Question about HP PhotoSmart C4280 Laser Printer
Need Help Adding a Printer
I have the HP c4280 all in one printer. It has been giving problems lately so i decided to delete the previous software and reinstall it again. I installed the driver and all in one software from the website. I am unable to print anything because i don't think this software was properly installed. When I check my printer and faxes folder it says there is only the generic/text only printer. I try to install it by clicking add printer from the options on the right, but no success. Is it possible that I may be going about this incorrectly?
  • trisjohn Nov 28, 2008
    I have tried solution number one and it was unsuccessful. Upon reconnecting the printer there was no prompt by the HP installation wizard.
  • trisjohn Dec 01, 2008
    I thank you for your help crichner. My printer is up and running now.
    Master:
  • 461 Answers
You do not use the Windows Add Printer option for HP printers. Reinstall using the HP installation CD or downloaded package and follow the instructions. The HP installation wizard should prompt you when to connect the printer.
Posted on Nov 28, 2008
  • Curtis Richner Nov 28, 2008
    The HP installation Wizard is the program you download from the HP website or runs from the HP Setup CD. Plugging in the printer will not trigger it to run.
  • Curtis Richner Dec 01, 2008
    Glad to help. Please share the steps you took to resolve the issue so that others may see.
I have an hp photosmart c4280 all in one printer. I have already installed the software two times..but when i click the hp solution center ,there is a dialog box that appears and inside of it is "no...
did your printer print correctly? If not...maybe the printer is installed on the wrong printer port, or there is a problem whit his USB interface. There is an option that your computer operating system is buged.
First of all try to install the HP on other PC to see that everything is OK. Then you have to look for software problems on your computer
Good luck.
pifonski
Feb 18, 2011 | HP Photosmart C4280 Aio Printer
Cant access hp solution center and no icon in right lower tray after installation, Also fatal error after installation???
download the latest software from www.hp.com/support and the run the application on the computer. first using the applications option uninstall the previous version of software. then go to c:\Program Files\HP and then delete the Digital Imaging folder. then go to COntrol Panel and then select the Programs option and then uninstall if there is any HP application installed.
Then type regedit on the run or on the search option. then navigate to HkLM\software\hp\ then delete the digital imaging folder.
then restart the computer and run the installation using the downloaded application
Nov 04, 2009 | HP Photosmart C4280 All-in-One InkJet...
C4280 HP PhotoSmart Printer, Copier, Scanner
Hi, click on the link below for your mac drivers and other supporting software that you will need for your printer. i would advise to save these important drivers your HDD and transfer them to a CD-R if possible.
CLICK HERE FOR YOUR DRIVERS
May 25, 2009 | HP Photosmart C4280 All-in-One InkJet...
HP C4280 Printer New Hardware found on system even when SW loaded
UNINSTALL ALL PREVIOUS SOFTWARE , UNPLUG PRINTER FROM COMP. THEN RESTART PLUG BACK IN AFTER LOADING SOFTWARE.
Dec 07, 2008 | HP Photosmart C4280 Aio Printer
Printer hp deskjet F380 All in one
Drivers, Software, lost C.D....come this way!
If you have lost you cd or don't know how to install your printer then all you need to do is download the drivers and software from the manufactures website that suits your operating system and printer.
Drivers and software download areas for brands listed below, just click to gain access and then locate driver for your needs.
 HP
PLEASE NOTE
When installing drivers/software it is generally a good practice to -
·                                 Delete old/previous installs
·                                 Leave printers USB cable disconnected from computer until newly installed software requests it to be connected.
Dec 06, 2008 | HP Photosmart C4280 Aio Printer
HP C4280 scanner problem
reinstalling the driver software onto your computer will fix this problem
Aug 26, 2008 | HP Photosmart C4280 Aio Printer
HP PhotoSmart C4280 Laser Printer Logo
Ben Johnson
