I can't get the power to come on on my recently updated Gateaway 830GM. I replaced motherboard (Augsburg 915G), and power supply. I've heard that others have this same problem.
    Master:
  • 461 Answers
Verify all connections specifically the two power supply connectors. Disconnect and reconnect and verify they snap in place. Make sure RAM is properly seated.
Posted on Nov 28, 2008
Intel 102007 motherboard manual
get it from here...
http://www.ascendtech.us/gateway-augsburg-intel-915g-motherboard_spv_mb4gwaugsburg.aspx
best of luck!
Mar 07, 2012 | Computers & Internet
Can I upgrade to a Intel Pentium D 945 3.40ghz processor. Intel (Augsburg) 915G Motherboard
No, the Intel (Ausberg) 915G motherboard will not support dual core processors.
The Intel (Ausberg) 915G motherboard uses an Intel 915G motherboard chipset,
http://support.gateway.com/s/MOTHERBD/Intel2/102007/102007sp33.shtml
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4.2FPentium_D.2FPentium_EE_Chipsets
Supports only Single Core processors.
It isn't until the Intel 945G motherboard chipset, that Dual Core processors are supported.
[NOTE*
The Intel Celeron D is a Single Core processor.
The Intel Pentium D is a Dual Core processor,
Intel Celeron D,
http://en.wikipedia.org/wiki/Celeron_D#Celeron_D
"The Intel Celeron D processor works with the Intel 845 and 865 chipset families. The D suffix actually has no official designation, and does not indicate that these models are dual-core. It is used simply to distinguish this line of Celeron from the previous, lower performing Northwood and Willamette series, and also from the mobile series, the Celeron M (which also uses 3xx model numbers). Unlike the Pentium D, the Celeron D is not a dual core processor."
Intel Pentium D,
http://en.wikipedia.org/wiki/Intel_Pentium_D
Don't 'shoot the messenger'. I just state the facts.
Regards,
joecoolvette
Dec 10, 2010 | Computers & Internet
I have a gateway 831gm. it has an Intel (Augsburg) 915G Motherboard and a Pentium 4 630 cpu 800MHz fsb & 2MB L2 cache. i've been looking for a cpu upgrade and saw that the Pentium E5200 Dual Core has...
If both motherboards are LGA775 socket, then the next concern is whether or not the case is capable of having the new motherboard installed into it. Disconnect all power cables to all dv drives or cd drives and hard drives. Disconnect all ribbons from drives to the mother board. If you can get to all of the screws that hold the motherboard into the case, you get away without removing drives. Once you've got the motherboard then you can disconnect the power cable from the motherboard. Remove the memory chips, disconnect the sound cable from the old motherboard. install the memory chips onto the new mobo, Connect the power cable to the new mobo, then install the new mobo into the case. Replace the ribbons from the drives to the mobo, replace the power cables to the drives and reinstall the sound cable to the cd or dv drive. You should be done now.
Dec 13, 2009 | Gateway 831GM PC Desktop
Gateway 507gr wont power on but looks like ps unit is good
Make sure you are plugging in your P.S. to Motherboard properly. This can happen if you are off by one pin on a 20 pin Supply on a 24 pin Motherboard. If you never opened the case and it just started happening, maybe one of your cards came out of its slot or your CPU Fan is not running.
Nov 06, 2009 | Gateway 507GR PC Desktop
Need new motherboard for Gateway 830GM
Looks like you have a p4 478 socket with ddr memory bad luck they only make 478 boards with ddr2 memory now. And when ever the power supply is as old as the motherboard it should be replaced to. Here's the specs I found on your computer http://www.shopping.com/xPF-Gateway-830GM. You could always try your luck on ebay good luck.
Jul 11, 2009 | Gateway 830GM PC Desktop
All wires are connected but still nothing comes up on the monitor
are you familiar into the parts inside.?
if not, i will not advised you t do this.
-inside you can see the memory strip/module, resit it again on the slot.
if you are using an external video card, better to resit it too.
let me know.
Feb 17, 2009 | Gateway 830GM PC Desktop
Motherboard wiring
cba3c97.jpgthis is the diagram for 103390 Intel (Augsburg) 915G
Jan 06, 2009 | Gateway 830GM PC Desktop
Need sequence for HDD LED, POWER LED, and POWER SW
The front panel header is on right the corner of the motherboard
if yu hhave the desktop laying down and the front bezel to you right and the back of the unit to your left. Here is a pictur which will give you reference on how to make the connections.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 28, 2008 | Gateway 830GM PC Desktop
Computers & Internet Logo
131 people viewed this question
Alun Cox
David Payne
David Payne
