Question about Dometic RM2652 Refrigerator
Unit will not restart and keep unit cold when camping in cold tem
On propane, the unit initially cools, then when camping in cold weather, it does not restart to keep the freezer as cold as it should...nor the fridge. Why should the outside temp hinder the working of the unit?
  • 121 Answers
Freon contract in cold wheather
Posted on Nov 29, 2008
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Ice forming
  • One cause of this is the compressor is going bad or Freon is low. The freezer is no longer able to achieve the zero temperature requiring the compressor to run continually. The refrigerator because of the continues running begins to freeze up. Food in the refrigerator begins to freeze and the freezer is not as cold as it should. This results in a very expensive repair of replacement of the unit .
  • The defrost cycle is not working. Depending on the conditions the unit has a sensor that detects when the defrost cycle should initiate. If this fails to occur than ice builds up on the coils and air can no longer pass preventing the normal cooling process. Many models use a mechanical timer that stops. On some units the defrost cycle can be initiated via advancing the mechanical timer. This repair is a reasonable expense.
  • The third possibility is a door was left open and the unit iced up the cooling coils. Suggest in that case shut off the unit , remove the food and allow the unit to manually defrost, Restart and see if unit gets cold and defrost cycle is working.
Nov 22, 2015 | Refrigerators
Hi,i have chescold rt50 fridge freezer,older model,colourbond brown colour,recently i have replaced the 240v element and the fridge work perfect again,at last camping trip i used on gas and work icy...
try disconnecting thermistor let run if cold replace thermistor if not bad board or cooling unit look for yellow stains on cooling unit or if you smell ammonia
Oct 13, 2017 | Dometic Refrigerators
My Samsung RB1855SW refridgerator not cooling
You may just be catching the unit during normal defrost cycles. Next time, allow the unit some time to complete it's needed task. If you allow it 30-minutes, it should restart on it's own. The cycles are necessary to keep the unit working properly. The cycles will be more frequent as the weather warms. If you allow the unit 30-minutes and it does not restart on it's own, then there could be a problem. You might consult the owners manual for more details.
Apr 06, 2010 | Samsung Refrigerators
Fujitsu AOU24CL fails to cool towards evening timeframe.
Hi Hal,
Yes the outdoor temperature is defintely affecting your ability to cool with this unit. I have had the same problem with some Mitsubishi units cooling server rooms in banks. Below 0 they don't want to work, the refrigerant shrinks to the point where the system thinks it has lost it's charge and shuts down.
The way to get around it is to either add more charge to the system, which will have to be removed in warmer weather. Not a fun thing to have to dotwice a year....
Or slide cardboard in front of part of the outdoor coil to raise the head pressure slightly... this will also have to be removed in warmer weather to keep the head pressure down enough in warm weather. It is kinda like the truck drivers do to get heat in the cold weather. Only you want to stop some of the heat from escaping and lowering your pressure in your system too much.Partially boxing in the whole unit will also work. A lot of grocery stores will partially box in all of their units in very cold weather...
You will need to see what is the best fix for you, but you have some things you can try now...
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 10, 2009 | Heating & Cooling
Camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
May 15, 2009 | Dometic WA3210 Compact Refrigerator
Dometic fridge 'check' light keeps coming on...won't cool
Yes , the check light is there to tell you that your out of gas yes this is true but the device which switches to power is not changing over which will not let the heaters work and will not start the process of cooling, I suggest to inspect the switch and ensure that this is the case first before consulting a mechanic.
May 11, 2009 | Dometic RM2652 Refrigerator
My ducted heating continually blows cold air thru
Well, if need be, turn the breaker off. Turn it on when you need heat. Sounds like the fan relay is sticking or something if that sort. Is the tstat fan selector on auto?
Jun 17, 2017 | Heating & Cooling
Patio Heater SRPH02 will not light in cold weather
you may need someone to come in and adjust your pressure regulator that is inline to heater this is what controls the output of propane and should only be adjusted by a pro
Apr 15, 2009 | Coleman 5040-751 BackHome Open Flame Patio...
Dometic RM2652 Refrigerator Logo
230 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
