Question about Reddy R60A Utility Heater
I have a reddy heater model r 50.. It ran for an hour, then shut off, I f I reset it, runs for 15 min or so shuts off... its old and borrowed, I think i might have a thermostat on it and just shuts off when it comes to temp... two knobs on the back side one red one white.. are either of these a thermostat?
  • 232 Answers
The R50 does not have a thermostat.
The 2 knobs that you mention- are they the screws in the black plastic end cover?
If so, these are the heartbeat of the fuel system and do not adjust. They adjust the air pump pressure which puts fuel in the nozzle and atomizes it. The pump pressure is critical. If the pressure is not correct the heater will shut down.
If you have adjusted the screw with a hole in it you will need to reset the pump pressure to specs. It's easy. http://reddyparts.com/photocell_test_sp.htm
Now, if you have not adjusted the pump, then you might want to check the tank for water.
Troubleshooting tips
Posted on Nov 29, 2008
Reddy heater 55 runs about 5 mins the a puff of
This a classic occurance due to low fuel in the tank.
Jan 21, 2010 | Reddy Heater-30-55,000 BTU Variable
Reddy heater 165,000 runs for approx 15 to 20 min. I unplug wait 5 min. it restarts again and runs for another 15 to 20 min. and so on ....and so on purchased approx 1 year ago
There is a sensor in the tube that is a safety feture. it is a snap disc it maybe faulty, it is reading that the tube is to hot and shutting down, it cools and works again, check snap disc and also they need pleanty of fresh air.
Jan 13, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy pro155 runs for 3 to 5 seconds
Reply with the correct model number. "Pro 155" designates a series. We need to know whether you have a heater with a spark plug or a heater with an ignitor (glowbar).
Feb 01, 2009 | Reddy R155D Utility Heater
Heater shuts down prematurly
If the heater runs fine for the 15 or so minutes without smoke/odor- do this
  1. check for water droplets on bottom of tank
  2. check for restricted fuel filter
  3. test photocell
  4. test safety control (reset)
You don't state whether this is a spark plug heater *or* Hot Surface Ignitor type. I made the assumption you were inquirung about a Spark Plug Heater. Disregard the list if the heater is an HSI type---- troubleshooting is different.
More troubleshooting tips for a Spark Plug Type heater
Dec 25, 2008 | Reddy R70ET Utility Heater
Does it have a themostat?
The R50 has no thermostat.
The two knobs... are they screws? In the round black plastic end cover? If so, do NOT adjust because they are not a thermostat, instead, this is the heartbeat of the fuel system. The air pump pumps fuel to the nozzle and atomizes the fuel. If you have adjusted the one with a hole in it you will need to reset the pump pressure. It's easy!
http://reddyparts.com/pressure.htm
Nov 28, 2008 | Reddy R60A Utility Heater
Reddy R60A Utility Heater Logo
208 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
