Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Broken Inner Glass Door
I have a Frigidaire Gas range oven (PLGF389CCA) and I touched a cool rag to the inner door after completing a self-cleaning. The inside glass shattered. What part(s) do I need to order to replace it myself?
  • 1,543 Answers
The inner glass panel is a part number 316117500
Anyone who services Frigidaire, and some others can get one for you. Here in the midwest I get lots of my parts from C.E. Sundberg Co., based in Chicago. They have this part on hand in Chicago, St. Louis Park (Minneapolis), Omaha, and Milwaukee, and will ship. Cost should be under $100. Even more info than you asked for, sounds like a FixYa, yes?
Posted on Nov 28, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Nov 29, 2008
    Thanks for the FixYa. Good luck with the repair. It should not be too hard.
    Sergeant:
    Champion:
  • 311 Answers
Just the glass piece. Look up parts on any parts site or let the supply house do it for you. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Replacing oven door glass
You didn't say what brand or model but here is a link to a youtube video for a Frigidaire oven, Other brands and models on youtube too. You will probably be able to get a replacement kit from sears parts direct if you have the brand and model number. Or an appliance parts store or ebay.
Range Stove Oven Repair Replacing the Inner Oven Door Glass Frigidaire...
Aug 16, 2014 | Ovens
I JUST WANT TO REMOVE THE OVEN DOOR TO CLEAN THE INTERIOR SURFACE OF THE DOOR GLASS
If you mean between the inner and outer panes of glass; you will regret it. It's likely that both are mounted with a fragile heat-proof mineral (non-asbestos) gasket material that may crumble once the panes expose it.
Apr 22, 2011 | Frigidaire 30 in. Electric Gallery Pro...
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
GLASS BROKEN ON MY FRIGIDAIRE PRO
Inner or outer? you will have to take the door off, done by lowering door to full open postion and youll see a fold down flap at hinge, fold down and close door and lift. this will allow you to access screws easier. remove handle and four bottom screws. that will allow you to take off outer glass....there will be screws on inside to take out inner glass.
Jun 08, 2009 | Frigidaire FGB24S5A Gas Single Oven
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Cleaning between oven glass
You must unscrewed inner door,there is screws around edge door inside,try it.
Feb 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool under counter oven, inside glass door broke.
To get to the glass on the inside of the door you need to do the steps listed.
1. Open door 4" and pull straight up at that angle
2. Lay door on flat surface with the handle down to surface.
3. Remove all screws that you see .
4. The inner housing should be removable now.
Then you should see the glass. Reverse the steps to put back together.
Good Luck with the fix.
Dec 17, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
How can I remove oven door so that I can replace the broken glass
I just took my oven door off and took it apart to clean the glass inside. I don't have a maytag but they probably all work alike. Just open the door like you are going to broil something and just lift it up. It should slide right off. Shouldn't have to unscrew anything. Hope this helps. Arlene
Nov 15, 2008 | Kenmore 33169 Gas Single Oven
Inner glass oven door
LONG AS YOU DONT RUN SELF CLEAN SHOULD BE OK
Nov 01, 2008 | Stoves Premier 600EMa Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
234 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
