Power supply for l1975nw
Http://nfm.partsearch.com/GetModel.aspx?MfgName=Westinghouse+Digital+Electroni&BrandName=Westinghouse+Digital&ModelNumber=L1975NW&SortBy=brandname&sortdirection=asc&page=1
my backlight went out too. changed a couple of caps still no luck so I'm ordering one myself
    Problem Solver:
  • 11 Answers
A new PSU (Power Supply Unit) will need to be reinstalled, one you reinstall a new PSU your problem will be resolved.
Posted on Dec 05, 2008
My screen symtoms are a little different on my L1975NW.
I am guessing the LED power indicator blinks green then becomes steady when the screen "turns on" (shows video). The problem is most likely a failing backlight power supply. That's why there is a 30 minute delay. Try to disable sleep mode and see whether that helps.
Aug 30, 2012 | Westinghouse L1975NW Monitor
Installed new 27-D01567 power supply unit in my 19" monitor L1975nw. have green light but black screen. whats next?
Is the board brand new or used? You will need to verify the voltage (12~18vdc) feeding the inverter circuits, there is also a surface mounted fuse.
Try reading here:
http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/#step1
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 05, 2010 | Westinghouse LCM-19v5 Monitor
I have the Westinghouse L1975NW
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Notes: When the caps went out, it may have raken out the fuse and the MOSFET in the inverter circuits with it also. http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/
May 23, 2010 | Westinghouse L1975NW Monitor
L1975NW Monitor: My monitor is very dark; too dark to even see how ...
More likely the backlight is not on, check the caps (leaking/bulging tops) in the power supply first, then check the fuse in the inverter circuits, when the caps went out it may have taken out the MOSFET for the inverter transformer with it. See failed WESTINGHOUSE and other monitors due to bad caps.
May 16, 2010 | Westinghouse L1975NW Monitor
Whats up with my monitor?
You have a failure in the backlight power supply. We have an article posted on our web site explaining how to repair this problem: http://www.ccl-la.com/blog/index.php/westinghouse-l1975nw-repair/ The Acer AL1916W uses the same power board as the Westinghouse L1975NW monitor. If you don't want to do the repair yourself we do offfer a repair service for $30 plus shipping.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | Acer AL1916W 19" LCD Monitor
The color is incorrect on my L1975NW (Westinghouse) widescreen
Try hooking it up to other PC to see if it does the same thing.
Try another VGA cable.
If none of above change the symptom then open it up and inspect the caps in the power supply, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 01, 2010 | Computers & Internet
Goes dark for 5 to 10 second for no apparent reason?
Look for bad caps in the power supply, it will get worst and can take out the inverter fuse and the MOSFET.
Feb 10, 2010 | Westinghouse L1975NW Monitor
Resistors burnt on power supply board on L1975NW lcd monitor looking for that power supply board
This monitor has common problem with caps went bad and it will take out the fure and MOSFET in the inverter circuit. Do you know which resistor is burnt out? I usually only have to replace the caps, MOSFET, and the fuse.
Jan 07, 2010 | Computers & Internet
Monitor is blank but green lightis on L1975NW
LCD Display/ control board Defective, send to repair
Dec 28, 2009 | Westinghouse L1975NW Monitor
Computers & Internet Logo
153 people viewed this question
David Payne
David Payne
