Question about Reddy R60A Utility Heater
Does it have a themostat?
I have a borrowed reddy heater r 50, I think it keeps shutting off because it has reach temp.. if i hit reset it comes right back on... runs for 20 mins then off again ... two knobs in the back one red one white.. are either of the themostats?
  • 232 Answers
The R50 has no thermostat.
The two knobs... are they screws? In the round black plastic end cover? If so, do NOT adjust because they are not a thermostat, instead, this is the heartbeat of the fuel system. The air pump pumps fuel to the nozzle and atomizes the fuel. If you have adjusted the one with a hole in it you will need to reset the pump pressure. It's easy!
http://reddyparts.com/pressure.htm
Posted on Nov 29, 2008
Heater not putting out hot air like it should
Put in a low temp themostat and see if this helps. Also check your mix on your antifreeze. Make sure it is 50/50 or what ever the dealer recommends.
Dec 01, 2011 | Cars & Trucks
When heater reaches controlled temp and shuts off it will not re light.
This sounds like a bad thermostat. Myself I run them wide open and unplug it if it gets to hot.You can replace it or follow my lead and just unplug it when it is hot enough.
Dec 26, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have reddy heater125t the flame lite
It sounds more like airflow and too high of a temp. The fan blades and return vent side must be very clean to keep this big guy pushing the btus out of the heater. A restriction of any kind could cause this overheating situation causing it the shut itself down. If you are confident that air is not the problem, make sure the nozzle that the kerosene comes out of is clean also.
Jan 09, 2010 | Reddy HEATER RH125T 125,000-BTU...
I have a unit that has built in thermostat. When
my ready heater pro115 model numberr115 keeps shutting off
Dec 20, 2009 | Reddy R115DT Oil Filled Utility Heater
Reddy Heater 50'000 BTU - Puffs Smoke and Leaks Out The End
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 30, 2009 | Reddy R60A Utility Heater
I have a reddy heater model r 50.. It ran for an hour, then shut off, I f I reset it, runs for 15 min or so shuts off... its old and borrowed, I think i might have a thermostat on it and just shuts off...
The R50 does not have a thermostat.
The 2 knobs that you mention- are they the screws in the black plastic end cover?
If so, these are the heartbeat of the fuel system and do not adjust. They adjust the air pump pressure which puts fuel in the nozzle and atomizes it. The pump pressure is critical. If the pressure is not correct the heater will shut down.
If you have adjusted the screw with a hole in it you will need to reset the pump pressure to specs. It's easy. http://reddyparts.com/photocell_test_sp.htm
Now, if you have not adjusted the pump, then you might want to check the tank for water.
Troubleshooting tips
Nov 28, 2008 | Reddy R60A Utility Heater
Reddy R60A Utility Heater Logo
89 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
