Question about Philips 13PT30L 13" TV
I have a magnavox model 25B800-7562. Audio works but no video.
When you turn on the tv a white horizontal line shines in the middle of the screen. Any assistance would be very much appreciated. Thanks
  • 4 Answers
This fault is known as frame collapse. Do not leave the tv on in this condition you will damage the screen. There is a fault in the field output stage, you will need an engineer.
Posted on Nov 28, 2008
Tv has horizontal line in middle of screen,sanyo ds25390
hi if only a horizontal line across with no video anymore, you have bad either vertical ic or no dc supply b+( vertical ic ) or no output dc coming from the ic. if it is not totally a horizontal white line and you can see a video you must check leak or bulged capacitors at the vertical section near the vertical ic. hope this can help good luck.
Oct 02, 2012 | Televison & Video
No audio and have a thin white verticle line across tv
Always suspect a bad EEprom...very common on this TV! See a tech, he will have to select one of six eeproms to fix this!
Jan 10, 2010 | Philips Magnavox 27MS343S 27" TV
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Blue Screen with thin horizontal white lines
THI IS THE INTERNAL CIRCUTRY FAULT BEST YOU
call the service person and dont try to open it other than in side of TV SET HAVING Hazard of electrical shock be handle most care fully .
and check video board and all.
Oct 19, 2008 | Philips Magnavox 20MS233S 20" TV
Tv repair
You don't have to buy a new tv, it is a fairly simple problem, your vertical ic is blown, and it could be the powersupply to the vertical ic also. To verify, slightly increase the screen voltage, and a horizontal line will appear on the screen, if the voltages is okay, change the ic, but first try resoldering the ic pins. Good luck
Jan 14, 2008 | Philips Magnavox 24MC4306 24" TV/VCR/DVD
Horizontal line in the middle of the television
From your description of the problem, there seems to be a Cold solder in the Vertical Oscillator or Deflection Coil circuits.
If you know Solid State electronics, and are good with a soldering Iron, sure u can do this yourself.
U gotta trace the Vertical section components and locate the cold solder. In most cases it will be a loose connector from the Deflection coil to the main PCB.Also check for the soldering of the Vertical output IC.
Oct 19, 2007 | Philips Magnavox 27MS343S 27" TV
Black screen, high pitched squeal
A set that has only a 1/2 inch bright line through the middle of the picture, from left to right, has a vertical output IC that is not working correctly. If the 1/2 inch line is in the middle but going up and down, then the horizontal yoke circuit has stopped working. These are problems which should be looked at by a qualified tech, but if the set was purchased 6 months ago then it should still be under the manufacturer's warranty.
Aug 29, 2007 | Philips Magnavox 20MT4405 20" TV
Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
May 29, 2007 | Philips 9P5544C 55" Rear Projection...
White Screen w/ White Lines, Sound On, Turns off after 2 or 3 secs.
Hi If you mean thin white lines, this is is an indication of a problem in the Horizontal Drive ckt. most likely the Damper Diode has opened or shorted, this would cause the visual symptom and then the set would shut down, unfortunately this is a problem best left to a qualified technician to repair, hope this helps.
Apr 12, 2007 | Philips Magnavox 27MS343S 27" TV
Philips 13PT30L 13" TV Logo
66 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
