Question about Mitsubishi CS-36509 TV
Horizontal roll on mitusbishi 35" tv
My tv is on constant horizontal roll. Someone said it sounds like leaky caps. Any easy suggestions I can use to fix it meyself? thanks.
Thanks for your answer nfandres. The whole picture rolls up and down. In the old days I could fix it with a Horizontal or vertical hold button, but I don;t have one of those here. Any other suggestions? Thanks.
Posted on Jan 16, 2007
    Scholar:
  • 168 Answers
Is this a horizontal black line going up or down? if yes, this sympton is caused by a trouble in the integrated circuit or in the vertical oscillator circuit. this symptons has 2 variations. one is the intermittent rolling of the picture. this referred to as the "loose vertical hold" the other variations is the continuous upward or downward rolling of the picture
Posted on Jan 15, 2007
The screen rolls for a long time then stops after tv been on for a while
If it rolls up or down it is bad caps in the vertical circuit, if it rolls left to right then its bad caps in the Horizontal circuit.
Oct 30, 2013 | Televison & Video
Rolling horizontal black bar 1" tall on the tv screen
this is a problem with heating of some components of the TV inside it.
i would suggest you to look inside the unit and check for components with high heat
Oct 01, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Rolling horizontal (colored) lines instead of picture; audio OK
This problems it pretty easy to fix.Just require take the tv apart.Resolders all the holes in the video board that connected to a long CRT tube neck.Should cost $50 -$75 more than that u are being cheated.
Dec 04, 2009 | Philips Magnavox 20MT4405 20" TV
Flatline!
the vertical drive ic that drives the yoke for vertical sweep has blown.
sometimes it is solder problems like sharp and toshiba had.
the part is 10$ the pc board will label it ,the yoke is the coil setup on the picture tube.if you follow the wiring half goes to the horizontal drive,and the others to the vertical section.the chip drives the coil directly.there are VERY high voltages in there ,even turned off. the pix tube cap on top is 30000v. like a stun gun.the horizontal drive 2000 volts and the main power supply 165 volts dc high current.you need a special setup to discharge the picture tube.
May 15, 2009 | Mitsubishi CK-35308 35" TV
Philips magnavox 32" TS3260C1
Sounds like retrace lines. Leaky caps or worse can cause this.. Are you getting any vertical foldover at the top of the screen?
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
JVC AV-24F702
well i suggest just replace all of them around the vertical output so u dont have to replace just the only one n in the future u have to replace the other one.
Nov 06, 2007 | JVC AV-24F702 24" TV
Hi.JVC AV-32F803/Y Turn on and shot it self off in a few seconds?
Sound like no High Voltage, have you tried the Horizontal output. Also look at caps in power supply for leaky ness.
Sep 21, 2007 | JVC AV-32F803 32" TV
Half of screen rolls
This sounds like a leaky electrolytic capacitor in the unit's video circuitry. You will have to take the unit to a qualified technician for repair, because there are no user serviceable parts inside, & the capacitor in question is about the size of a BB.
Jul 19, 2007 | Durabrand PDV-705 Portable DVD Player
Screen off and sound buzzing
Probably a bad high voltage transformer and horizontal output transistor.
Jan 21, 2007 | GE 35GT720 35" TV
TV Comes On But No Picture
check for bad solder connections on the pc board and a posible leaky cap
Dec 06, 2006 | Philips Magnavox 20MS233S 20" TV
Televison & Video Logo
548 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
