Question about Lexmark X5470 All-In-One InkJet Printer
X 5470 Memory Card not being recognized by my computer
For over a year the memory card has been read by the computer.
Today for some unknown reason the Lexmark Imaging Studio does not recognize the memory card..
Any advice is greatly appreciated..
Thanks
  • jbngal Nov 29, 2008
    Thanks for the help...
    Happy Holidays..
    Problem Solver:
  • 5 Answers
First restart your computer. Double check if your memory card is locked, this is the little switch thingy on the side of it, it should say lock somewhere near it, slide it to the part not marked lock. If this doesn't help go to your start bar, click control panel, go to printers and other hardware, click on the memory card you are trying to recognize. Then it should give you some options on what to do with it and one should be load to your standard Lexmark Imaging Studio. I hope this helps!
Posted on Nov 28, 2008
    Master:
  • 461 Answers
Try the memory card in another reader if possible and also try another card to isolate the problem. The card could have failed or there could be a problem with the reader or internally in the printer.
SD reads Memory error locked in camera and computer will not recognize SD chip. Other SD memory chips are recognized by computer. Have moved lock switch up and down and is not in locked position.
Is it a newer 4GB or larger SDHC card, and are you trying to use it in an older (4 years or older) camera? If so, that's your problem. SDHC format only came out a few years back, and older cameras can not recognize them. You'd need to use 2GB or less standard SD cards only. Fortunately, these are very inexpensive these days, and widely available on Amazon if your local stores no longer carry them.
Sep 21, 2011 | SanDisk 2GB microSD Memory Card
Sgh s3310 memory card not recorized ple solution
Hi hitendra_sin,
Try these steps:
Remove memory card and plug it to computer via card reader and check if it is able to reade the details
If it is successfully read by the computer, then take a back up of entire memory card.
Then format the entire memory card.
Check if it is recognized. If recognized, remove and plug it back to computer and copy only the required file to memory card like music, pictures and videos.
If not recognized, you will loose the data, try reformatting the memory card and use as new.
This should work.
Thank you
gowtam1402@live.com
091-9916828137
Jan 02, 2011 | O2 Samsung SGH-E250 Cellular Phone
When I put the memory card in the camera it says 'cannot read' it. How do I format the card? I know it has the right 'size' memory. The memory card I am using is the same one I used a few months ago and I...
Do not use the computer to erase the card. This is the reason your camera no longer recognizes the card. Now you need to format the card in the camera to get it to work properly.
Oct 07, 2009 | Cameras
Memory Card locked
this solution is from a another website about card error... i dunno if this will help fix ur problem but i hope this will give u idea how to fix it... okay.. tell me if this works, coz a lot of people were encountering the same prob as u.. thank God i havent encounter this error...good luck..
Troubleshoot:
Memory card is used by digital camera to store the photos it takes. Popular memory cards include SD card, CF card, xD-Picture card and Memory stick. For some reasons, memory card may get damaged on power shortage, or removal of memory card on picture shooting or viewing, or other various and unknown reasons. Usually, you will see error message like "memory card error", "card locked", "card error", or an error code on your camera screen and the valuable pictures on the memory card could disappear and be lost. Some cases, your camera or Windows may prompt you to re-format the memory card and refuse to take new pictures or view old pictures.
Solution:
Once you have your memory card damaged, it is highly recommended to stop further operations on the memory card (e.g. taking new pictures, or delete, format the memory card). Data recovery software like "CardRecovery" is able to recover the lost pictures in most cases.
First, you need to confirm your memory card can appear as a drive letter in "My Computer", which will allow recovery software to access and recover the lost photos. You may try to connect your digital camera to your computer, if a new drive letter appears in "My Computer", it is OK. Otherwise, you need to prepare a USB card reader. There are many card readers available in market (e.g. SanDisk and Kingston). You can buy one from Amazon or BestBuy.
Then, you may download and install CardRecovery to your computer. Launch it from Start Menu -> Programs -> CardRecovery. You select the drive letter of your memory card, and destination folder for save the recovered files. CardRecovery will scan your memory card and locate the recoverable pictures. The process is quick and easy. Usually it takes less than 15 minutes.
Can I re-use the corrupted memory card?
For data protection, CardRecovery performs read only operation on your memory card and it does not change the data on the memory card, so it does not repair or fix the memory card. If you need, AFTER you have recovered your lost photos from the card, you may try to format the memory card before re-use. It is suggested to perform enough read/write test before using it again to take new pictures. If you are worrying that the memory card is unstable and may cause further data loss, purchase and use a new memory card. Your valuable and irreplaceable photos are more important than memory card. Memory card is very cheap. A new 2GB SD, CF or xD card is less than $10.
credits: www.cardrecovery.com
Sep 13, 2009 | Canon PowerShot A75 Digital Camera
Computer won't read my memory card
Hello. Regarding your problem first you have to consider the compatibility of your memory card in your computer cause not all memory card supported by computer. Other memory card need to install their device driver in order to recognize by the system that you are currently using. Therefore my recommendation, try to check first if the your memory card reader evice is recognize by the system/computer then check also the memory card itself maybe their something wrong with your memory card and if you find out that the memory card of your's have the problem then return it to the supplier.
Jun 15, 2009 | PNY Optima Pro 2GB Secure Digital Memory...
PSP not reading Memeory Stick.
If it is not a psp memory stick,or a compatible psp memory stick,IT will not work.Most memory sticks are not compatible with the psp.
Please take time to rate this fixya
May 12, 2009 | Sony PlayStation Portable (PSP) Console
How to recover datas from corrupted N72 memory card
You may try this mobile phone recovery software named asoftech data recovery which helped me before. You can download trial for free
http://www.asoftech.com/adr/
Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
Apr 24, 2009 | Nokia N72 Cellular Phone
Memory card on Lexmark X5470 not being recognized by my computer
Karen,
Sounds like your card may have went bad. A good way to check this would be to use a different memory card. Hope that helps! Good luck!
Sincerely,
Jeremiah
Dec 28, 2017 | Lexmark X5470 All-In-One InkJet Printer
Memory card not reading in camera
look into the camera with a bright light and see if any pins are bent where the memory card goes in. also check to see if the card is unlocked and check the card to see if it works in another device.
Mar 06, 2007 | Canon PowerShot A75 Digital Camera
Lexmark X5470 All-In-One InkJet Printer Logo
70 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
