Question about Linksys Wireless-G WRT54GS Router (e125894)
Wifi password Hi there, I have a dlink 625 wireless router. Everything works fine and has for months. I can access the setup and have set the admin and user passwords.  I cant figure out how to set a simple password that must be entered for wireless access? Thanks for any info.
  • coreyjubes Nov 29, 2008
    Great, thank you for the tip. Saved me from taking a golf club to my router! Much appreciated.
    Will the router request a password each time used, or does it remember my laptops address? We have 2 laptops and it has only initially requested a password.
This is not a step-by-step but you should be able to do it any way...
Login to router as admin then go to wireless, then go to the wireless security, there you should be able to enable the security as well as selecting the encryption type, select WPA personal select TKIP and give it a password. Hope it helps
Posted on Nov 28, 2008
Hi i Just bought dlink 600 i am using compaq and has iphone and internet tv all of them cant connect by wifi my compaq can only connect with a cable. on my tv it says internet connection failed. and btw cm...
ok first prep. we need to configure your router. to do that we need your compaq laptop directly connected to the dlink via ethernet cable. after securing the connection, try to open a browser, whether internet explorer or mozilla firefox. go to the address bar and type in, 192.168.1.1 it would ask you now for a username. username is " admin " password is " password " if it wont let you in, try "admin" for password. if it still cant, try to live it blank and just click on login. it would take you now to the dlink router page. there you can configure your wireless connection and set your network name. make sure to click apply settings after configuring it. then try to check your wireless connectivity again. this should work.
Sep 02, 2011 | D-Link DIR-600 Router
My router suddenly stopped working yesterday and I've tried everything I can think of to fix it. I have one computer wired directly in to it and a few laptops that use wireless connections. The...
Please try to access the router's configuration page by accessing 192.168.0.1 using a computer that is wired on the router.
Default admin user name:Admin
Default admin password:
Please update firmware:
Note:Please do not upgrade the firmware over wireless connection. Anyway you wont be able to do that now but for future reference. Please use the link on the bottom.
DIR-625:
http://www.dlink.com/products/?tab=3&pid=DIR-625&rev=DIR-625
DIR-625 rev C:
http://www.dlink.com/products/?tab=3&pid=DIR-625&rev=DIR-625_revC
Jul 10, 2011 | D-Link DIR-625 (790069292637) Wireless...
How to put password so the neighborhood couldnt access my dlink router
All you have to do is connect to the router and change security key/ secure the connection. Just follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (Default router settings are written under the router)
(unless you've configured otherwise, the default username is admin and the password "leave it blank")
Lookup for the options to do the following: -
Next step is to secure it (adding a network security key):
1.On the left-hand side, under Setup, click "Wireless Setup" Click on Setup at the top and then click Launch Wireless Security Setup Wizard. Select your desired encryption method (WEP
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Save Settings.
Also, do the following changes: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password
(The above steps would prevent unauthorized access to your router)
Now your router and your connection would become secure and the user has to provide the network key to access the internet. Please note down the settings such as SSID Key, User Name/Password and Security as in case you loose this information you cannot recover it back)
You may also download and refer to Page 60 onwards of the PRODUCT MANUAL DIR-625 for further information, if required
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 04, 2011 | D-Link DIR-625 (790069292637) Wireless...
I was given a dlink dir 625 router with no installation cd or manual. how can i set it up and make it secure?
Get the install wizard from http://www.dlink.com/support/, but here are the highlights of what needs to be set:
Wireless Router settings:
It is usually easiest to run the install wizard, which you can get from the manufacturers' website, usually for free, but be sure to be ready to set the items listed below:
To get access, start your browser, and put 192.168.1.1 or 192.168.0.1, or other address for your unit, into the ADDRESS bar (not search box) of your Internet Browser. Every unit has unique access login and passwords, some are admin with no password, some are admin and admin...seek access information from the website of the manufacturer of your unit. Look under support, downloads, drivers or similar sounding areas.
Things to set:
(Note: Routers are intended to be set by geeks. You have to SAVE EVERY page before you leave it, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes. SAVE OFTEN.)
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is typically NOT the security issue.
2. Set a recognizable system ID (descriptive name is easier to find when you need to connect wirelessly).
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping this information to bottom of the router. (Physical access is usually not the security issue.)
4. Check that your router is set to broadcast its' presence.
5. Change the channel of the wireless to 11, and avoid conflict with landline cordless phones. (Big issue, even the neighbors can interrupt).
There are more secure settings available, all the way down to only allowing certain MAC addresses to have access. A MAC address is a digit unique to each and every network card. Like a fingerprint. Most users do not set mac address limits.
Jun 25, 2011 | D-Link DIR-625 (790069292637) Wireless...
I DO NOT HAVE A CD FOR MY dlink 628
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Oct 13, 2010 | D-Link DIR-625 (790069292637) Wireless...
I can't connect to the internet with dlink router
http://192.168.0.1
or
http://192.168.1.1
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Jun 06, 2010 | D-Link DIR-625 (790069292637) Wireless...
HOW TO ACCESS DLINK WIFI ROUTER BECAUSE OF FORGOTEN PASSWORD
You reset the D-Link back to the factory default by - Press the RESET button at the back of the wireless router when it is powered up. Holt the RESET button foe at least 5 secs until the LEDs flash and then release the RESET button.
You can then configure the D-Link as follows ;-
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 19, 2009 | D-Link DI 514 Wireless Router (DI-514)
Dlink wbr-2310 router no wireless working
you have to change your channelk type in your wi fi router.
For that access your router with following link
http://192.168.0.1
if you have belkin router
http://192.168.2.1
type user name as "admin" and password is "admin" or blank or "password"
then go to wi fi ->advanced setup chang channel type 4 ,6 ,11
change chanel type 1 by 1 and check signal strength.
everyt time save settings and restart both computer and router after save settings.
Thanks for using fixya.
Please rate this solution if it helps.
Jul 23, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
D-link Router DIR-625 resets itself
You need to open the router's setup page (admin page) http://192.168.0.1 to enable the wireless security
Feb 13, 2009 | D-Link DIR-625 (790069292637) Wireless...
Linksys Wireless-G WRT54GS Router (e125894) Logo
49 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
