - it is blue circle with markins of paper size. Second thing under printer driver properties on PC check if the correct paper size is choosen.
Hope that helps!
Aug 15, 2011 | Canon iR 2016i Black and White Copier
Printer doesnt print in the right format, even the set up is right. Photo paper just taken from Printer in Landscape format, not in Portrait
check for dirver setting for paper selected and application setting for paper should be same and try with the costum paper size for the same
select small paper and check printing
Nov 08, 2009 | Epson Stylus Photo R320 InkJet Printer
CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Dec 01, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Epson R320 Paper Feed Problem
Biggest POS in the world. Brand new and doesn't work right. Will never buy from this company again!
Oct 02, 2008 | Epson Stylus Photo R320 InkJet Printer
Cannot print from Tray 1 in Gestetner 6002
First make sure that the machine is reading/ seeing the paper size of the paper that is in the tray ( select tray 1 from the touch screen and see what the paper size reads). If the machine sees a different size then that in the tray, use the 'user tools' and change the paper for that tray. Also, go into your printer settings on/in your computer and make sure that the proper paper size is selected ( the size that is in the tray you want to print from). If the orientation of the paper size is different from the tray -- will not print and give you the error.
May 06, 2008 | Gestetner - 6002 Digital Imaging System...
Paper Feed Problem
I had same problem... eventually just started using 8.5 X 11 paper to print photos with smaller sizes.
Mar 30, 2008 | Epson Stylus Photo R320 InkJet Printer
Printing
seems that y´all experiencing various paper feeding issues
check first for recommended paper type
that printer should handle 4x6´s up to 8.5x11´s
and if it can´t feed a particular size - hardware issue & check your warranty status with the manufacturer
Dec 24, 2007 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R320 InkJet Printer Logo
102 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
