Question about Nokia 6220 classic Smartphone
Automatic key lock
Hiya, can't find in the menu of my new nokia 6220 the settings for automatic key lock, on other nokia's i was able to set it up for certain time to lock.. for example after 15 seconds.. any chance you could help on that please?
  • kashif_26_20 Jan 31, 2009
    i wan to down load the auto key lock softwerw for my nokia 7610 cellphone
  • Anonymous Mar 16, 2014
    do I have to go to settings each time I want to lock my phone? isn't there a way to have it lock automatically
Go to menu
then settings
then phone settings
then general
then security
then phone and sim card
then look for the 'Keypad autolock period' tab...
Hope this will solve your problem !
^_^
Posted on Apr 25, 2009
How to automatic keypad lock nokia e61i
Go to settings phone settings or security settings and choose automatic key lock
Apr 02, 2015 | Nokia Cell Phones
Nokia C6-00, I have disabled the Autokeyguard, still the phone is getting locked automatically at a very short interval.
Hi, there are two options for you to lock your cell phone under "Key Guard Settings", One is the "Automatic Key Guard" where you can set the delay time to lock the phone, and the other one is "Key Guard Code" where you can set a password every time you wish to unlock your phone. I think you have only disabled the Key Guard Code, please try turning OFF the Automatic Key Guard. I hope this helps.
Thanks for using FixYa.
Sep 08, 2011 | Cell Phones
How do I put a keypad lock code in my Nokia C7-00
Simply press the menu key and ash(*) key and the key pad will lock it self.
Or press the menu key, scroll to setting, press select key, scroll to phone setting, press select key, scroll to key guard setting, press select key, then you can now choose either theautomatic key guard or you want to use your on code.
When using the automatic keyguard, you specify the the seconds you want your phone to stay before being automatically locked up and presss ok.
Regards.
Jun 16, 2011 | Nokia Lands Phones
I forgot how to lock my keys , so I can carry my phone in my pocket & not have to worry about keys being pressed accidentily..Help?
Just press the menu key and after that press the * key..
Your phone will be locked..
You can also lock your phone using security code by searching through menu-->settings-->phone settings-->security code..
You can also check the automatic key guard option and select it to automatically lock the keyguard in stand by mode so every time you do not want to lock it manually..
To unlock the key guard do the same by pressing menu and * key..
The default code is 00000 or 12345
If you use a security code you need to give the code to unlock your phone..
Thank you for using fixya..
Please rate me on fixya to continue my future assistance..
Feb 04, 2011 | Nokia 1600 Cellular Phone
How do I unlock and lock my nokia 1209 keypad to avoid **** dialing?
hi,
press MENU then asterisk * and your phone will be locked..to unlocked it just repeat the procedure...if you want automatic locked of your phone do this....
*MENU
*SETTING
*PHONE SETTING
*KEYGUARD SETTINGS
*AUTOMATIC KEYGUARD
*you have option there ON and OFF ,select ON
now your phone is in automatic locked status ,even you forget to locked it ,it will be safe and avoid dialing...
i hope it will help you ,thanks for trusting fixya..
Jun 20, 2010 | Nokia Cell Phones
How to unlock nokia 2700c
Keypad lock
To prevent accidental key presses, select Menu, and press * within 3.5 seconds to lock
the keypad.
To unlock the keypad, select Unlock, and press * within 1.5 seconds. If
the security keyguard is on, enter the security code when requested.
To set the keypad to lock automatically after a preset time when the
phone is in the standby mode, select Menu > Settings > Phone >
Automatic keyguard > On.
To answer a call when the keypad is locked, press the call key. When you end or reject
the call, the keypad locks automatically.
When the device or keypad is locked, calls may be possible to the official emergency
number programmed into your device.
Jun 05, 2010 | Cell Phones
Cant access memory card messages in nokia 6220
Go to Menu >> Messaging
Press Options (Left Key)
Select Settings
Select "Other"
Under "Memory in use", choose Phone memory or your memory card.
Aug 28, 2009 | Nokia 6220 Cellular Phone
Automatically Press Keys
you have activated automatic key pad lock in u r phone disable it. you can find in settings menu
Jan 08, 2009 | Nokia 6080 Cellular Phone
Key pad lock and unlock Nokia 1200
My local Nokia Care Center provided the easy answer (which does not appear in the
owner's manual):
In the Menu, go to Settings, then select Phone settings, and activate "Keyguard Settings," and "Automatic." That done, you must select the time interval until the keypad self-locks. To unlock,
touch the "select" key (upper left key) and * (lower left). That combination also will relock the keypad.
Sep 11, 2008 | Cell Phones
How do you lock nokia 1208 when not in use
there are 3 ways to lock the keypad.
first there is a icon for settings. click on it and look for right side. with this you can stroll down and mark all of the features you would like for shortcuts. look for one with lock keypad. all you have to do is touch this and the keys would lock.
second, is look for keyguard and set it to automatic. this would automatically lock your keypad within a few seconds of not using it.
finally, you can touch the upper left key and the symbol *. this can only be done manually and if you perform the 2 step, this one is not needed
Jun 27, 2008 | Nokia 1100
Nokia 6220 classic Smartphone Logo
137 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
