Question about Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side by Side Refrigerator (White) (GS 6SHAXLQ, GS-6SHAXLQ)
Whirlpool icemaker Icemaker not working: changed power head at icemaker and changed water sylenoid. Still no ice. How can i check the wiring and door sensors to make sure they are working? Seems like its stuck in its sequence waiting to charge water. (Water line is clear) Fridge is a whirlpool model GS6SHAXLQ0
  • Anonymous Nov 02, 2007
    ice maker does not dispense water. all else works. checked all micro switches and all ok. checked water valve and is ok.
    Now what?
  • boomer jr Nov 15, 2007
    i have a roper side by side model RS25AGXNQO1. Ice maker isn't working it gets water to the filter then back to the pump i guess but no water to where it goes into the icemaker at back of fridge.
I changed the filter and it stopped making ice. I finally discovered that the rubber fill spout had frozen somehow. I heated the tube with my wife's hair dryer and the top of the fridge just above the tube. A pencil sized chunk of ice fell out of the tube and it started making ice again.
Posted on Feb 04, 2008
  • 237 Answers
Good troubleshooting, the motor module (power head I guess you call it) is a high failure item. If you can manually fire the solenoid and get water to the Ice Maker then that's OK. Another item can be the t-stat at the ice maker, it must be "closed" at 15-17 degrees F. or it won't send power to the motor module. There may be a schematic under the front of the fridge in a plastic holder stuck up underneath. Sometimes it's just tech notes but some show the basic wiring diagram.
Posted on Jan 17, 2007
Whirlpool side by side with water and icemaker. My water works perfectly fine but my ice maker no longer produces ice. It runs but it's not getting any water to make ice. What can be done to fix this?
There are a couple reasons your icemaker will not fill with water.
First thing you want to check for is a frozen fill tube to the icemaker. The easiest way to check for a frozen line is to remove the icemaker. Once the icemaker is removed look for ice in the fill tube. If there is ice in the tube the (water valve) will need to be replaced. You can melt the ice by forcing hot water up the fill tube.
Another reason could be the icemaker is not sending voltage to the water valve. The fix for this issue is to replace the icemaker. Hope this helps you with your whirlpool fridge!
The reason to change the water valve with a frozen water line is because the solenoid is not closing all the way. This allows water to enter the fill tube of the icemaker and freeze based on the temperature.
May 04, 2017 | Whirlpool Refrigerators
Ice maker doesn't work
Testing the ice maker:
As far as the smaller line (1/4") you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. For whirlpool and its subsidaries,you can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked m and the other in the cicle marked n. Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. For GE, you turtn the ice maker off, wait about a minute then turn back on, water should automatically shoot water in the icemaker. That will tell you the water valve is good and icemaker is bad, or the ice maker is good and the valve is bad if no water. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Also check the fill tube to be sure the no ice is blocking water from coming in.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 17, 2012 | Kenmore Refrigerators
Frigidaire Superba Ice maker - no water flow
Jun 06, 2012 | KitchenAid Superba KSBS23IN Side by Side...
Icemaker stoped rotating
Note that the temperature in the freezer must be below 10 degrees F for the icemaker to cycle. The icemaker line is the smaller line (1/4") located in the back of the machine that runs from the valve to the filll tube. To test the valve and icemaker you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked "M" and the other in the cicle marked "N". Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Before doing any of the above though check the fill tube to be sure the no ice is blocking water from coming in.
Jun 04, 2012 | Whirlpool Refrigerators
I have a whirlpool side by side w/ice and water thru the door.model#ED5JHEXTQ00.WATER THRU THE DOOR WORKS FINE BUT WILL NOT FILL ICE MAKER.ANY SUGGESTIONS ?...
Jun 03, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
No ice is coming out of ice maker
  1. Whirlpool Icemaker Repair Guide ... guide I will walk you through the steps in a whirlpool icemaker not making ice. ... when you do this water does enter the icemaker take that jumper wire and place ...www.appliance-repair-it.com/Whirlpool-icemaker-repair.html - Cached
Dec 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker isn't making ice, but the water works just fine.
switch the wires on the water valve (it has two plugs) and depress the water lever and see if the icemaker fills with water, if it does, change the icemaker, if it doesn't change the water valve. make sure there is no ice obstruction in the fill tube in the freezer
Oct 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Why is the ice maker not droping ice / Mod. ET1FTTXKQ00 / Type C21TFA01 Whirlpool 08-01
Take a 4 inch piece of 14 gauge insulated wire and strip 1 inch of insulation off each end. Bend the wire into a U shape.Remove the plastic cover from the front of the icemaker. Insert the bare ends into the terminals marked T and H on the face of the icemaker. The wheel should move and dispense the ice into the bucket. If it does not move and drop the ice replace the icemaker.
Aug 30, 2009 | Whirlpool Refrigerators
Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Jan 25, 2009 | Whirlpool ED5SHAXM Side by Side...
Whirlpool icemaker
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side by Side Refrigerator (White) (GS 6SHAXLQ, GS-6SHAXLQ) Logo
297 people viewed this question
Top Whirlpool Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
