Question about Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore he4t washer shows f-11 error
I keep getting a f-11 error and sometimes I can mess with it and sometimes it will correct and complete cycle and sometimes the error will reapear
  • Anonymous Mar 08, 2009
    I get this error occasionally, but today I can't get the machine to reset. Usually I can stop it and restart it and it is fine. But this time it will do nothing.
  • 116 Answers
F-11 // WILL THEN APPEAR FDL CODE DOOR LOCK LOCK FAILURE, F-11 COMMUNICATION ERROR REPLACE MAIN CONTROL,, JUST REPL 3 TODAY ....
Posted on Nov 30, 2008
Freezer cuts on every 3-4 minutes. stays on 8-10 seconds. some thawing occuring
If I understand you correctly the compressor is short cycling. The more it does this the worse it gets by causing the compressor to overheat. Sometimes the problem is because the condenser fan or evaporator fan being defective. Pull away from wall and remove cover over compressor unplug and feel top of compressor and if too hot to keep hand there keep unplugged but do examine the evaporator and condenser fan to eliminate them as a reason. The most likely reason is start relay and or start/run capacitor and sometimes a worn out compressor.
Overload relay click here=> 67002527
Run capacitor click here=> 65889-4
Location Click Here=> MBB1952GR Compressor Components
Parts in that photo are marked as 10 overload/relay, 11 is the run capacitor and 3 being condenser fan motor. Condenser and evaporator fan motors do not always stop completely when bad so make sure both run while compressor is running. If this has been helpful please rate if you have more questions please let me know, Thanks Sea Breeze
Dec 10, 2010 | Maytag MBB1952GR Bottom Freezer...
I keep getting an f 11 error code? what seems to
F11 is the code for a communication error between the CCU and motor control unit.  sometimes just re-seating the connectors on the CCU cures it.  if not, odds are it is a faulty CCU and needs to be replaced.
Jul 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Keep having an f 11 error code,even in middle of a cycle
Hello there:
this dreaded error code is caused by the following
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Jan 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 11 error code on whirlpool duet washer.
  • Check MCU
  • Check CCU
  • Check Motor
this is for error code f 11
thanks.
May 02, 2009 | Whirlpool GHW9400 Front Load Washer
The machine does not automatically go from one cycle to the next
You have a pitted timer most likely. First i would check out the lid switch which you may be tripping while messing with the timer. And what brand and age.
Mar 29, 2009 | Washing Machines
Error message F 11
Potential causes: • Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU) (its the
usual thing)
• Check MCU
• Check CCU
• Check Motor
Replace failed component. Check for sharp edges in wash basket of machine. Companies want you to dump your machine & go for a new one, keeps their factories running.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite smart wash quiet pak 9 Front Load Washer
Our washer is flashing a F21 and it never finishes the load there is always water left.. what can we do to fix it?
Oct 16, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet Washer
Jake at applianceblog says that the F11 is a "Serial Communication Error"
Check for:
Check MCU
Check CCU
Check Motor
Check Wire Harness
If all the connections look fine , then its possible the CCU is reading wrong and will need to be changed.
Nov 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 3.8 cu. ft. HE4t Front Load Washer Logo
537 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
