Question about Saws
Trouble removing blade
Bolt securing blade is so tight - don't know if this is a left hand or right hand thread - don't want to strip the thread in the motor
  • Anonymous Dec 09, 2008
    quick change is broken cant remove, how do i remove.
    Top Expert:
  • Saws Master
  • 77,499 Answers
The bolt is counter clock wise (standard thread), use a screw driver to jam the blade
Posted on Nov 28, 2008
  • 3,600 Answers
First guy is right also use a socket 6 point to get the nut loose and you can tap it with a hammer just a little to break it loose.
Posted on Jun 25, 2009
Changing blades on 2008 mtd rideon mower,are they left hand thread or just incredibly tight.
to remove the bolt or nut turn it the same direction the blade turns when cutting. This way the bolt tightens itself as it mows not back out and slip.
Dec 15, 2016 | Mtd Garden
The bolt securing the blade works loose (and therefore the blade is unsecured)
Simon, very dangerous, Fully remove bolt and check the threads, if you think threads on bolt are questionable replace bolt. Pick your self up a small tube of Loctite for threads of bolt, before reinstalling coat the threads with Loctite and reassemble with all necessary washers and hardware.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 21, 2016 | Garden
Are the Cutting blades bolts for a John Deere LT 160 right handed thread or left handed thread?
It is typical to use right handed thread so you would turn them clockwise to install, and counterclockwise to remove. The blade rotates towards the cutting edge which is typically counterclockwise, so to remove the bolt, you unscrew it, with the handle of your wrench pulling towards the back of the blade.. These bolts can be really tight. Pull the spark plug lead or remove the ignition key so you don't get an accidental start. Wear gloves, there are sharp bits.
Mar 17, 2015 | Cars & Trucks
Blade bolt is stripped
I assume that the head of the bolt is rounded off, so you can't get a hold of it to remove it. (Most people say "stripped" when they mean the threads of the bolt or the hole are destroyed.) First, confirm the direction you need to turn it, which differs if the blade is on the right or left. If you are looking at the head of the bolt, the teeth of the blade will be pointing in the direction that you need to turn the bolt to loosen it. I assume you have already tried vise-grips to no avail. The next easiest thing to try is a small rotary grinding tool (like a dremmel) - you can use that to grind two parallel flat surfaces on the bolt so that you have something to grip. If the head of the bolt is too thin for that to work, you are going to have to use a screw extractor which requires you to drill a hole in the head of the bolt. However, if this is a left-handed thread (which would be the case if the teeth of saw are pointing clockwise, you will need a left-handed screw extractor - which might be hard to find. Good luck.
Oct 16, 2012 | Rockwell Rk7136 1 Shop Series Miter Saw...
Does the blades have left hand threads or right hand threads when relacing the blades
The blade bolts have a normal right-handed thread orientation. But remember, when you are installing a blade bolt, the bolt is facing UP from the ground, not DOWN to the ground; hence the confusion.
Jul 19, 2011 | Craftsman Garden
Blade keeps coming loose
Check to make sure the blade washers are installed correctly and the right order The thread is left handed on the bolt and should tend to tighten from the toqure of the motor spining If this dosn't you could try a drop of white lock tight on the threads of the bolt but don't use red locktight its to strong
Jan 30, 2011 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Cannot remove blade from craftsman circular saw
without knowing the model number I can only assume that it is a circular saw and the blade is on the right hand side and then the bolt should be a standard thread. Hold the spindle lock in and turn the bolt counter clockwise to loosen. If other than it would probably be a left hand thread and do just the opposite. Let me know and if so please provide the model number so I can look at a breakdown for the tool.
Jan 31, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Trouble un-screwing edger blade bolt
It may have left handed threads and needs to be turned clockwise to unscrew. As for sharpening an edger blade...it won't cut any differently. That short blade, traveling that fast and rubbing against concrete is going to do it's job, sharpened or not.
Jun 20, 2009 | Garden
Saws Logo
426 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
