Question about Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher
Need installation instructions for a Bosch dishwasher with hidden controls, possibly SHX36L 12UC 24-in under counter dishwasher. It comes to me used with no instructions and the usual install makes it impossible to use the hidden controls. Thank you.
    Sergeant:
    Champion:
  • 311 Answers
Go to thermador.com to view manuals. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
Instruction manual for bosch exxcel dishwasher
Hello hazenchris
Please click the link below to download the user manual for the Bosch SRS45E02GB/18.
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=qcbpLlccdcso0pdmdb---03K&UMOBID=qcbpLnecdcso0pdmdb---03K
You will need to have Adobe Reader or another PDF file viewer installed on your PC to view the manual:
http://get.adobe.com/uk/reader/
If you need assistance with your Bosch dishwasher, please let me know.
Regards,
BElectric
Oct 17, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Don't understand the incomprehensible door and general installation instructions for the aqua star. Just uses pictures, anywhere available that uses WORDS?
  • 1 what you'll need
    Electric drill and hole cutting bit
    Screwdrivers
    Pliers
    Adjustable wrench
    Level
    Teflon pipe tape
    Drain pipe for dishwasher
    Dishwasher connection kit - available at your home store (should contain water supply line for dishwasher as well as necessary connectors and compression couplers).
    New dishwasher
  • 2Determine that you have access to the hot water supply line, the drainpipe and an electrical connection under the sink. Installing the dishwasher will require extending the hot water supply line to the dishwasher, connecting the dishwasher drain to the drainpipe under the sink, and plugging the dishwasher in. If your home was not plumbed in anticipation of a dishwasher, you will need to change some fittings under the sink to make these connections possible. (See below)
  • 3Read the instruction manual that comes with your new dishwasher. Installing a dishwasher is straightforward but you want to be sure you understand and are comfortable with the necessary steps.
  • 4
  • Thanks for using fixya.
  • Jul 19, 2011 | Bosch Dishwashers
    What holds the dishwasher under the counter top
    There are 2 screws that hold the dishwasher in place. To see the screws open the door all the way. Then bendover and look at the underside of your counter top. You will see the screws on both sides about 3 inches in from the sides.
    May 11, 2010 | Bosch 24 in. SHE43C05UC Stainless Steel...
    My Bosch dishwasher sounds like it is running but does not clean the dishes.
    check bottom of dishwasher screens for any blockages or obstruction preventing water from getting into pump. may need a wet vac to **** water out of pump and use a small mirror to inspect pump openings. if no obstruction, the pump impellor maybe broken. replacing the impellor is fairly difficult. the dishwasher has to be pulled from under the counter. repost if you further questions.
    Jan 10, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
    How do you adjust the height on a bosch dishwasher?
    The easiest way, is with an adjustable wrench. First, make it level in both directions, and then, back out the feet until it comes to the counter top. Screw to dishwasher into the under side of the counter after you have your hoses and electric routed.
    Nov 15, 2009 | Bosch 24 in. SMU40 Built-in Dishwasher
    How to replace electric motor
    take it out and turn it upside down outside and go from there. At the edge of the counter underneath should be 2 screws that fasten it to the counter
    Feb 26, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
    I have a bosch dishwasher classixx its less than a year old, the 'check water' light comes on and it doesn't complete the cycle. Water is left in the bottom unable to drain away. I have checked pipes as...
    if its less than a year old why dont you contact the manufacturers service team it will still be under guarantee as the bosch guarantee is 24 months
    you can dowload a copy of the instruction maual free of charge from the bosch or bsh home appliances web site
    Feb 21, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
    Securing Bosch SHU 4300 under "hard" countertops
    If this is a new Bosch Dishwasher then there should be two metal tabs that protrude from the top of the tub above the door. These tabs are for top mounting the dishwasher to a wood countertop, however these tabs also can be relocated to side mount the dishwasher to the cabinetry. The way to do this is to pull the dishwasher out of the hole it is in, in the counter (be careful not to pull too hard or to move the machine out too far due to the length of the water and electric lines). just pull it out easy till you can see the tabs, Now using a pair of pliers, bend the tabs on the backside of the mounts straight so you can remove them from the framing of the dishwasher. Next look at the tabs there should be a perforation where you can use 2 pairs of pliers to snap the tabs off at the perforation, after snapping off these tabs, look at the sides of the dishwasher and you will see a slot where you can reattach the tabs into, and bend the tabs in the back to hold them in place. If you look at the rubber gasket material on both sides of the machine - you can see where the round holes are located for side mounting. Attach the tabs and gently push the machine back into the cabinetry. Now using a small drill bit, drill a pilot hole into both sides of the cabinets to mount the dishwasher. You want to drill these pilot holes so as not to split the counter facing when you drill in the screws. Using the Bosch screws that came with the dishwasher (or small flat phillips screws) slowly screw in the screws into the sides of the cabinetry. When you attempt to remove the machine from the cabinetry you may find that it is adjusted tight to the countertop. If this is the case you will need to remove the 2 screws that hold the kickplate in at the bottom of the dishwasher in the front and remove the kickplate. Then you will need to bring up the front legs on both the left and the right and also the rear leg which is adjusted up and down by using a flat blade screwdriver. Look at the front of the dishwasher, behind the kickplate and there will be a adjusting screw with arrows which point left to right. the direction you turn this screw will determine which way the dishwasher will adjust,- right adjusts the machine higher and left lower. Good luck!!!!!! Hope this helps.
    Feb 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
    How do I replace the heating element for a Bosch SHU53 dishwasher
    are you sure its the element, the control boards on them get bad soldering joints and the you get the impression that the element is bad, but its the solder joint that controls the element that goes bad....you can resolder that
    Nov 24, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
    Hidden control panel not accessible on dishwasher
    no thats correct installeation of machine, its meant to be a "hidden" control. simply open the door, choose your options, press start and close door.
    Feb 28, 2008 | Dishwashers
    Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher Logo
    234 people viewed this question
    Top Bosch Dishwashers Experts
    Gerry Harvey
    Gerry Harvey
    Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
