Question about GPX PDL705
Tip polarity on GPX PDL 705
I have a universal adapter and need to know the tip polarity for this unit?
    Champion:
  • 303 Answers
It is positive
You can buy a new one by clicking on the hyperlink:
buy replacement ac power adapter charger GPX PDL705
Posted on Mar 04, 2009
Get a replacement battery for my gpx pdl 705
www.batterymart.com/c-portable-dvd-player-batteries.html
www.batteriesplus.com
Nov 26, 2014 | GPX Televison & Video
What is the polarity of the jac/mic so I can charge rechargeable batteries by ACDC adaptor
On you're AC adapter unit, there should, if it's a good one, have a switch with a + & - signs indicating the polarity you require to use.
Further to this, does your radio have an AC recharge point. Some of these units don't have this capability, but in your case it may.
This is usually found on the side of the radio.
If there is no such point, then what you need is to buy rechargeable batteries with the appropriate charger, you can't just use any charger for these batteries, else you'll damage them.
I hope this helps you.
Best regards,
Peter
Jan 27, 2013 | Columbia Telecommunications Group...
Blueparott B250XT Charger Specs
9vdc positive tip. Road King RPDC-812 available at most truck stops work great it's a universal dc adapter and the orange end fits the 250xt. Price $15 at Love's.
May 01, 2012 | VXI Corporation Blueparrott B250-XT...
Hi, I'm not sure of the polarity of the Lexicon mx200. I have bought a multi tip transformer & it gives 2 options of outside + or inside +, do you know which is which please, I don't want to fry it!...
DO NOT use universal adapters to run these devices. Accidents are too easy and often the universal devices do no have adequate filtering. You are off on the wrong foot to start with as this unit does NOT have a polarity since it REQUIRES an AC adpter, not a DC one. What you have WILL NOT WORK. If you have connected it, it should NOT have caused damage, you just won't get any audio out, even if the unit lights up on one polarity. The unit generates both polarities inside using the AC input.
Here is an example of correct adapter: http://lcdpayless.com/productpage.php?productId=5793
Apr 25, 2011 | Lexicon MX200 effects unit (with )
What is the output polarity for the ac adapter for the pdv-705 Tip positive or tip negative
If it is not marked on the adaptor or by the socket on the dvd player measure the contacts on the jack when you get contiuity with a ground ie headphone jack opening that will be the negative.
Oct 31, 2009 | Durabrand PDV-705 Portable DVD Player
Where i find ac dc adaptor durabrand portable pdv 705
You should go to a local electronics shop with the old adaptor.
They merely need to match: Voltage in Voltage out Current requirements Plug size Plug polarity (center positive or negative) There is nothing "magic" about the original vendors power adapter.
Oct 06, 2009 | Durabrand PDV-705 Portable DVD Player
Multi region code for GPX PDL 705 portable DVD player
I hope this helps^^ try it and gimme a shout!
Turn on power.
Open lid.
Push 9 7 3 5 from the remote.
Select 0 using arrow keys.
Exit Setup.
Done.
The one above did work me, only that after one turns on the player, enter in the 9735 with the remote and press 'enter', you can choose between making your player region-free or a different region in addition to R1. Select the desired region unlock and press 'enter'.
Make sure you check the bottom of the DVD player to see if it was manufactured in the first quarter of 2007, that might factor in whether the code can work or not.
Apr 01, 2009 | GPX PDL705
I can't determine the polarity of my GPX PDL705 portable dvd
I have uploaded the GPX PDL705 manual to this site today. If you check tomorrow they may have posted it by then.
If you look at the small print on the adaptor it should indicate by diagram Voltage output, current capacity, type and tip polarity by small diagram. Most adaptors are 'positive' -- but if you are unsure do not plug the adaptor into the device because it will fry it!
Dec 05, 2008 | GPX PDL705
Modified power conector polarity.
I know what you're trying to do, and I don't recommend it. I've done some splicing, and had a few that burned up the machine, so I recommend buying a new power supply. Check Ebay, you can generally find one at a reasonable price. Here check this link to Ebay, they have your adapter for $16 and change. You can't beat that. So why take the chance of ruining the machine.
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=ECS+A535++ac+adapter&category0=
Aug 21, 2008 | EliteGroup ECS A535 Notebook
Need to know the polarity
you can set positive and negative of the universal power adapter 110v to 220v.
May 05, 2008 | Scanport 821S 17" LCD Display Monitor
GPX PDL705 Logo
180 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
