Question about Asko Washing Machines
Asko washer power light does not come on when depressed.
I checked the fuses in dryer and washer. I put a meter on inside washer and have power. Is this the boasrd?
    Sergeant:
    Champion:
  • 311 Answers
Yes. I can get you parts if you need them. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
Asko 12505 has no power
i assume you checked the fuses with a meter?how old is the unit?
Sep 16, 2007 | Washing Machines
I have a T711 asko dryer. When I push the start button it makes the sound when the dryer has completed its cycle. There is a "signal" button that you can depress to let you know the dryer is finishe
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Nov 11, 2011 | Asko T711 Electric Dryer
Asko dryer has no power.Washer ok
By-passed fuses,dealer said he's done hundreds.Saved me a service call.This is the 1st and only problem we've had in 10 years! We love our Asco.
Feb 16, 2010 | Asko Dryers
Light of power button very weak and the start button doesn't work
Hi, the issue with the "light" may or maynot be related. Sometimes the lens which holds the light in place behind the console cracks and the light falss loose, so although the light still aluminates, you only see a slight glow as a result. The other issue may be the unit is only getting 1/2 volts. **UNPLUG THE POWER CORD** Check the fuses at the back (there will be 2). They are by the cord in a "holder" that is either gray in color or black. Observe them and you'll notice they have a slot in them so you can use a flat screwdriver to remove the holder/hub (as Asko likes to refer to them), once removed you can check across the fuse with a meter for continuity or replace with a known new/good fuse. If that solves the problem...awesome. Let me know and I'll follow up if needed. **ALSO** If you replace the fuse and in a short time it blows again, you likely need new fuse holders & hubs. They do suffer from metal fatigue over time which in turn causes a poor connection and of course equals undesired resistence, hence...blown fuse. The same can & likely will happen to the washer if it's an Asko as well FYI. Hope this helps, let me know. I'd appreciate the opportunity to help more if called on. Good Luck
Oct 21, 2009 | Asko T701 Electric Dryer
Power light is not turning on. I have replaced the 2 15 amp fuses in the washer (not ASKO fuses) and I have confirmed that the beaker panel is working fine and the dryer which is linked to the washer is...
There is need to check if there is power getting at the fuses and power getting to timer control board.That is done reading volts with a multimeter.
For safety reasons I need to remind that all test with live power must be done by a trained repairman.
If there is no power at all and you already replaced the two fuses, then problem can be power cord, internal wiring harness, control assembly .
Sep 08, 2009 | Asko Washing Machines
I Have an ASKO dryer that will not start,the power buttom red light comes faintly on put that is it
Check for a blown thermal fuse. It is about an inch long and is located just inside the rear of the dryer and is usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Test for continuity. A lack of continuity indicates a blown thermal fuse. Hope this helped and best wishes.
Aug 27, 2009 | Asko T701 Electric Dryer
No Power. Tried everything I can think of...replaced both ceramic (15 amp) fuses. Restart button is already depressed in. Power cord works (washer currently works and electricity flows through top box of...
You will have to chase power in the machine. Start at the start button and follow the wires with a meter check each connection point. Have you checked the door switch?
Nov 14, 2017 | Asko T701 Electric Dryer
Asko 700 model dryer has no power
If you have done all of the above, check your on off switch. It may not be getting or letting power in or out.
Feb 13, 2009 | Dryers
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Washing Machines Logo
101 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
