Question about Dishwashers
Grounding a figidaire dishwasher correctly. The model number is MD8122RFSO.
  • 706 Answers
Hello ashlyn010507,
What exactly do you need to know about how your dishwasher is to be grounded? The national electrical code treats has dishwashers wired like any other appliance in that a receptacle ( like on your wall) is placed in the general area of the dishwasher and a power cord is attached to teh dishwasher at junction box internal to that dishwasher.. the cord is typically plugged into a 3-prong outlet which has a ground terminal. Otherwise... that is all that is required... If you are hard-wiring it ( as was done years ago) then a power feed is brought into a junction box internal to teh dishwasher and you would wire the hot , neutral and ground there).. Please restate your question if this information didn't answer you correctly..
Regards,
Rick
Posted on Nov 28, 2008
Reset figidaire dishwasher. Control panel not working.
hi david.
not sure if this link will help you out but have a look.
how to Reset figidaire dishwasher Google Search
Nov 01, 2017 | Dishwashers
Whirlpool du810
There should be a check valve in the drain hose to prevent that.
Is the sink drain clogged?
Link to video showing how to replace the drain hose and check valve. Dishwasher Repair Replacing the Drain Hose and Check Valve Whirlpool...
DU801 is not the complete model number. Find the complete model number. It should be just inside the door on the right side of the tub.
Go to sears parts direct. And enter your model number and find the part number for the drain hose of your dishwasher. The number in the video may be the correct one.
Link to searspartsdirect.
http://www.searspartsdirect.com/
Sep 06, 2014 | Whirlpool Dishwashers
Figidaire FTF630as0 won't agitate. The door locks and water drains but won't agitate or spin
Hello Tina Kaha - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Apr 19, 2013 | Frigidaire ATF6000ES Front Load Washer
THE RINSE AID CAP MELTED WHEN IT FELL ONTO THE HEATING COILS. I NEED A REPLACEMENT JUST NEED TO FIND THE PART NUMBER
If the model number you posted this question under is correct, the part number for a replacement Rinse Aid Cap is 8564929.
You can purchase replacement parts at any of the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If the model number is not correct, please post back with your correct information, or use your model number at the sites I provided, for your search criteria. I hope you find this informaiton helpful.
Feb 16, 2011 | KitchenAid 24 in. KUDI02CR Built-in...
Manual for sears dishwasher item MOD#1440902214409000
I am not sure if you have got the correct model number.
Sears dishwashers are usually of the following makes - Kenmore, Maytag, Kithchen Aid, Whirlpool and the model number would be something like 665.xxxxxx
Can you please change the model number and post a comment.
Nov 20, 2010 | Dishwashers
My model number is FDB1500LFSO, my dishwasher quit...
Is the door open or unlatched?
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.
Is there power to the dishwasher? Electricaly ground dishwasher. Connect ground wire to green ground connector in terminal box. Do not use an extension cord. Failure to follow these instructions can result in death,fire or electric shock.
Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob? (Some Models)
The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
Press and hold the Heated Dry option (button with lock icon) for five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?
To cancel the delay and cycle, press Cancel/Drain.
Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.
Is the Start/Resume indicator flashing?
Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.
On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.
Is the water shutoff valve (if installed) turned on?
Make sure that the water shutoff valve is turned on.
If these tips did not work or your controls are not working correctly you may need to schedule service.
May 17, 2010 | Dishwashers
I have a second dishwasher that i got and have never used i havent got the manual for the dishwasher but when it is turned on it trips all the electicity, the plugs have been checked and there is no...
the ground leakage breakers are determining insulation failure either from water ingress, moisture or the like
get in an accredited electrician to properly check the unit and fix the fault
while you may be using it correctly, the unit is unsafe
Feb 25, 2018 | Brandt S2600WF1 / S2600BF1 / S2600TF1 1550...
I need details on how to install Maytag built in dishwasher
Hello Ted, Without the exact model number, it is difficult to provide the correct installation instructions for your specific Maytag dishwasher.
I can provide you with a link to the Maytag site where you can enter in your model number and download an owners manual and installation instructions/guide that will provide you with the step-by-step needed to properly install your dishwasher.
http://www.maytag.com/support/manuals_literature.jsp
The installation instructions will provide the proper wiring, water supply inlet plumbing and connection of the water discharge line, as well as all of the dimensions needed for clearances for the countertop and cabinets.
If you're trying to install an older dishwasher, you can also give them a call at 1-800-344-1274 and have your complete model number available, so they can provide you the correct manuals and instructions.
I hope you find this Very Helpful and best regards!
Nov 23, 2009 | Dishwashers
I need the insulation cover for the outside, any ideas?
If the model number you have this listed under is correct, a replacement tub insulation can be purchased at pcappliancerepair.com for about $38. The part number is W10223014. If the model number is not correct, or if you have questions, please let me know. I hope this helps you.
Sep 28, 2009 | Maytag MDB3100 Dishwasher
Dishwashers Logo
114 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
