Macintosh G4 - grey screen with folder flashing question mark and face(s) upon start up...what do i do to fix?
Thanks guys...figured out my problem!
Posted on Nov 28, 2008
  • 162 Answers
Press and hold the letter C on boot. It'll then give you options where to boot, select the icon that looks like a harddrive.
  • 1,879 Answers
No boot media found (maybe changed)
or
computer locked
reboot mac, press "C" while starting up, it'll try to detect any available media to boot from.
I was using my I Book G4 when it stopped responding. I powered down and restarted. When it began restarting it went to a gray screen with a file folder in the middle of the screen. the file folder had a...
Hi ,
take out the battery for 5 minutes , this resets the computer , , if this does'nt work , put in a bootable disk and try to recover the system ...........let me know if this works , i can advise futher
Goodluck Roy
Aug 27, 2011 | Apple PowerBook G4 Mac Notebook
Hi! when im opening my g4, instead of the normal apple logo when light up, the screen will light up and turned dark and light up again with a small folder with a question mark and the finder icon...
Hi, this seems to be a problem with your hard disk. You see, when your mac displays the folder with a small question mark, it means that it doesn't find the operating system. You're lucky to be able to get to your desktop, because usually that folder means you'd have to reinstall everything again.
First of all, I strongly recommend that you copy everything that's important for you (i.e. your documents, pictures, music, etc.) elsewhere, it can be an external USB drive, you can burn it into a CD, etc.
Now, as I don't know what version of Mac OS X are you running (I'm going to assume that 10.4), it seems that your problem is that your computer doesn't know where the main operating system is. We can try and fix that by going to the Apple menu > System Preferences, then select Startup Disk and in there, select the hard drive icon that says "Mac OS X 10.4 on Macintosh HD". Now select reboot and see if its resolved.
If that didn't help, you'll have to contact a technician so he can replace your mac's hard drive. Please be sure to have a copy of all your important documents somewhere else.
--Dennis
Feb 27, 2011 | Apple iBook G4 Mac Notebook
My Powerbook G4 turns on light, fan, chime but no video.
Your hard drive has lost a file needed to start up the machine. The folder with the question mark means it cannot find a useable Operating system. I hope you backed up your files you needed becuase the only real way to recover the machine is to reinstall the OS from the install disk. You must format the Hard Drive from the format option on the install disk and reinstall the OS.
May 08, 2010 | Apple PowerBook G4 Mac Notebook
My mac powerbook is displaying a folder which flashes between a question mark and a icon in the middle of the folder it stays on the grey start up screen and doesnt start up any suggestion???
Your PB can't find the system. Most likely you hard drive is no longer working. To check that this is the case, start up from the discs that came with your computer.You will need to replace the hard drive then re-install the operating system off those discs. I hope you had a backup of your data!
Feb 21, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My powerbook G4 will not startup... All that appears on the screen when I try to turn on my computer is a tiny folder with a question mark on it. The mouse pad is nonresponsive.
Computer cannot find operating system files. Start up from Install Disk or Utility disk and re-install system. Hold down C key while starting from disk.
Aug 11, 2009 | Apple PowerBook G4 Mac Notebook
Can not get computer started
The flashing folder with a '?' means that the computer can't find the boot files. This may be that the hard drive has failed, boot files are damaged, or, that the drive is missing. In each case you will need to re-install the Mac OS. from the system disks.
May 27, 2009 | Apple Power Mac G4 Desktop
My powermac g4 startup problem - grey screen and folder+blinking
when booting immediately after the first chime before the grey screen hold down keys (apple,option,p,r) allow the computer to restart if it still goes to that blank screen restart again and this time hold down only the (option) key or maybe (option,s) on that model try option key first then select the main start up disk from the menu and click the arrow underneath
Apr 21, 2009 | Apple Computers & Internet
Grey screen folder icon flashing and alternating with ?
The computer can't find an operating system. Start up from the OSX disc and check the drive with 'Disk Utility'. The system may have got damaged, or the drive may need to be repaired. Run 'First Aid'.
Apr 10, 2009 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
Apple Macbook Pro was dropped. Will not boot. Screen is grey with flashing file folder with question mark inside. Thanks Dan
I believe that's a sign the HD is bad. However, I've not worked with the Apples in a very long time. (Remember the Macintosh Classic?)
Jan 09, 2009 | Computers & Internet
Apple g4 ibook 12' wont show o.s.
You probably need to reinstall the OS. That would be the best thing to do,so you would not have to mess with the data that is on the unit.
Sep 29, 2008 | Apple iBook Mac Notebook
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
