Question about Motorola Mobility Bluetooth Hands Free Headset Wireless Headset
Bluetooth conectivity problem
I have a verizon Samsung phone and a motorola bluetooth. Whenever I pair the two it works fine until after awhile I'll hear a beep noise in the bluetooth (like it's turning off) when not in use. Then after when I answer a call or try to use the bluetooth to make a call I get nothing but static. Also, when people call (sometimes) when I answer the phone they hear nothing but static on there end only. But I can hear them fine on my end which is weird. Then after about a minute it goes away and they can hear me again.
The one solution that always works is whenever I hear the bluetooth beep off on its own, I reboot the phone and it beeps back to where it's connected or paired again.
Why is this happenening? I tried to get another bluetooth thinking it was faulty and they all appear to do the same thing.
Has this ever happened to anyone else? Please help!
suisboy
  • 175 Answers
SOURCE: no voice or sound
Did you check that you didn't activate mute?
If it is on mute. Press both volume buttons at the same time you will hear two descending audio tones.
Posted on Jan 10, 2008
PyroPCMan
  • 405 Answers
SOURCE: pairing motorola h500 with an lg voyager phone
Good Day,
Passcode is "0000"
Hope this helps
Posted on Jul 02, 2008
SOURCE: bluetooth pairing
that motorola is in the series of bluetooths that all have 0000 for pin numbers and they are NOT changeable.
turn bluetooth off push the button with the phone on it until lited LED turns Purple immediately release and open mic, now it is ready to pair.
then go to the phone tool>bluetooth> search for device enter pin 0000
it will then verify and Voila you are set
Posted on Dec 11, 2008
SOURCE: Motorola H505 Bluetooth Pairing - pass code
try typing 0000 for the pass code
Posted on Dec 30, 2008
  • 11 Answers
SOURCE: Pass code for verizon bluetooth
It should be 0000, unless they changed the code
Posted on Feb 27, 2009
Bluetooth in car not recognizing Droid 2 any more - worked fine but now does not
your limit would have crossed
there are a particular no of devices that could be paired
Pair your Verizon Motorola Droid 2 smartphone with a Bluetooth device using these steps:
1. From the Home screen tap Menu > Settings app.
2. Tap Wireless & networks.
3. Tap Bluetooth settings.
4. Ensure that Bluetooth is checked.
5. Turn the Bluetooth device on and set it to discoverable if required.
6. Tap Scan for devices.
7. The Droid 2 should locate any devices in the area. You may need to enter a password. Most devices have a password of 0000 (four zeros).
The Bluetooth indicator should now show in the notification area. This indicates you are paired successfully.
Feb 24, 2012 | Motorola Mobility Droid (2 GB) Cell Phone
Have new Samsung Alias 2 that won't pair to my motorola car bluetooth, motorola bluetooth ear piece nor newer jabra car bluetooth. Did pair to Magellan GPS bluetooth, but voice transmission garbled. Any...
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Oct 05, 2009 | Verizon Communications Samsung Alias Cell...
Im trying to pair my verizon cell phone to my motoral headset
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | Motorola Mobility Bluetooth Hands Free...
Bluetooth pairing
Nov 25, 2008 | Motorola Mobility HS850 Consumer Headset
Bluetooth to mobile pairing
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done
Jan 05, 2008 | OEM Systems Bluetooth Headsets - Model...
Blue Tooth Stereo Headphones and KRZR
From what I can tell and after researching the same issue it is the KRZR. I called both Verizon tech support and my bluetooth tech support.
There is no solution
If you notice some of the functions in the Blue tooth Pairing/connection menu functions don't even work. (The on off for instance and the settings) After it is paired. I tried my bluetooth with other phones and it works fine.
I am going to the Verizon store to complain untill i get a different model.
In short the KRZR software is defective
Dec 26, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Krzr k1m won't connect to bluetooth device
Turn off the phone. Remove the micro-sd card. Restart phone. It should connect now.
Nov 22, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Bluetooth headset
you need to turn on the headset and to order the phone to search for BT devices.
May 19, 2007 | Motorola Mobility RAZR V3
Headset will not pair up eith razr phone.
Have you pressed and held the button on headset until light is always on, as this is in pairing mode, then search devices with your phone.
Jan 15, 2007 | Motorola Mobility HS820 Consumer Headset
Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
35 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
