Question about Maytag Performa PAV2200
Older model Maytag washer, it makes a lod squeal noise at end of spin cycle
  • 121 Answers
Its the brake dont worry it wont heart athing but you can put some greese on it
Posted on Nov 29, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Loose belts on Maytag Washer LAT2300AAE
It is normal for the belts on this model to be loose. Normally the noise that you are hearing is either the damper (a white plastic type material,comes in a kit) or the pump making the noise. Take the belt off the pump and put it into a spin cycle and see if you hear it. If so ck the tub bearing for rust or leaking and the damper for wear. If you don't here it, ck the pump.
Mar 04, 2013 | Maytag MAV4755A Top Load Washer
Old Maytag Dependable care washer - LAT8506
Need to replace the belt going to the transmisssion powered by the motor. these act like a clutch for the unit. It is worn out and needs replaced.
Jan 26, 2010 | Maytag Dependable Care LAT9206
Washer squeals at end of spin cycle
The manufacturer recommends you tilt back the washer and spray some penetrating oil into and around the brake package to stop the squeal.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 18, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Makes loud squeal noise when stoping to change cycles
when in spin out cycle when first comes on makin a noise like something is in the pump i check it and the pump is clear must be maybe lower bearing assembly sounds like something is lose or broke it also stops instancely at end of cycle what could this be
Jan 12, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My MAV8600AWW top load washer makes a loud steady squeal whining noise in spin cycle. Load size doesn't affect noise. Machine is 7 years old. Any guess as to problem?
Maytag had problems with the berrings on the transmission . water gets in and the berring goes bad rorring as it spins. Dump it and get a Whirlpool.
Nov 11, 2009 | Maytag MAV8600 Top Load Washer
MAV408DAWK Maytag top load washer is squealling
The noise could be coming from the wornout drum bearings. It needs replacement.
Oct 13, 2009 | Washing Machines
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Washing Machines Logo
296 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
