Question about Refrigerators
Location of start relay
I've been told the start relay is going bad on my 16 yr. old Kenmore ColdSpot 20 with freezer on top. Model #106.9710680. I want to replace it myself, where do I find it under the frig and what does it look like? I assume its connected to the compressor. Sears sells them for $36.50 is that a fair price?
  • 120 Answers
Yes that is an ok price or try coast appliance if you are in the la area ok the relay is located on the left side of the compressor is conected on a 3 pin conector you can't miss it is mounted on the compressor it self
Posted on Nov 28, 2008
Kenmore Refrig Model # 75922400 top Freezer. Freezer is freezing really good but frig is around 46 - 48 degrees at coldest setting. We discovered ice on vents in freezer and thawed them out with hair...
Sounds like a defrost failure.
Look on the back wall of the freezer from the inside.
If it is covered in ice your defrost system has failed.
Also check the fan motor in the freezer.
If it is not running it must be replaced.
Feb 24, 2011 | Kenmore 18.9 cu. ft. Top Mount...
Kenmore coldspot model 106: top freezer leaks water slowly into botton refrigerator. how do I repair it?
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
Dec 19, 2010 | Kenmore Refrigerators
My Kenmore coldspot 71182100 which is almost 9 years old just started leaking water from the freezer onto the shelves in the fridge. I just cleaned out the freezer and got the ice out. There was not...
I have a Kenmore Coldspot Model #69207990 and have the same problem. Water from the freezer drains into the refridgerator onto the shelves and sheets of ice form. A repairman pointed out that the tube leading down from the freezer onto the drain pan was frozen. By pouring hot water down the tube, he reopened this drain line. Problem solved for six months and the drain line froze again. My question is how to stop this drain line from freezing up again.
Dec 16, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore Coldspot not keeping cold. Ice in freezer
What are your temp controls set to? If the controls are set to the max setting and it won't reach temp, you could have a broad range of problems ranging from bad door gaskets, to bad temp controls, to a low refrigerant charge, to possible a failing mechanical part such as a fan motor or compressor.
Jan 08, 2010 | Refrigerators
Spin cycle does'nt work.
you have a bad basket drive on the washer and with a coldspot the problem will most likely be your defrost timer
Nov 22, 2008 | Kenmore 24032\24036 Top Load Washer
Refrigerators Logo
186 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
