Question about Estate TEDS840JQ Electric Dryer
Estate Dryer 840 jq2 takes forever to dry our clothes.....
We love our Estate Dryer. It's about 4 yrs old. Recently, it takes about an hour and a half to dry our clothes. We've done all the usual things, cleaned the vent, blown the vent tube up thru the roof, taken the back off to see if the heating element heats, cleaned out the lint trap......don't know what else to try. We don't know whether it's worth calling in a repair person or just getting a new dryer.
Is the heating element supposed to cycle off and on or is it supposed to stay on the whole time?
Anything you can suggest we try is well appreciated.
Thanks.
  • 1 more comment
  • mbecker0601 Nov 28, 2008
    The dryer is electric and it definitely runs, so I think the outlet is good. We've unhooked, unkinked and blown thru everything we can think of....
  • daldieri82 Dec 31, 2008
    I have the same problem with the same model. The clothes take forever to dry. It does not seem that they are getting hot. Also cleaned out the vent and the airflow from the outside vent seems fine.
    Will be calling repair service soon.
  • lucky05mom Jan 20, 2009
    I have the same problem! It takes for ever to dry even a smaller load. I have cleaned everything out. I have replaced the hose that vents out. I notice that the heat element does not stay on for the entire cycle. Maybe on for about 3 min then turns off. Now the fan on the bottom in the back, it started making a terrible grinding sound & poof the entire dryer shuts down. Maybe this is a lemon brand.
  • 659 Answers
The heating element usually stays on while drying it is possible the thermal device that turns on and off the element might be working incorrectly and turning the element off too soon
Posted on Nov 29, 2008
    Sergeant:
    Champion:
  • 311 Answers
Is outlet holding plug good and tight (assuming this is electric as you say heating element). I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
Dryer has started to take longer to dry clothes only 3 yrs old, any reason why this could be happening. A load used to dry in roughly 30 minutes now can take up to an hour.
I would check your venting. If your venting is plugged up it will not be able to expel moisture properly causing long dry times. Feel the airflow outside if its not strong then thats your problem. Good luck.
_MJ_
Dec 15, 2010 | Estate EED4100SQ Electric Dryer
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
Dryer heats up ands pins, but it takes forever to
Hi, First thing to check is the 4" venting to the outside. Make sure it is free of any lint and that there are no kinks in the hose. If this is a gas dryer, the couls on top if the gas valve could be getting over heated and not opening the gas valve later in the cycle so there will be no heat.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 15, 2009 | Dryers
Not drying properly
The heater coils or going bad. It has two wire rings that heat up. One has bunt out.
Jan 16, 2009 | GE DBSR453EBWW Electric Dryer
Hi, thanks in advance for your insight and experience. We have a 4 yr old estate dryer that we love. Recently, it just doesn't get the clothes dry without running it for about an hour and a half. We have...
the element cycles at high temp of around 155 and when it drops to around 85 it comes back on ,,, if it takes as mach as twice the time to dry it has to be in some of the venting ,,,, eather the hose behind the dryer was or is kinked or the venting going outside is part way stopped up / larry
Nov 28, 2008 | Dryers
NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
Jul 09, 2008 | Whirlpool GEW9200L Electric Dryer
Estate TEDS840JQ Electric Dryer Logo
234 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
