Question about Toshiba SD-3980 DVD Player
Incorrect disc and bAd
Just thought i would include my common problem to the mix. Hadn't watched a dvd for a while (worked perfectly last time). I settled in for a movie last night and got the "incorrect disc" and "bAd" messages. I blamed my kids.... oh well. I don't believe the discs were dirty (i tried both the questionable dvd i rented from library, and a brand new one which had only been played once). The library dvd played perfectly on my computer. Hence i fault the dvd player. I am trying an unplug/plug back in solution in an attempt to reset any computer error message. I'll report back under solutions if this does any good.
  • jtdd Nov 19, 2007
    I also was playing a disc. when it suddenly stopped I pressed menu and skip and maybe some other buttons and now every disc I put in the dvd says incorrect disc.
I have the same problem, reads bad, won't play, took the top of a blow on it, alot, hoping dust would come off the lens, it did. Works now, also ran a disc cleaner in to after.
Have another dvd palyer, never had that problem, Philips.
Posted on Jan 09, 2008
My problem was :
a. no display on led panel
b. manual power on button works with remote but not physically pushing the button
soln:
a.remove the top cover
b.plug in and power on
b.push the drive head forward.
c. turn on/off
result:
display panel comes on and manual on/off button now works.
bhash
04/08/2k8
Posted on Apr 08, 2008
I took mine all apart and got the darn DVD out of it, and fixed my problem. Never by this one again!
Posted on Dec 22, 2007
Thanks, that worked!
Posted on Nov 26, 2007
After having this problem Incorrect disc and bAd in my Toshibha DVD Video Player SD-3980 after my father was playing with the skip forward and back and ended up messing up and jamming the lens in the DVD player. My only option since I work with computers and new that lens jamming happens, what I did was unplugged it, opened the top, moved the lens chip forward until it clicked in place and then put it back together and I worked. So if you have this problem all you have to do is open it and readjust the lens
Posted on Nov 02, 2007
I gently hit the bottom of the dvd player and it did the trick.
Posted on May 20, 2007
I have tried cleaning the lens and all so the age old solution of plugging and unpluggin the system. Neither of them works. I have also read on many other forums that Toshibha has this problem. This is a piece of junk.
Posted on Apr 15, 2007
1>The DVD may have specific regions so use correct disks 2>Lense may need cleaning or adjusting
Posted on Feb 27, 2007
SOURCE:
A DVD RW that I recorded and have previously watched now will not play in any DVD player, including the one I recorded it on.
You may have encountered a problem that will eventually hit most users who write their own DVD's. The media used to create your DVD's is not immune from damage or aging, and will eventually fail.
You might try to play it on a computer from one of your familly members or friends. Different drives are better at potentially flawed discs. If one of them plays okay, it may be possible to copy your original disc on that computer to make a new copy.
Obviously, how you treat the DVD's you create plays a big part in how long they will last. If you handle them only by the edges, never lay them down on other surfaces where they might get scratched or attract dust, and always put them back in their sleeves or cases, that will help.
The quality of the blank DVD media is also a big factor in how long the media will last. You can search on the web for quality comparisons of DVD blank media to help you make a purchase decision. No media is perfect, and there are error-correcting routines that are used by your computer software to account for the minor surface imperfections that will be present on any blank DVD disc. But there are definitely DVD media makers who produce higher quality blank media than other low-cost makers. This is truly a case of "you get what you pay for".
One other note: While your blank media may say it is rated for "16X" (meaning it can be created using a disc rotation speed that is 16 times the normal rotation speed), I personally never burn my DVD's at the rated speed. Frankly, I don't trust that having the laser beam speed across the disc at 16 times the normal rate is a reliable way to create a long-lasting disc. So I always access the recording options for my disc burning software and set the burn speed to a lower value, like 4X, so ensure the laser has enough time to create a longer lasting burn image on the disc. This applies to CD blanks as well, where some of the drives support 52X speeds. While I don't have any research to back up my disc burning recommendations, I just feel better not pushing my equipment and my disc media blanks to their upper limits.
Oct 01, 2016 | Verbatim DVD-RW Rewritable Disc - 4.7GB,...
Dolby portable dvd player has no disc or disc err
You will have to get the laser replaced.
Thanks, Frank Z.
http://www.attechcomputers.co.cc
3868607368
Jun 24, 2009 | Initial IDM-1731 Portable DVD Player with...
Burned DVD video couldn't play
are the videos you are rying to burn store bought
Mar 25, 2009 | Ricoh MP5240A (RICOHMP5240A) DVD+RW Burner
-bad disc reports
The problem with using rental discs is that they are dirty. Buy a dvd player cleaning disc and follow the instructions. These discs help to realign the laser. If this does not help try cleaning the disc with a disc cleaner. Also depending on how new the dvd is there have been a lot of discs manufactured outside of the US that have been bad. It may not be your machine but the discs. I personally went through 6 of the same movie before i gave up and rented something else that worked perfectly fine. Hope this helps you watch.
Sep 11, 2008 | Televison & Video
Rca DVD/VCR COMBO SAYS NO DISK INSERTED WHEN IT IS
open your vcr and locate the lens.then get cotton budds and clean the lens manually.
Sep 02, 2008 | RCA DRC8300N DVD Recorder/VCR
Dvd player problem
get a dvd cleaner from best buy. mine did the same thing, it would not play any dvds so i resorted to vhs, and once i had watched all of those, i finally got a dvd cleaner and now it works fine
Jan 20, 2008 | GoVideo DV2150 DVD VCR
RX-668V - Center Speaker Channel
have a tech check your set it is a bad cap that that bias a very small voltage to that circuit or it could be cold solder.good luck.
Apr 15, 2007 | JVC RX-668V Receiver
Even when the DVD is in the tray correctly, it says "No Disc"
I had a similar issue and now mine is opening closing opening and then powering off?
Mar 18, 2007 | Toshiba SDK615 Multi-disc DVD Player
Movies on my recorded discs freeze after a few minutes of play
Sometimes this unit gets "confused" - not sure why -- but try first using a CD cleaning disk and let it start and stop a couple times (sometimes lens gets dirty and does this) - if that doesn't help then try unplugging unit and leave unplugged (from wall socket) for about 30min then plug in, set local time and then see if the disks play okay - sometimes this "resets system"
Jan 20, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Toshiba SD-3980 DVD Player Logo
385 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
