Question about Philips Nike PSA220 MP3 Player
Player wont function ... at all
The MP3 player does not turn on and does not respond to a soft reset (by pusing volume up and the next button). I tried to resore it to the factory defaults and it appeared that it was restored... except that it will not turn on at all still. I tried plugging it into the charger and it says Problem please connect to computer.
I have the same problem all the time if you kinda jump start it by holding the power button(play) as you plug it in you can sometime get it to work
Posted on Jul 09, 2007
SOURCE:
I tried the reset button but it cant reset. it turns off at the welcome screen
Hi, there are two types of reset mode:
The soft rest,
And the hard reset.
soft reset by pressing the power button and volume up (+) button together. if It didn't work. you can do the hard reset.
hard reset by pressing the reset button (its a small hole next to usb connection socket) with a safety pin. It worked. Thankfully it does not delete any of the content on the device .
Have a nice day...
Feb 25, 2011 | Philips GOGEAR SA6045 MP3 Player
Sansa Express not responding and not turning on
Just to make sure you are doing the reset right, try these: First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
Jul 06, 2009 | SanDisk Sansa MP3 Player
My gogear is frozen. One song ended and before the next one started it froze and it has been like this for several hours. It doesn't respond to any of teh buttons being pushed
Try doing a soft reset. 1. Press and hold the Power on/off key and the volume + key for a couple of seconds. 2. Then switch on the GoGear using the Power on/off key. Note: Your songs and data will not be lost or corrupted by a soft reset. Update your players firmware to the latest version to reduce the chance of future hang-ups. (http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=NZ&slg=ENG&cat=MP3_PLAYERS_CA&sct=HDD_AUDIO_JUKEBOX_SU&session=20090608204052_67.190.4.112&grp=PORTABLE_ENTERTAINMENT_GR&ctn=HDD6320/01&mid=Link_Software&hlt=Link_Software)
Jun 09, 2009 | Philips GoGear HDD1830 MP3 Player
Philips mp4 wont turn on or take charge
This is a hardware-related issue, and several things could be wrong with the player - the battery could be bad, the usb port could be damaged, or the circuit could be damaged.
Before you go opening up your GoGear, call Philips and see if you are eligible for an in-warranty replacement.
There is only one "soft" fix you can try, but most likely it won't work:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
-Tha Mp3 Doctor
Mar 24, 2009 | Philips GOGEAR SA6045 MP3 Player
My GoGear 8G wont come on
1. On you computer, ensure that Philips Device Manager is running.
2. Turn your mp3 player on (it should freeze at the Loading or GoGear Screen).
3. Plug in the mp3 player to your USB/Charger cable (ensure it is connected to the USB port on your computer), and then perform a soft reset (Power switch down and Volume up button simultaneously).
4. Let go of the other buttons as soon as the player resets. Hold the Volume down button until the player comes on. The player will be recognized by Philips Device Manager and will report a problem (and will allow you to repair it). Windows will also recognize it as a Mass Storage Device.
edit:
video: http://video.google.com/videoplay?do...56814975105076
Jan 15, 2009 | Philips GoGear SA5285/37 Digital Media...
Phillips SA3025/37
Triple Reset for GoGear:
After repair is complete, upgrade the firmware for this player.
Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Jun 13, 2008 | Philips SA3125\02 MP3 Player
Cant switch it on!
This could be a hardware issue (requiring repalcement), but try the "soft" fixes first:
Make sure the lock slider is not in lock position, and then try turning the player on again. Connect to the computer, and see if you get any activity. If all else fails, try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Jun 08, 2008 | Philips GoGear HDD1830 MP3 Player
RCA Opal not responding
Make sure all of the songs are in the right format.
If they are, then reformat the player.
browny - headphone symptom is normal. For not turning on,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 01, 2008 | RCA OPAL M4001 MP3 Player
Craig mp3 player
Reset the Device
NOTE: THIS IS AN ADVANCED OPERATION. NORMAL USERS ARE NOT RECOMMENDED TO PERFORM THIS OPERATION!
Sansa e200 provides a Reset Function. Please note that you only need to use this function if the device does not respond for several minutes. The button is like a power down button of the device. You can turn off the device by using a reset operation, such as pressing and holding the Menu button for 15 seconds. Once you perform the reset function, the adjustments you made during last
30
Dec 27, 2007 | Philips GoGear HDD6330 MP3 Player
My mp3 wont respond to my computer!
Dec 16, 2006 | SanDisk Sansa m230 MP3 Player
Philips Nike PSA220 MP3 Player Logo
121 people viewed this question
Top Philips Nike Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Philips Nike Audio Player and Recorder Expert? Answer questions, earn points and help others
