I have a 2001 sc1 saturn. efi/ohc (electronic fuel injected) sohc. about a week ago i started haveing a ticking sound from my motor. sounds like it may be the lifters. not 100% sure. but i also have oil siting next to my butterfly when i take the hose off for my air intake. im not an expert when it comes to cars. but i know this cant be good
Your engine code (DTC P0442 Evaporative Emission (EVAP) System Small Leak Detected ) should not have anything to do with a ticking sound. The evaporative system keeps you from having a gas smell under the hood and in the car.
As far as ticking goes ... it could be many things. You are correct, it could be lifters. If you take a long screwdriver and with the engine running place the handle end against your ear and touch the blade end to the top of the valve cover the screwdriver will act as a stethescope. If the ticking gets a lot louder somewhere on the valve cover then yes, you have a lifter making noise. If the motor ran really low on oil, and then one or more lifters started ticking you can try running about a half quart of transmission fluid in the oil for about 15 minutes at ididle while gently changing the rpms between idle and about 2500 to see if it loosens up the lifter(s). Change the oil after you do this.
To test the PCV valve, with the engine running pull the PCV valve out of the valve cover (leave it attached to the vaccuum hose) and place the tip of your finger against the now exposed tip of the PCV valve. It should make a snapping noise and **** your finger against the opening in the valve. If it does not, then make sure the vaccuum hose does not have a leak in it. If the hose is good, shut the car off, remove the valve from the vaccuum hose, and use some carburetor spray and clean it out. I clean mine each time I change the spark plugs. If the valve is stuck or clogged this could be causing the oil pooiing problem in the air intake tube you describe from excessive crankcase pressure.
If you still have not found the ticking noise, it could also be in the lower end of the motor. This is the only "bad" place for it to be out of what I have described. If it is a lifter and the noise is not really loud, it is not dangerous to drive.
SOURCE: Saturn 2000 SL1 - 4
Try pulling the engine coolant temp sensor, They often crack not sure why but the ceramic tip cracks makes the car hard to start, or won't start, the car's idle may race while shifting gears, and often smokes. The sensor is on the right side of the engine when looking at it on the head. Easy to change and get too
SOURCE: 99 Saturn SC1 ''Service engine soon'' light is on.
Did you get the code that triggered the SEL? If you know that, it will be easier to diagnose your problem. You can do it without a tool on the old saturns. Just need a paperclip. :
Use a paper clip to jumper Terminal A and B of the ALDL *Assembly Line Diagnostic Link* which is above your left knee.
Terminal A is an interal ground and is the top right terminal in the
connector. Terminal B is directly adjacent and to the left of Terminal
A.
Turn the ignition to ON.
All codes are 2 digits between 11 and 99. Codes are displayed on the
SES light by flashing the light with short and long pauses to
distinguish digits of one code from digits of another. The short pause
is used between digits of the same code, long pauses are between codes.
Also, each code is flashed three times before going to the next code.
For example, the sequence of code 12 will be: flash, pause,
flash-flash, long pause, then repeat 2 times. If Code 12 is not
displayed, the self-diagnostic pogram i snot functioning properly.
If only Code 12 is displayed, no system malfunctions have been stored.
Any existing system fault codes are displayed in order from low to high, except for Code 11.
On vehicles with an automatic transaxle and on which exist stored
transaxle codes, Code 11 will be displayed last, then the SHIFT TO D2
light will begin flashing transaxle codes of flags.
When all engine codes have been displayed, Code 12 will flash again.
Diagnostic Codes
11. Transaxle Codes present
12. Diagnostic System Check
13. Oxygen sensor, circuit open or not ready
14. CTS circuit, out of range high
15. CTS circuit, out of range low
17. PCM fault, pullup resistor
19. 6x signal fault, no 6x signal between reference pulses
21. TPS circuit, out of range high
22. TPS circuit, out of range low
23. ATS circuit, out range low
24. VSS circuit, no signal
25. ATS circuit, out or range high
26. Quad Driver output fault
32. EGR system fault
33. MAP sensor circuit, out of range high
34. MAP sensor circuit, out of range low
35. IAC valve, rpm out of range
41A EST circuit open
41B EST circuit shorted
42A Bypass circuit grounded
42B Bypass circuit open
42C Bypass circuit shorted
41. EST bypass, open or shorted
42. EST bypass, open or shorted
43. ECS (knock sensor) circuit open or shorted
44. Oxygen sensor indicates system lean
45. Oxygen sensor indicates system rich
46. Power steering pressure switch circuit, open
49. Idle rpm out of limit high (vacuum leak)
51. PCM memory error
55. A/D converter error in PCM
81. ABS message fault (1993 vehicles with TCS)
82 PCM internal communication fault
Diagnostic Flags
27. Quick quad driver output fault (1993 only)
48. Reference imput intermittent or noisy
52. Battery voltage out of range
53. ESC knock present
54. Five volt reference ground
58. Battery voltage unstable
61. 6x signal fault
63. Option check sum error
67. Handwheel sensor circuit fault
71. Cooling system temperature high
72. Coolinng system temeprature low
73. CTS sensor unstable
74. CTS/transaxle temperatuer sensor ratio error
76. ATS sensor unstable
83. Low coolant (1993 only)
SOURCE: Resetting my car
It is real easy. Turn the key to the on position without starting the car.(lights on dashboard), Push on the accelerator 3 times within 5 seconds. That's it. If you are unsure, then try it twice. Good luck. Keep me posted.
SOURCE: will not start after it stalls untill about 5-10 minutes
Your problem is most likey your intake gasket.They have a problems on the SOHC engines where the intake gasket shifts & starts leaking vacuum at the #1 intake runner causing a missfire on Cylinder #1.While the engine is Idling buy some throttle plate cleaner & spray throttle cleaner down at the #1 Intake runner where the intake meets the head.If engine stalls or runs rougher that's your problem.I have replaced dozens of those gaskets for tha reason!! They have a beter design gasket through saturn parts.It has a coating on it to prevent reoccurance.Also you should check you Coolant Temp Sensor,if it's ceramic it's most likely bad.Replacement is brass from saturn.Good Luck
SOURCE: 1998 Saturn SL Service Engine Soon Light is on
there will be a fault code in the PCM
need a code to help you
ok well ive done some more serching and my light is ffor sure on because of the evaporative emission control ystem (eec) but im thining it may have something to do with my positive crankcase ventilation (pcv) the here are two hoses comeing from the top of my motor. one leading to my throtle the other to my air intake but that one is actualy comeing from my injectors. now the one going to my throtle there is like a brass conection that the hose is conected to i belive when i put my mouth on that, that i should only be able to breath air through one end of it. but i have oil comeing through one of the lines.well pritty much circulating through bolth hoses (pcv and eecs) not sure if thats causeing the noises if its realy that or my lifters ticking. please again any help is always grately appreciated. its varry important that i get the problem fixed befor i leave michigan. i just got enroled into uti in glendale IL. n the car hasto last n get me there by october thankyou varry much
oh duh it is a 5speed as well
