Question about Zenith A32B86R 32" TV
TV Screen Does not Display Entire Image
Television screen does not display entire image -- for example, sports scores and news ticker items are partially "cut off" (particularly on either side of screen). I've searched the menu for a corrective setting without any luck.
  • kimteele May 03, 2009
    I have the same problem and cant afford to have it looked at by a television guy, lol trying to figure out how I can do it myself. Any ideas?
    President:
  • 1,284 Answers
Most likely it has a horizontal width control on the inside of the set on the main module. It is usually to the right side of the set near the high voltage transformer. I advise caution unless you understand the operation of the tv and the components near the control.
Posted on Jan 30, 2007
Can I change any settings so FullScreen doesn't go outside the screen and cut off the image?
get the on screen menu up , then find aspect ratio and use the volume control buttons to change the ratio until the screen and picture match , click ok and exit
Dec 11, 2015 | Televison & Video
The image display on my Westinghouse 42" LED TV does not fit the screen. It is zoomed in, so when watching sports, i cannot see the score and time ticker.
Using the remote go to the menu for the TV. Look for picture or aspect ratio. Make sure it is set to 16:9 and not zoom or auto. That should clear the problem up.
May 15, 2012 | Westinghouse LD-4258 42 Class Widescreen...
Screen keeps t going blank but still have power
It may be the internal backlight that is failing. When the display has failed but still has power, take a flashlight and hold it close to the screen, move the flashlight all around the screen and check if you can see anything. The display will be dark, but you should be able to make out the image that is there with the flashlight technique. If you can see an image on-screen, then your backlight has failed and you will need to replace the monitor. Weather or not you see an image is not a critical issue, but a tool to verify if the backlight is off or some other issue is causing the problem.
Note, it may be difficult to detect an image on the un-light display, for example if you have a dark image as your desktop background. So make sure to fully scan your display (top to bottom, and left to right covering the entire screen) with the flashlight technique in order to see any image on-screen.
Mar 24, 2011 | Xerox XG-91D 19" LCD Monitor
Ticker along bottom of screen for news channels and sports channels is being cutoff along the bottom. That is, the ticker moves right to left and I can read it but the bottom 10-15% of the letters is...
I might need a little more detail to solve this problem - I suspect the problem is an incorrect setting on your cable/satellite receiver (assuming you are using one), but let's start with the TV.
Firstly, switch the TV on and select a channel where you can see the ticker. Then press the "FORMAT" button (above the red REC/CONNECT button) on your Mitsubishi remote control. This will change the screen aspect ratio and the current setting will be displayed on screen. Each time you press the FORMAT button the screen size should change.
The screen aspect ratio settings for your TV are STANDARD, EXPAND, ZOOM, STRETCHED and NARROW. Press the FORMAT button repeatedly until "STANDARD" is displayed on the screen. If the ticker is still cut off, you need to change the aspect ratio setting on your cable/satellite receiver.
Please note: If the TV will only allow you to select STANDARD, this is not a fault. It simply means that the aspect ratio cannot be changed on the TV because it's displaying a picture from an external source, i.e. a cable/satellite receiver.
You should then look for a button on the front of your cable/satellite receiver or the cable/satellite remote control marked "FORMAT" or "ZOOM". When you have located this button, try pressing it repeatedly until the ticker is both fully on the TV screen and the picture covers the entire screen.
If you don't have a FORMAT or ZOOM button for your cable/satellite receiver or you are unable to set the picture size correctly, leave the TV set to STANDARD and then reply to me with the brand and model number of your cable/satellite receiver. I will then be able to assist you with finding the correct picture settings and give instructions on how to set these correctly.
I hope this helps - please post back here if you need further assistance.
Regards,
BElectric
Jan 15, 2011 | Mitsubishi WS-73909 73" Rear Projection...
My Zenith C32V28 television does not display the top and bottom of the picture. I phoned Zenith tech support who told me that it was the satellite signal. I called the satellite provider who advised me it...
This is applicable to Bell Television Services (Canada)
I solved the problem myself after two calls to both Zenith and Bell Television satellite service. On the bottom left of the Bell remote control there is a * (STAR BUTTON). Press this * button and within two seconds you must press the channel change button up or down. This will do two things. One; it changes the channel; and also changes the ratio of the satellite signal. There are three satellite signal ratio settings. Try this when you are tuned to a TV channel such as BNN (Canada) (Business News) or The American channel which has a stock ticker usually displayed along the bottom of the TV screen. Select the ratio (setting) that allows the stock ticker to be displayed......hope this helps.........Jim McP
Nov 10, 2009 | Zenith C32V28 32" TV
My LCD TV has X-ray-like image on the half of the screen.
Looks like you have a bad Display Drive Board which drives the LCD display. Bad news is the Display Board is sold With the Panel.
Dec 19, 2008 | Sylvania 6626LCT 26 in. LCD Television
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
60" Phillips HDTV Rear Projection
You need new convergence ICs two of them numbers STK392-110 they are available at the following link and they provide free installation instructions with pictures as well as free online tech support while you do the repair which takes about an hour. Heres the link.
http://servicemanuals.vstore.ca/
Apr 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Image size too large, cannot see all of sports scores scrolling on the bottom
hey voiolentce. if you press the # button on the cablebox remote control you can fine tune the zoom by those 20 pixels you want. you are most likely set at zoom 1 currently. thats where i was when i had this same problem and it took me days to figure out that all i needed to do was press the damn # button. i couldnt see any of the scores on espn sports games and its been driving me crazy. hope this helps!
Sep 10, 2007 | RCA R52WM24 52" HDTV Projection Television
Televison & Video Logo
199 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
