Question about Sony KP-57WS500 57" Rear Projection Television
Convergence what do i need to do to get the ic stk392-560?
  • kevin walvatne Nov 29, 2008
    thx for your response, what i really need to know is do i take out the d card or the whole tray thx kwalvatne
  • Sony Master
  • 8,617 Answers
The ICs are located on the D board Tan board on the lower left side looking in from the rear. They old Ics will need to be desoldered and replacements soldered in. Also check the yellow pico fuses located under the fins of the ICs heat sink, usually some of those will be open ( Blown) replace them with 3.5 amp pico fuses.
Posted on Nov 29, 2008
I have an rca r52wh77 it is bowed in the top and bottom. it also is way off in convergence and i can not seem to get the crosshatches to come together. i have changed the fl123 part that was sent in my kit...
Does the kit have a pair of convergence ICs? That is what you will need to fix the convergence problem. The kit should also contain thermal grease(a white paste that should be applie to the ICs before you solder them) and resistors that may also need to be replaced. When a convergence IC blows its usually due to failed resistors.
May 26, 2011 | Televison & Video
I need an IC Part for the TV. Are these expensive parts and is it a difficult repair job ??
I asume you're talking about convergence IC's? The IC's themselves are about $50.00 total
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 25, 2009 | Toshiba 57H81 57" Rear Projection...
My samsung rear projection tv has a problem with its convergence ic. i think theres two ics , but how do i tell which ic need replacing??
Always replace both once your going to the trouble each IC is usually less than $30.
This link will help show you what's involved.
Nov 13, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Convergence
If you can not adjust the convergence, then you need to change the convergence IC's The number of the IC is on the chip. There maybe one or two IC chips. I think there are about 12 to 15 pins or so, and will be mounted to a heat sink. There maybe surrounding resistors that need to be replaced too. I hope this is helpful.
Nov 13, 2009 | Televison & Video
I have a philips 9p6044. where can I buy convergence ic's and a
its far more likely that you need a new Vertical output IC. The convergence ICs wouldnt prevent the picture. When you have audio but no video it is often meaning vertical failure. Try replaceing the vertical IC
Apr 23, 2009 | Televison & Video
My Mitsubishi VS-50705 has an all over 3-D effect.
Yes it sounds to be convergence issue .
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
Convergence ICs
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Hope this helps .
Mar 03, 2009 | Mitsubishi VS-50705 50" Rear Projection...
My tv is showing a double picture in red
Convergence ICs
Hope this helps .
Mar 03, 2009 | Apex Digital GB4308 43" Rear Projection...
CLASS HD Convergance ploblem
You need to replace STK ics which are convergence ICs in your tv
You can get from the link below
Click this link to get convergence IC
It will cost you $20-30 to buy these IC .
Jan 30, 2009 | JVC AV-48WP74 48" Rear Projection...
42H83 Convergence
Yes the convergence ICs need to be replaced, however so dont the six 1.8 ohm 1watt resistors as Toshiba recomends replacing those six resistors when the ICs are changed. You can get the 50H71 / 50H82 Convergence repair kit as the 42H83 is identical to the 50H71 series, so the kit will work for your model. Heres the link where you can get the kit.
http://servicemanuals.vstore.ca/
Aug 10, 2008 | Toshiba 42H83 42" Rear Projection...
Right side convergence
A convergence IC has burned out. If I remember correctly, those Pioneer sets have one huge convergence IC, but that IC only has 5 channels in it so they use another smaller dual STK IC and one half of it is used for the 6th channel and the other half is the vertical output. Look on the convergence board, find the blue convergence jack, identify the blue horizontal channel, follow the traces and replace the IC handling the blue horizontal channel.
Aug 28, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
63 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
