Question about Brother MFC-9420CN All-In-One Laser Printer
Vertical line on paper when printing
There is a vertical line about 1/16 of an inch on the paper when i print, this just happened, I think is because one of the label paper I put in the tray before printing on it had something, which I thought was ink on it that caused this problem, how do i remove it?
    Sergeant:
  • 291 Answers
If that paper is rolled over the roller you will have to disassemble the printer to remove it,but if it is just on the printers upper side u can pull it forcibly to remove thast paper.
Posted on Nov 28, 2008
HP m410n laserjet pro banding gray vertical lines
the two places to look is transfer roller and the fuser unnit.
i think there is a problem with the transfer roller it is under the toner and it needs to be spring loaded. The paper passes between the toner an the transfer roller to charge the paper en let the toner stick to the paper and if it doesn't make correct contact then it wont work
Dec 26, 2013 | HP LaserJet Office Equipment & Supplies
My Ricoh Aficio CL2000N is printing several faint lines
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
Mar 25, 2010 | Ricoh Aficio CL2000N Laser Printer
Small vertical lines in background
Very strange that the lines would appear on your prints aswell. Must be a faulty video adapter but I have no idea how this is getting to your paper - printer.
Get someone to look at the machine locally I don't think that we can solve this over the internet. thanks.
Sep 11, 2009 | Dell Dimension 4600 PC Desktop
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Black Vertical Line on the paper
start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine;quickly open it to stop print and take out the cartridge and look at it's drum and the paper underneath. if the issue is there at that point then it would point to the cartridge. if not then the fuser
Let me know....
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Brother HL 5140 Laser Printer
LaserJet 3015
The line was not a crack in the glass-as I thought it might be.
However, I cleaned the two sides of glass with piece of clean kitchen roll and it is clear now!
Thanks
J Taylor
Sep 10, 2008 | HP LaserJet 3015 All-In-One Printer
Printing problem
the problem exclusive between the drum or the fusser unit
Apr 25, 2008 | HP LaserJet 2550L Printer
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Brother MFC-9420CN All-In-One Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
