My HDTV keeps turning off and on.
My Samsung 46in. LN46A750R1F HDTV keeps turning off and on and has no picture or sound, but the 'turn-on chime' keeps sounding. All I did was push the power button on the remote. I've already taken the remote out of the room, so I know it is the TV and not the remote with the problem. I put a blueray into the player and then turned the tv on when this started happening. Any help would be amazing.
Took it back to the store.
Posted on Nov 29, 2008
Samsung DLP TV has power but no picture.
There is a capacitor that often fails.. it round and contains a thermal sensor.
May 29, 2015 | Samsung HLT5687SAX 56-Inch Slim LED Engine...
How to fix TV
If you are willing to take a chance...and you have some technical skills you may be able to repair it. I was able to replace 2 capacitors on my power board for under $5. I had no picture, no sound. Not saying that is what is your problem. Search the internet for your model number and no picture. I see several youtubes on yours as well.
Jan 24, 2015 | Samsung LN46C630K1FXZA - 46in Lcd Hdtv...
46in Vizio LCD HDTV distorted black picture when tv is turned on
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
You can get parts at www.interliquidparts.com
Nov 28, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
I have an hlp4663w 46in dlp samsung. The problem is after turning on the set it runs for a few minutes and I loose the picture, but I still have sound. I can turn it off and then back on and the picture...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Aug 01, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
I have a 46in. Samsung LCD TV. It worked lastnight now I tryed to turn it back on and all it does is the power light flashes and it make's a clicking sound can you help thank's very much.
The clicking noise indicates that its a power supply related issue. When the relay switches turn themselves off you will hear that sound. The first thing you should try is to unplug the set and hold for 5 minutes before plugging it back in and turning it on? Why? Because a power surge may have triggered these relays and unplugging them will reset them so that you can see if the set turns on. Otherwise we will proceed accordingly and troubleshoot the components provided you can follow a schematic.
Sai.
Mar 23, 2010 | Samsung 46IN LCD 1200:1 460DX BLACK 8MS...
Toshiba 46in DLP No Picture, but good sound.
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad lamp assembly , search for one online by model# for between $100-$200
easy to install yourself
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Sep 09, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
No picture on my samsung tv
If you have a conventional set, it sounds like you might have cold solder joints around the Horiz Driver Transformer. It's not the large one--the small one.
Jul 16, 2008 | Samsung TSL3293HF 32" TV
Televison & Video Logo
373 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
