Question about JBL S120PII Subwoofer
The power switch came off of my subwoofer.
I have a JBL S120PII Sub. Yesterday, I went to turn on the Sub, and the Power Switch just came off. I tried putting it back in, but to no avail. A couple pieces of aluminum also came out w/ the switch. I was wondering if there is somewhere I could take it to get it repaired. Aside from that, sub works perfectly. Although, at current, I have no way to turn the power on. Appreciate any help and guidance.
-Ryan
  • jon3500 Mar 22, 2009
    I have the same issue! I used mine for well over a year or so until one day the switch just fell out. Has anyone found a solution to this? If so, please email me at jon3500@hotmail.com
Same thing happened with me. Did you ever find a solution?
Posted on Nov 22, 2009
I have a JBL S120PII sub that stopped working. All I get is the red and green light flashing on top. Is this indicative of a specific issue?
Check and replace the power output MOSFETs [at the power amplifier circuit]. A damaged MOSFET can cause this continuous LED blinks. It is important to replace all the 4 MOSFETs at one time. Also, check for any further damaged to any other components too have occurred. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Oct 09, 2016 | JBL Audio Players & Recorders
JBL PB12 will have loud thump or pop!
First try to find the source of your problem. The easiest way would be to try your sub with a different audio source to see if the problem still occurs but is sounds more like there's a problem with the receiver.
Oct 18, 2012 | JBL PB12 Subwoofer
How to set up to stereo ?
Generally there is a left and right input. The sub is usually not in stereo, the frequences of the sub are more omni directional, and have no spattal placement in the stereo field. If there is only (1) input you can take either the left or right from the system and you should get the frequencies you need. In the even it is not working out quite right you may take the left and right and use some 1k to 4.7k 1/2 watt resistors connected to tie the left and right line output togeather to feed the sub.
Dec 24, 2010 | JBL S120PII Subwoofer
I have a JBL PB12 sub, no power - prev wrenching sound on startup
these a internal power control board defective, send to repair
Jan 17, 2010 | JBL PB12 Subwoofer
Wiwing question
its for the led light red and green red means in standby position and green means its on
Nov 12, 2009 | JBL S120PII Subwoofer
JBL PB10 subwoofer sounds distorted and lights on the front flash
More likely to be the Class D power amp module, but you should look through the service manual to make sure all the parts are installed correctly. My PB10 AMP module went out and you cannot get one anymore.
http://manuals.harman.com/JBL/HOM/Service%20Manual/PB10%20sm.pdf
Nov 10, 2009 | JBL PB10 Subwoofer
Even Distribution
i have same speakers try these setting and tell me what you think put phase at 180 and put switch on lfe mode not normal for some reason my sub plays louder on these setting verse phase on 0 and lfe switch on normal i have power on subwoofer a little more than half also set croosover to 80hz you will never touch it again
Dec 05, 2008 | JBL Northridge E 250P Subwoofer
Subwoofer not powering enough (Sounds like under powered 8inch)
get a nice monster subwoofer cable and a Subwoofer PowerCenterâ„¢ SW 200 with Clean Powerâ„¢ Stage 1 get it from like amazon and you'll definately see a difference and also put the sub in like a corner
Jun 08, 2008 | JBL S120PII Subwoofer
Jbl sub power dumb blonde needs help!
did any 1 get a solution for this problem???
Apr 12, 2008 | JBL S120PII Subwoofer
Power acoustic amp help
probably you had cause the wire to ground out the set.causing the short out to damage the power supply take your set to a tech to check it.and possibly to repair.good luck.
Apr 13, 2007 | JBL S120PII Subwoofer
JBL S120PII Subwoofer Logo
196 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
