Question about Compaq Presario X1000 Notebook
Laptop dvd drive door will not open
I can not open my Compaq laptop dvd drive door any clue how to open? I have removed the drive from the laptop ( toshiba model sd-r6252 )
  • 1 more comment
  • Phil Gardner Jan 16, 2007
    Thanks for your fast reply I already had it opened by going to the following site. I opened it before resorting to the paperclip
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    Before you begin
    Get a paperclip and restart the computer.
    Opening the tray
    Use the following steps, in order, until the door is opened:
    NOTE: After opening the door, you may find that a disc has shattered inside the drive. If so, try to find and match all pieces of the disc. If all pieces cannot be found, the drive should be replaced as the damaged pieces may cause further damage to the PC and other discs.
    If the keyboard has a CD/DVD Eject key, press it. The Eject key is usually placed by the volume knob and is marked by a triangle pointing up with a line underneath.
    Double-click My Computer.
    Right-click the icon for the CD, CDRW, or DVD drive that is stuck, and then click Eject.
    If the CD or DVD drive door button is a long clear plastic bar on the front of the PC, press firmly on the right side of bar. Some models have a button on the front panel of the PC to the right of the hinged door. Press the button to eject the drive.
    If the drive door button is part of the PC case and is covering the actual drive door, open the door that is part of the PC case and press the Eject button on the faceplate of the drive.
    Restart the PC and press the Eject button on the front of the drive when the first screen appears (before Windows launches). If the drive door opens this way but does not open in Windows, another software program is taking control of the CD driver. Try shutting down or configuring any software programs that create discs or monitor the CD or DVD drive.
    If the door still does not open, do the following:
    Close all programs and shut down the PC.
    Unplug the power cord from the power outlet.
    Look for the small hole on the faceplate of the CD or DVD drive. This is the manual release. The location of the manual release hole will vary (see Figures below for possible locations).
    NOTE: On some models it may be necessary to remove the front panel to expose the manual release hole. Check the documentation that came with your PC for information about removing the front panel.
    NOTE: On some models the release hole and the drive activity LED look similar and are about the same size. Do not force the paperclip into the hole if it does not go in. Make sure that the hole is not actually the LED.
    Figure 1: Possible location of manual release hole
    Picture showing possible location of manual release hole
    Figure 2: Possible location of manual release hole
    Figure 3: Possible location of manual release hole
    Straighten the paperclip and insert it into the manual release hole until resistance is felt.
    Once the resistance is felt, keep pushing the paper clip until the drawer opens a little.
    Remove the paper clip and gently pull out the drawer until the disc is accessible.
    Remove the CD and turn on the PC.
    If the tray still does not open, do the following steps to check the power cable for the drive. Work on a hard flat surface over a non-carpeted floor:
    WARNING: The edges of metal panels can cut skin. Be careful not to slide skin along any edge of the computer's interior metal.
    CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface (like the metal frame of the PC).
    Turn off the PC.
    Unplug all power cords from the back of the PC.
    Press and release the Power button on the front of the computer.
    Remove the side panel.
    locate the power cord that connects to the back of the CD or DVD tray that is having the problem.
    Unplug the power cable and wait five seconds.
    Find a different power cable that is not being used, plug the different power cable into the back of the drive, making sure that it fits firmly into the socket. If a different power cable is not available, replug the original power cable into the back of the drive, making sure that it fits firmly into the socket.
    Replace the side panel and plug in the power cord.
    Turn on the PC and press the eject button on the front of the drive.
    If the optical drive does not have the manual eject feature and the CD tray will not open by using the steps in this document or if a disc has shattered inside the drive, the CD, CDRW, DVD drive may need to be replaced.
  • xlsia3 Feb 10, 2008
    able to open with cd in cd tray/without cd in,cd drive do not open
  • Anonymous May 12, 2008
    i have
    President:
  • 2,961 Answers
There is a tiny hole on the draw in which to insert a paperclip to manually eject the draw.
Posted on Jan 16, 2007
Toshiba laptop dvd door will not open
Posted on Feb 13, 2011
I went back into Record Now program and it had a eject cd button that overides the manual release button.
Posted on Jul 05, 2008
  • akshay dhakal Aug 12, 2013
    i have open dvd drive from small hole and it opened but again after closing the drive it didn't open so please help me and give best soln.
How to remove the DVD drive
Turn off and unplug the laptop, some where on the bottom of the laptop will be a single screw, about 5 inches from the DVD drive edge of the laptop, remove it, it may be a long. Once that is removed, open the drive's tray, using a paperclip (stick it into the "very small hole" in the front DVD drive draw, and press it in slowly...) the door/draw will open. Grab the door/draw and slowly pull out, IF it doesn't come out, you may have removed the wrong screw... try again.
Jul 17, 2012 | Toshiba Satellite A65-S1065 Notebook
Help my dvd drive is stuck and wont open
Desktop or Laptop computer wasn't stated.
With most desktop computer optical drive's there is a tiny hole located right under the optical drive tray.
(The tray the disk is inserted in)
A paper clip is straightened out, then inserted into the hole.
This is a manual override, and will open the tray.
There are some desktop computer optical drives, that the computer case has a door that flips down, then the optical drive tray comes out.
The door must be eased down far enough to see if the optical drive has the small hole.
With a laptop computer the optical drive is removed from the laptop.
Generally there is one small Philips head screw that is removed from the bottom side of the laptop, then the optical drive tray is opened with the paper clip, and the optical drive is then removed by using the tray as a handle.
The optical drive is then pulled straight out.
Once out the top cover is removed for access to the disk.
If this information is not what you seek, or you would like it explained, please post in a Comment, and we'll work together on finding a solution.
Regards,
joecoolvette
Apr 21, 2011 | HP Compaq Computer Speakers
Dvd door keeps opening. Won't load dvd. Won't stay closed.Compaq laptop. Bought at Wal Mart this summer. Problem started a few weeks ago. Aaaaargh.
Check and make sure a disk is not stuck in the disk drive. If a disk is not stuck try closing the door and hold the door close, shut down the computer. Start the computer and hold the the door while the computer reboots. Hope this fixes it. djmax1966@yahoo.com..
Nov 08, 2009 | HP Compaq Presario R4000 Notebook
I have a compaq presario cq 60 laptop with Vista - i don't understand how to access the CD-ROM drive - I would normally expect it to appear as an additional drive using the Explore function, but I can't...
Normally it would show up in "my Computer" as a drive, if it is not, then the computer is acting like it is not installed or not enabled. Go to the device manager and look for the dvd drive there and see what the properties say. Put the computer on its back and with a small phillips screwdriver, remove the screw that holds the drive to the motherboard. Now flip the laptop back on its feet and insert an open paperclip into the small hole in the door of the dvd drive bezel, this willphysically trip the door to open. Pull the door and tray out and keep pulling and the rest of the drive will follow. Power up your laptop with the drive missing and access "My Computer" and see if anything changes. Now,power down the laptop, remove the battery....wait 30 seconds and slide the drive in and make sure it seats all the way in, replace the hold down screw, replace the battery and power it up. Let windows recognize the drive and load drivers for it. If it does not read the drive, there may be an issue with either the interface on the drive or the socket on the motherboard.
Oct 04, 2009 | Compaq Presario CQ60-220US PC Laptop
Replace dvd drive on eMachines laptop
I have removed this drive from my M5414 by removing the bottom case screw that is in between the battery latch and the Left edge of the DVD drive door as you face it. The trick is getting a hold on the drive to remove it AFTER THIS SCREW IS REMOVED.
I solved this problem by opening the drive before shutting down the computer.
Next remove the battery.
Now remove the bottom case screw between the battery latch and the left corner of the DVD drive.
Now since the door is open you can extend it all the way and grab INSIDE THE TRAY, NOT THE FRONT BEZEL, and gently pull it straight out.
Be patient, you may have to wiggle it slowly and gently left to right, you will feel it loosen, and notice it move forward. IF NOT, DO NOT FORCE IT.
Apr 05, 2009 | Computers & Internet
How can i replace my cd to a dvd in my compaq lab top
You'll have to order a drive for your model of laptop (either from the manufacturer or from ebay), and have it installed. Most of the drives in this style of laptop are held in place by a single screw. Power down the laptop, remove the retaining screw, remove the old drive, install the new drive, and replace the screw. Windows will detect the new drive automatically, and then you can install the DVD software. Keep us posted and good luck.
Mar 07, 2009 | HP Compaq nx6110 PC Laptop
How to remove the optical drive from a Compaq Presario 3045US?
Open the RAM door and remove the two screws underneath. The optical drive will slide right out.
Jan 11, 2009 | Compaq Presario 3045US Notebook
How to replace the cd rom in laptop with a dvd-rw
laptops are very tricky to open...it is much better to look for a nearest compaq support center and have it checked by their own technician.
Aug 06, 2008 | Computers & Internet
update the firm ware for this drive if that is possible. This will rewrite the eprom data and hopefully restore lost functionality.
Feb 11, 2008 | Computers & Internet
if you cant open the rom drive, unravel a paperclip and stick 1 end into the tiny hole on the rom drive.
if you get tired of doing this you have 2 options
either take it to a local repair facility or buy a new drive and install it yourself
Dec 08, 2007 | Computers & Internet
Compaq Presario X1000 Notebook Logo
8,009 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
