Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
How do I replace the TV tube in my Sony Wega 36" flat screen?
I'm getting the 4 quick red blinks.
    Genius:
  • 1,139 Answers
Hello jmdady,
First I would like to say that this procedure is dangerous, and should only be done by a qualified Television Technician.
With that being said here is how I would do it:
1) unplug TV and remove the back panel of the TV set.
2) discharge the anode voltage of the CRT by using a screwdriver attached to a clip lead which is attached to the ground of the TV.
3) Remove the chassis of the TV as per the instructions found in the service data (you will need to buy the schematic diagram and the service data sheets for this set)
4) with the chassis removed and the HV anode removed from the CRT, lay the TV face down on a soft surface (a folded towel or a large foam pad).
5) Remove the yoke transformer and the convergence rings by releasing the holder ring and slowly moving the assembly up on the neck of the CRT until the whole assembly is free.
6) Unscrew the 4 retaining brackets and remove the retaining assembly from around the tube (this includes the grounding straps
7) Once the retaining assembly is removed, pick the tube up by the sides (DO NOT USE THE NECK OF THE TUBE TO LIFT THE TUBE UP).
8) Once the old tube is out, put the new tube in its place.
9) Reinstall the retaining brackets and the grounding strap and screw the assembly back in place.
10) put the yoke transformer back on to the set, using the same spacers and mounting equipment but do not tighten the holder ring (you will need the yoke and color rings to the loose to adjust purity and convergence)
11) Reinstall the chassis as per the schematic, reconnect the HV anode, the CRT board, and the connections to the Yoke Transformer
12) At this point you will need a color pattern/bar generator, a mirror, and a lot of patience because you will need to adjust the yoke on the TV and adjust color purity, and convergence (Read the schematic as to the recommended signal levels, and patterns to use).
This is the procedure I would use. Now I suggest that you have a qualified TV technician do this because there are certain dangers involved in this procedure. THIS IS NOT SOMETHING YOU SHOULD TRY TO DO YOURSELF.
I hope this helps,
Thank you,
Shuttle83,
Http://www.electron-age-technologies-llc.com
Posted on Dec 07, 2008
Sony kdf50e2000 will not stay on red light blinks 4 times
No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Mar 03, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have " Sony FD Trinitron WEGA KV-36HS420 36" TV
U have a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?Can u do basic soldering and uderstand basic electronic?FBT- the flyback transformer,the big black block of a plastic with a red wire with a cap hook to a CRT-tv picture tube.Near the big block of a plastic with a red wire with a cap hook to a CRT picture tube.Inside to the right of the FBT,there are 2 power supply ICS,those 2 ICS are dead.Replaced these 2 power supply ICS near the FBT,will solved this tv LED power light indication blinking and will have stable tv power again,and tv will work.
Nov 29, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Trinitron Wega TV keeps shutting off and red
There are two Ic's that need replacing on the Deflection Board (D) board.. These regulate power for the High Voltage and Chopper PWM circuits. The IC location on the board are IC6501 and IC8002
Nov 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Attempted to turn the tv on, screen stayed blank with no volume either and standby light blinks 16 times.
High voltage is dead,FBT,flyback transformer the cause.The big block of plastic with a red wire with a cap hook to a CRT(tv tube).
Nov 04, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My 32'' sony wega blinks 5 times
The 5 blinks means a problem in the set's AKB (auto kine-bias) circuit. Sony TV's monitor the operation of the picture tube. When some kind of trouble has been detected, the TV blanks the screen and flashes the 5 blink error code. This may be due to problems in the video circuit, a bad picture tube, or adjustments that have changed due to aging of parts. There isn't anything I can suggest you try on your own to fix it. Because several things may cause the problem, and the proper tools and service information needed to troubleshoot, you should refer this repair to a professional.
Feb 17, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Jan 01, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    SONY GRAND WEGA KDF55WF655
    tv turned off black screen and red light flashes 6 times over and over again
    Feb 28, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
    Tv stopped working
    HV problem. I'm sorry but there is a time for the TV dudes to come see everyone and this is your turn...accordianman
    Oct 10, 2007 | Sony FD Trinitron WEGA KV-36FV300 36" TV
    Color variation and blinking red light on bottom of tv
    The light flashing 5 times is normal at turn on as the set is monitoring current drain on the pictures tube cathodes. Any speakers near the set that have un-shielded magnets could possibly cause color issues.
    Apr 16, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
    Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
    125 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
