Question about ViewSonic VPW505 50 in. HD-Ready Plasma Television
Viewsonic vpw 505 won't turn on
I've had my 50" Viewsonic Plasma for about 3.5 years. I tried to turn the TV on and it wouldn't come on. I tried it again a few minutes later, it came on for about 1 second and went off. We noticed that not only was the green "ON" button not coming on but also the orange button that indicates power wasn't on either. We checked circuit breaker..fine. We checked the Main power switch in the back..it was on. We thought maybe it was a bad outlet so we plugged it into another outlet but it still didn't work. We plugged a lamp to the TV's outlet to see if the outlet was the problem and it was working fine. Next we plugged the TV back into the original outlet and the orange light came on. We thought it was fixed. Within seconds the orange light went off again and we can't get any power at all. Spoke to the tech at the place where we purchased the TV. He said it sounds like it COULD be a power source and we needed to bring it in Does anyone know what that means? Just for them to look at it it's going to be $100. Can anyone help me with this? Thanks
    Top Expert:
  • ViewSonic Master
  • 76,036 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Mar 06, 2017
SOURCE:
  • 395 Answers
SOURCE: Picture goes out after 1 second, audio is fine
the problem is not the mian board but the DC to DC inverters that drive the lamps behind the panels some manufactures make them available seperate from the panel but most are a part of the panel. so the whole panel may have to be replaced.
Posted on Jan 17, 2008
SOURCE: broken plasma tv screen.....nec model
How much would it cot to replace the outer glass screen please
Posted on Apr 10, 2008
SOURCE: Have parts for Viewsonic VPW-425 42"
no clear picture on any plugs on back of tv can tap on box it clears up for a min.
Posted on Jul 01, 2008
SOURCE: Powerlock Enable cannot be removed from my ViewSonic N3246w.
I have a 19" ViewSonic and if you hold down the 2nd and 3rd buttons together under the screen, counting from the LEFT, it will disable the Powerlock.
Posted on Jan 01, 2010
budmrtn
  • 11361 Answers
SOURCE: No Video, Just Squeaking at 1 second intervals
Check the power supply module for bad caps, Q7,and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20N3250W/
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jun 29, 2010
50" Philips Plasma 50pfp5332D/37 won't turn on
I have a 42in vizio led with about the same problem i replaced a 75 cent chip # u33 on computer board problem fixed.
Sep 25, 2012 | Philips 50PFP5332 50" 1366 x 768 Plasma...
My 50in won't turn on
might have to change the bulb in the tv, should be in the back right corner should tell u something like a warning lable so u can find it,u will need a screw driver.
May 28, 2012 | LG 50PK250 50 HDTVReady Plasma TV
My viewsonic vx1940w monitor won't turn on. There's no lights or anything. The outlet it's plugged into is working because I tried another device in the same outlet. My settings didn't...
I had two ViewSonic's that did the same thing right around 2 year as well. They worked really well for me and then just died.
I found out the first one had a faulty power cord, and the second one just wouldn't turn on at all.
I think there's a good chance that your monitor bit the big one just based on my experience with the brand. I would recommend taking it in to your local computer repair shop and let them take a look at it. If it is 2 years old then it is probably out of the manufacturer's warranty unfortunately. I hope this helps answer your question :(
Thanks for using FixYa.
Aug 27, 2011 | ViewSonic VX1940w LCD Monitor
I have a ViewSonic 42"
Take it as soon as possible to a tech. Check your warranty. It's either a software or hardware problem.
Jul 26, 2017 | ViewSonic N4280P TV
LG 50" Plasma Start Up Problems
The logical fix would be to activate your 3 year warranty, messing about yourself is unlikely to fix it and very likely to void your warranty. The time for do it yourself repairs is when you have no warranty.
Nov 25, 2017 | LG 50PC5DC 50 in. Plasma HDTV
If these are used parts or from a scrapped set, buying used parts would be a very risky investment.
Jerry G.
Apr 13, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Broken plasma tv screen.....nec model
SoCalRugger,
The plasma usually has 2 sheets of glass, the outer one sounds ok which is not good news as these can be replaced.
The inner panel is the actual plasma layer and if it is craked or broken it usually requires a swapout for a new panel.
Jan 25, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
ViewSonic VPW505 50 in. HD-Ready Plasma Television Logo
202 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
