Question about Panasonic PT-53WX42 53" Rear Projection Television
Replacing STK Modules in a Panasonic Rear Projection HDTV
I've read the posts on this board from February and March regarding replacing the STK modules in Panasonic rear-projection HDTV's. I have a 7-year old Panasonic and am having the same convergence problems with it that other people seem to have had prior to replacing the STK modules. I found a Sanyo STK392-180 module for about $15 and I'm considering attempting the repair.
Before I order the module(s), I have a few questions about the prior posts:
1. Is there more than one STK392 module in this HDTV that will need to be replaced? The prior posts all talk about getting an STK392-180 rather than a -110, but seem to suggest that there is more than one of these modules which will require replacing. I haven't opened up the back of the set yet and won't do so until I have the parts. How many of these modules do I need to order?
2. Most of the suggestions recommend against ordering generic brands and instead suggest ordering name brands and paying a bit more. The module I've located was made by Sanyo. Is this a quality product?
3. I saw on epost which suggested checking for blown resistors. Is this a visual check or do I need a meter to perform this test?
Thanks for any hints, tips and recommendations.
John A. Franczyk
    New Friend:
  • 21 Answers
Hi there.
If you look up the datasheets for the 392 series, you'd find more differences than power and voltage ratings... Using a similar IC (even if it is the same series) may make it difficult, if not impossible, to converge. It's recommended to change the 2 ICs as a matched pair. Since one already is failing or failed, the other probably isn't too far away.
The resistors mentioned are to bias each output stage for proper deflection and must be within tolerance. They're precision blue flameproofs, so if anything really heated up from a bad IC you'd easily catch any browning / burning. Red is IC7001, blue IC7002, and green is split between the two ICs.
Tha advantage getting a factory supplied or authorized distributor part is you know the LOT NUMBER has been approved by the manufacturer. Generics or unusually cheap originals are often rejects from the manufacturer as being out of tolerance.
The originals are only $29 each directly from Panasonic. Why go through all the effort tearing the thing apart twice to save $30?
Good luck, Mark
Posted on Nov 28, 2008
In replacing the two STK-192-150 chips, I need to remove the board. I am concerned about the 4 white interboard connectors along the left side of the board. Can you just pull up the board?
In my experience it's easier to just pull the chassis out and flip it over. The white connecters can be disconnected by applying sufficient force pulling up, you can also use a screw driver or pen. Place the pen under the connector flat and pull up on either side to apply even force to the entire connector. Goodluck and remember to mark the convergence connectors 1, 2, 3 so they go back where they belong. They are the little white connectors that are identical.
Feb 08, 2011 | Panasonic PT-53WX53 53" Rear Projection...
My color is not perfect. It looks like it is missing the green aspect
This tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows picture or 3D picture look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,require replacing to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 03, 2010 | Panasonic PT-53WX54 53" Rear Projection...
I have a Panasonic Multimedia Projection HDTV when tv is turned on it has red & blue color spots & red verticle lines showing on the screen what could be causing this to be happening
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have shadows colors pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Are the ic's solderd in on a rear projection?
Yes, this is a very common problem for RPTV's.
Please search for stk-392-110 and you will find tons of posts on how to solder/unsolder, replace and where to buy.
Oct 22, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I have a Samsung Model PCN5425R Rear Projection TV. When I try to set the convergence, the red will not move whatever I do, but the blue works fine.
If it is rear projection set it uses either two of the STK-392-020 OR STK-392-040 CHIPS FOR CONVERGENCE OUTPUT.
BOTH WILL HAVE TO BE REPLACED; NOTE THAT THESE SETS ALSO HAVE "PICO" FUSES ON THE BOARD FOR EACH CHIP--no movement means one of the fuses is blown because the chip shorted.
This can be a do it yourself repair if you are handy; total parts cost if the parts purchased on Ebay is under 30 dollars.
Let me know if I can assist you and if you have any questions reply to the posting here.
REGARDS, SD TECH
Aug 10, 2010 | Samsung PCN5425R 54" Rear Projection...
Toshiba 65hdx82 convergence issues
check fuse resistors near STK, and broken PCB around digital convergence board (board in a metal box verticaly mount beside STK.
Apr 23, 2010 | Toshiba 65HDX82 65" Rear Projection...
Had convergence problem; replaced 2 stk392;
100% Ur 2 STK convergence ICS are still dead.Ur ICS soldering some how,u got the ICS shorted.Or ur ICS not right kind of STK ICS,u replacing in ur convergence board.
Apr 07, 2010 | Panasonic PT-56WXF95 56" Rear Projection...
Please, can anyone tell me which STK39x-xxx convergence ic's are used in a Panasonic, rear projection TV, model PT-47WXC43
Your STK numbers are on the ones in your TV Big black ICs STK if they are 110s,120s,150s Use the 180s instead.better ICs For EXample STK392-110 ect.....
Feb 20, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Samsung HLM507W 50 in. STK IC's
STK-392-180s these are the best.Replace BOTH
Feb 01, 2009 | Samsung HLM507W 50" Rear Projection HDTV
Panasonic pt-53tw53 convergence
It looks more like an open solder because you were able to align it properly after replacing the STK ICs, if there was an open resistor(s) you would not be able to get it align.
I would suggest to go back and double check the solder joints on the STK ICs as well add some fresh solder to the resistors nearby the stk392-180.
Good Luck.
Apr 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
99 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
