Question about iRiver Audio Players & Recorders
Hi plugged in 12v power to my 5v charging connection.Screen flashed for 3 seconds& turned off with bad smell of burning. Now wont power up at all even with charger ?
    New Friend:
  • 161 Answers
R.I.P. cremate whats left.
Posted on Nov 29, 2008
How to charge it
Hi Stacey
How to charge "what model" Cell Phone
iPhone & others usually charge from the USB cable that it comes with.
Plug into any USB port (5v DC)
Some chargers supply more current which can give a faster charge. iPad chargers supply 2A where as iPhone chargers are 1A
Sep 13, 2015 | Cell Phones
Meos dvd92b not charging
Hello:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 29, 2012 | Cell Phones
I hae a vizio E320VL, i have replace main board and the power suplly, and it still won't stay on.
hi. you sure your replacement -- power supply & main board in good condition???? lcd present 5v , 12v, &24 v ??? if no you need going back power supply. if yes. you need to replace inverter board as possible. good luck!
Sep 01, 2012 | Vizio L32 32 in. LCD HDTV
Does not boot up. fans & hd run but no beep
Fans are usually 12Volts, hard drives are 12V for the motor and 5V and/or12V for the electronics inside. It could be a bad power supply that only puts out 12V but not 5V. Also ensure that all plug are okay, including the large 20 or 24 pin main plug, and some mo-bos have an additional square 4 pin power plug.
If swapping power supplies fixes it, there you go. Otherwise it's either a wiring problem or dead mobo.
May 09, 2012 | ASUS P5LD2-VM Motherboard
Wont turn on light just flash back and forth on speed setting
gilly your controller still thinks you are charging the chair. This error is a charger inhibit error which means that when you have the charger plugged in you can't drive the chair. If your charger is not plugged into the chair then you have a problem that needs to looked at by your provider where you got the chair or by a tech Sorry I don't have a quick fix Hope this helps you
Sep 25, 2010 | Pride Mobility Products New Pride Mobility...
I have everything hooked up correctly and cleanly, but when i turn my truck on the blue light flashes on then off and my subs do nothing. I don't know if its shorting out or what is going on.
sounds like a loose ground, or a loose positive cable or possibly a blow inline fuse, and the only power your unit is getting is from the remote. triple check all your connections. use your senses, smell the amp, smell for a burned order, this usually identifies if it is something internal. but it sounds like in your case (from experience with) a bad ground. If your gound or positive is connected but not tight it may be enough to power the remote circut, but not good enough to handle the actual turn on (Click) of the circut. powering the led light usually takes about .5 amps, but powering the turn on switch usually takes anywhere from .5 to 20 amps, then the inital charging of the capacitors that are internal on every amplifier... that quick charge pulls a decent amount of curren fast (usually the first 2-3 seconds) to fully charge a small amplifer after it has clicked on. hopes this helps
Aug 08, 2010 | Sony XM-2002GTR Car Audio Amplifier
Green flashing light
Remove the PSU. If you have another one of equal (preferably larger) power output, then replace it and connect it like you normally would (sata connectors, aux 12v 4-pin, molex hdd connectors, etc...) and see if it works.
Its most likely that one of the 12v or 5v rails has burned out or that the entire unit itself is burned out. Either way, its done in. You'll need a new one.
May 22, 2010 | Bestec (ATX100-5) (ATX1005B) Power Supply
Charger/power light will not come on when plugged into usb or car charger
Check the FUSE usually located in the plug if so equipped try owners manual. Also check car fuse for short or overload fuse opens, also bad battery replace it, try Mouser electronics lotta techs are ordering on line no min order.
Apr 16, 2009 | GPS
Soyo 19" flat screen monitor
Hi, these monitors are dropping like flys and it's due to power supply problems. There is a power supply that needs to supply 5v, 12v, 24v. The 5v and 12v is for the logic boards and the 24v is for the back light. On other boards people have tried to repair the supplies with no luck (same here).
The best fix is to purchase two power bricks off of ebay. Get one that supply 5v 12v that are used for external hard drive enclosures and get one 24v that is used for mac g4 laptops. Both can be had for < $10. Then you will have to replace the internal power supply with these. This is not for the beginner, but if you have any experience with soldering and wiring you should be able to do it. You will have to tap into the 12,5 volt wires, I used the PC style power 4 pin connections and attached the other end to the power supply. You will also have to do this for the 24 v lines. A bit of cutting / stripping, soldering and getting the AC to both will do the job.
The only thing that this will not do is shut of the 24 v supply during idle. Best this is to remove power from the monitor when not in use. This should fix an no / power / on then off / problems with this monitor.
Total time is probably about 2 hours and tools needed are the replacement power bricks, cutters, soldering iron, solder, electrical tape, screw driver... etc
ort11
Oct 25, 2008 | Soyo DYLM1798 Monitor
63 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
