Question about Frigidaire 18 in. FDR252RB Built-in Dishwasher
Hooked up new 18 inch frigidaire dishwasher, sounds like the motor is running but not filling, making kind of a gargling weird noise
    Sergeant:
    Champion:
  • 311 Answers
If it's new call a Frigidaire servicer for wty service. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 29, 2008
Grinding sound in FGHD2472PF frigidaire professional
Hello friend, thank you for your inquiry!
I understand that your Frigidaire dishwasher is making a grinding noise. Typically that noise could be a faulty motor/pump. I have included a link to your manaul. If that does not help I would recommend having a technician out to your home to properly diagnose and repair your appliance. Best of luck. -Matt
Frigidaire Manual Search Results
Aug 14, 2014 | Frigidaire Professional Series 24 in....
Washer makes grinding noise but isn't doing anything else
Remove the cap off the agitator, flip back the top of the console, remove any nuts keeping the tub in the console. There will be a clutch ring that needs to be replaced. I have an older top load washing machine. I agitates, fills, and drains, but it won't spin. It sounds like it is spinning, but it doesn't. It might be the coupling. That is a 3 piece kit that goes between the transmission and the motor. I found the directions how to do it over the internet, got the part and fixed it myself.
https://www.structuredsettlement-quotes.com/
Nov 08, 2013 | GE GSM1800NWW Spacemaker 18" Built-In...
Diagnostic
something is caught in the food grinder. they can make all kinds of weird noises depending on whats in there. here is a video if you think that this could be your issue. http://www.youtube.com/watch?v=Wttz4fB1yVs
Oct 09, 2013 | KitchenAid 24 in. KUDI02FR Built-in...
Dishwasher hose is hooked up separtely from garbage disposal but still dishwasher not draining
Hi - Is the unit making a grinding noise? If so, contact a professional because you may possibly have a defective drain motor/pump.
Oct 13, 2012 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher is making a loud noise
Sounds like there is something in the filter trap that is right before the mini disposal that is a fan blade, on top of the motor.
Aug 04, 2012 | Frigidaire Professional Series 24 in....
Dishwasher is running and emitting a weird odor that is filling the downstairs of our home- smells like sharpies?
You could have a problem, maybe something has plugged and is causing stress on a pump motor (wash cyc) or drain pump... something stuck in discharge baffle unit must be removed for easy axcess to said assembly.
Feb 27, 2011 | Frigidaire 24 in. PLD2850 Built-in...
Frigidaire dishwasher model GLD2445RFCO is making noise
I have the same problem with my dishwasher. If you remove the kick plate while it is running, There is an electric motor underneath. If you push up and pull forward on the electric motor, the noise will stop. I used a block to prop it up and the noise stopped. You may want to try it.
Jan 08, 2010 | Frigidaire GLD2445RFC Stainless Steel...
Dishwasher makes squeeling noise when filling with water
if the dishwasher is only filling when u hear the noise it could be a bad water valve or if you are lucky it could be the screen in your water valve is dirty, however if it is filling and washing at the same time and you hear a noise like sqeeling it could be your motor, before u replace the motor. check the water valve or screen on valve may be dirty
Sep 16, 2009 | Frigidaire 24 in. GLD2350RC Energy...
Water not spraying
sounds like a bad motor, you can get a complete replacement of the motor and sump assembly for about $150-175. one piece includes new motor and chopper assemblies, less then a hour to change.
Feb 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Frigidaire 18 in. FDR252RB Built-in Dishwasher Logo
220 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
