Question about Kodak EASYSHARE M763 Digital Camera
Back screen will not show anything
The camera was left in the car in a purse all day and it probably reached a temp of 120 degrees and now the rear screen either does not turn on or it just stays black. please give me advise or tell me where i can send it, it is only one year old
    Problem Solver:
  • 15 Answers
Try to do this.
1. Turn the camera off.
2. Take out the batteries and wait about 10 seconds.
3. Replace the batteries with new or freshly charged batteries.
4. Remove the memory card from the camera.
5. Turn the camera back on.
If this does resolve the issue, you will need to send the camera in for repair. go to www.kodak.com/go/itg to set up repair
Posted on Dec 05, 2008
2003 Audi A6 temp goes to 120 overheats then down to 90 and oil symbols comes also
I would check the thermostat first. Remove the thermostat and place it in a pan of water on the stove. Place a thermometer in the water with the thermostat and slowly increase the temperature until you have reached 194 degrees Fahrenheit or 90 degrees Celsius. Watch closely for the thermostat to open slightly. If it opens then the thermostat is good. If it does not open, replace it. Try that first and see what you come up with.
Aug 13, 2014 | 2003 Audi A6
Engine only reaches temperature after I turn it off
please check if cooling fans are running all the time- only should come on when engine temp reaches fan temp setting- google it for exact temp
Feb 21, 2014 | 1994 Chevrolet Suburban
The oven will pre heat to set temp, then when it reaches temp the oven beeps and both oven elements turn off. At this point the control panel (clock LED) shows an F2 error.
Good afternoon.
F2 for hotpoint means oven temp sensor thinks oven exceeded 650 degrees .Did that happen?
Probably not so have your sensor checked or replaced. It should be a probe device in oven back wall.
Was this helpful?
Aug 16, 2011 | Hotpoint RB787 Electric Kitchen Range
Frymaster will not re-light after reaching temp on initial start
You have a lazy thermostat that needs replacing. Not uncommon.
Tom
May 21, 2010 | Frymaster Dean FM345EETC Deep Fryer
Freezer defrost cycle
If the defrost timer sticks in the defrost mode,yes. Normal defrost time is 30 minutes or less depending upon which timer is installed.
If it happens again,locate the defrost timer and turn the dial manually to see if the compressor comes back on. If so,replace the timer.
It is probably on the rear near the compressor. Some are under the front behind the dust guard.
Feb 24, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
Tried resetting the thermostat. Shows 70 degrees for a second. Then back to 78.5 degrees. When I use the arrow adjust to change settings the number does not change
Depends on your Tstat. The set point is different from room temp. My tsat show set point and room temp. But to answer you when you set at 72 and room temp is 75 . It will go back to room temp till you reach that temp. Rusty
Jun 07, 2009 | Heating & Cooling
Coffee spill
take some rubbing alchol . i mean remove the battery from the camar frist take a soft cloth pour. some rubbing alchol on it where it drippingand soak the back side of the camera let dry for a day or so then try it
Jan 14, 2009 | Nikon COOLPIX L3 Digital Camera
Blank LCD Screen
Does it still take pictures and you can see them by downloading them to a PC? If so, your LCD screen is probably bad and will need to be replaced. I have replaced these before, its not hard to do if you can purchase a replacement screen.
- Jim
Feb 10, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
My camera display screen is only showing weird colors but works when I take pictures
A loose connection perhaps
A gentle taspe may restore it - or it may not.
Canon support will advise on your next move
Sep 14, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Had camera in purse?!?!
you can buy a new screen and have that installed but it will be at least 60 bucks... check out ebay
Jul 29, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Kodak EASYSHARE M763 Digital Camera Logo
94 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
