Question about Toshiba 27AF43 27" TV
I have no remote for the tv, so I can't switch to video input to use my DVD player. Isn't there some way to get a menu which allows me to switch between tv and video input, right on the tv?
  • 75 Answers
Check the Toshiba website.  A replacement remote is $20 well-spent!
Posted on Nov 28, 2008
How do I program for playing DVD's on the TV?
If the tv has a built in dvd player, you should simply be able to put a dvd in the drive and the tv will auto-switch to the dvd player.
If you have an external dvd player, ensure it is plugged into the tv.
On the remote you should have a button that says either "Source" or "Video"
Press this button until the video input your dvd player is plugged into is highlighted, then press "OK" or "enter" (some tv remotes have one button that highlights and also selects the input)
You may also press the "Menu" button and check in the "video" section if your tv supports "Auto input switching" This will allow your tv to automatically switch to whichever device (dvd player, game console) is turned on while the tv is on.
Please provide make / model of tv and possibly dvd player for further help.
Nov 21, 2014 | Televison & Video
Isn't this just a simple hookup? What am I not doing?
You either need to change the input source. Currently the source is TV, depending on how you connected the DVD player to the TV, it should be composite (A/V), component video or HDMI. (S-video is also a possibility. Very few DVD players are connected on the RF (coax) input which might be channel 3 or 4 without having a converter between the DVD player and the TV.)
Look on your TV remote for a button marked Source or Input. You may also find this button on the TV. (On some TVs, this may also be accessed through the menus.)
How did you connect the TV and the DVD player? If your audio and video were connected via three RCA plugs (yellow, red, white) on each end, then use the composite video input. If you used cables with 3 RCA plugs for video (yellow, green, blue) and 2 for audio (red/white), then switch to the component input. If you used HDMI which carries audio and video in one cable (with rectangular ends), then use the HDMI input.
Some older TVs only have the Source/Input button on their original remote. Not all universal replacement remotes have this button, you may need a different remote. Those that do may require you to try additional codes for your TV manufacturer to enable the button. (The on./off buttons often will work with more of the codes for a brand.) The ones that can be programmed via a USB connection to a computer are most likely to support the function. Please add a comment with the type of TV for additional help with this.
I hope this helps.
Apr 21, 2012 | Sony Dvp-sr500h 1080p Upscaling Dvd Player
Auxillary channel for dvd
You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
May 17, 2009 | RCA Universal Remote Control
Cant switch tv to play my dvd player. no button on menu for this
If the tv remote has a input control button(video/antenna), you should be able to play your dvd thru this .
Apr 29, 2009 | Televison & Video
Hooking up & seeing a dvd player?
does the dvd have a coax output for coax antenna input on the tv? you can use that untill you can get the video input selection straight with the tv and a remote that supports rca's extra functions such as menu , tv/av button
or
also if there is a( wake-up) on/off timer in the tv menu , then you can also set it to come on with the video input instead of a tv station,set it a few minutes after the time it is when you set it( then just turn off the tv set after the time is set and you have exited the menu, then it will come on with the video input instead of a tv station)
otherwise you will need that remote that supports the video input selection on your tv
Jan 08, 2009 | RCA F20625 20" TV
Can't play dvd player on JVC tv; I don't have a JVC remote.
I hooked up a Pioneer DVD player to my TV and when I play a DVD the volume cannot be controlled by the TV. It just plays at one level and on the louder side. When I'm watching regular TV and the DVD player is on and playing a disc I start to hear the DVD soundtrack at the same time as the whatever I'm watching on TV. I should not be able to hear anything until I switch over to Video 1. Any suggestions?
Dec 31, 2008 | JVC AV-32F476 32 in. Television
I have a pensonic dvd player. it has sound but no video.
Check your Video connection from dvd player to TV.
Check your DVD player and see if you need to "activate" your video source or not by going to the setup menu.
Check your TV input to be sure you have switch the video input from your remote or manually on the tv.
Lastly,try another video input behind the tv,maybe your first video input does not work.
If you try both video inputs behind the tv, you might consider using a different video cable,you might have a defective video input UNLESS you are using HDMI cable,then nothing of the above steps will applied!
solutiondoct
Nov 11, 2008 | Televison & Video
RCA F25645 25in TV.
I have this same TV. The DVD player is either hooked up to the video or s-video input. Go to the Menu (either through the remote or from the front of the TV) and select the Setup option. Go to the part where it asks if you want to use a DVD player. Select yes. Then select Video Input. Exit the Setup. When you hit the DVD button, it will switch to the Video input. The second step is to go into the Menu and select Channel, then go to Video Input Source. From there, select which input you are using for your DVD player, the S-Video or the standard Video (yellow composite cable).
Mar 06, 2008 | RCA F25645 25" TV
Having trouble hooking up my DVD player
Try looking on your tv's menu for "input" or "input select". This should allow you to switch to your front AV inputs. If that doesn't work hook into the coaxial cable in the back of the set (the one for your cable or satellite input. Plug the cable from the output or to tv side of your reciever into the input of the dvd player and run another lenghth of coaxial cable from the output of the dvd player to the coaxial input where your satellite or cable was plugged into the back of your set. When you want to watch a DVD just turn on the DVD player and the picture should come up. When you turn it off your satellite or cable should come right back.
Feb 20, 2007 | Durabrand DWT1905 TV
No Video
From the manual (search Google for CM27101S): Normally, your TV displays the signal coming through the antenna terminal. However, If you?ve connected another component to your TV(such as a VCR) using the Video/Audio input, you will want to be able to view the signal from the component. To do this, you will need to switch from the ? TV ? input to the ? Line1, Line2 ? Input, as follows: 1 With the TV on, press the MENU button twice, then ? Set-Up ? menu will appear. 2 Use the WCHVbuttons to select ? Input ?. 3 Press the CVOLB buttons to change from ? TV ? to ? Line1, Line 2 ?. 4 Wait 10 seconds, or press the MENU button to return to normal TV viewing.
Aug 07, 2006 | RCA F27676BC TV
Toshiba 27AF43 27" TV Logo
300 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
