Question about Water Heaters
Water is either hot or cold - no in between.
I have a Stiebel Eltron DHC 2-10 water heater that I installed in a new house I am building. I have it installed under the kitchen sink and built a little distribution manifold out of PVC that is connected to the hot water line coming from the water heater. There are 3 lines coming off the manifold - 1 for each shower, and 1 for the kitchen sink. One of the showers is on the other side of the wall where the kitchen sink is, so the distance from the hot water heater to the shower faucet and kitchen faucet is about the same.
OK, so that's the setup. My problem is that in the showers, where I have identical Moen 1 handle faucets, the water is either really hot or cold. When I feather the handle back to get the water warm instead of hot, it stays hot until I get to a certain point and then the water turns cold. The faucet in my kitchen sink is a 1 handle faucet as well and it is working perfectly - I get hot, warm, or cold water.
I have taken the cartridges out of the shower faucets and took them apart to check for debris or something that would cause a problem and found nothing. I even switched the cartridges between the two shower faucets to see if that would make a difference and it didn't. I spent a couple of hours trying to adjust the flow control screw on the water heater, as well as adjusting the control valve on the cold water line going into the hot water heater. I turned the valve to restrict water flow into the hot water heater, and adjusted the flow control screw in the hot water heater. I did this while the water was running in the shower and I made every adjustment I thought possible to nothing works.
My thought is that either my shower faucets are faulty which doesn't seem likely, or somehow the holes in the shower control valve for the hot and cold water are so small that when I turn the handle to a certain point it is almost closing off the hot water side and signals the hot water heater that the line is closed, but that's just a guess. Any ideas of what the problem could be?
  • 6 more comments
  • brad936 Nov 29, 2008
    The cold water connections come from the same source for the faucets. I built a cold water manifold that is connected to the incoming water line and I have a line coming off the manifold going to each fixture. I think I may have solved the problem today. After trying to adjust everything, and exchanging the innards of the 2 shower faucets with each other to see if it made a difference (it didn't), I thought maybe the problem is with the sensor in the hot water heater.
    I figured that maybe when I tried to feather the shower control to get a little cold water mixed with the hot so I would have warm water, that when I get to a certain point it is shutting off the hot water line enough so that the sensor in the hot water heater wasn't sensing the demand an shut itself off. So I figured I had to find a way to keep demand in the system so the hot water heater would stay on. I went to the kitchen sink and turned the water on all the way hot. I didn't have the pressure/volume all the way on but had the handle all the way to the hot side and waited until hot water was running in the sink. Then I went to the shower and turned the water on and when it got hot I started feathering the control to the cold side and I started getting warm water. So either I got real lucky or my theory was correct. So now I have to keep the hot water running at another fixture in order to keep demand in the system when I take a shower.
    If I'm right, is there a way to adjust the sensor in the hot water heater so that it will keep running even when the demand is extremely low as it seems to be in the shower?
  • brad936 Nov 30, 2008
    Oilboilerman, thanks for your answer. My water heater is a Stiebel Eltron DHC 2-10 and it is brand new. I had the same model in my old house and used it for four years with no problem. This model is the bottom of the line model so there are no temperature controls or settings. I have adjusted the flow control screw all the way in and then all the back out (in small increments) to see if that would make a difference and it did not. The only time I can get warm water in the shower is by leaving the hot water running in another fixture to create demand in the system.
  • dlpm Feb 23, 2009
    I hve the same problem as brad936
  • gav72 Mar 22, 2009
    I have a moen turn facet in a shower stall on the second floor. I also have a direct hot water system from an older weil mclain.  all of the facets and showers have warm water cold water and hot water when turned in the proper direction. My problem is on this shower in the upstairs bathroom. I turn the water facet to the left thinking it would be warm to hot. But instead it is ice cold. when I turn to the 12 oclock position its off. When I turn to the right it is a constant scalding hot temp.  Not sure what to do. I tried taking the facet apart to see if there were any adjusting screws but found nothing.  Any suggestions?   I am currently in the process of piping a Buderus boiler and indirect tank to replace the old Weil Mclain but dont know how to resolve the water issue in the one shower stall. Need help Please!!!
  • larry rosen May 11, 2010
    where r the cold feeds to your showers coming from?
    are they coming from a storage tank or from the same source as the faucets?
  • Anonymous Mar 13, 2014
    need to open the hot water flow 1995
    sea breeze
    No hot water when taking a shower
  • Anonymous Mar 24, 2014
    All water in house is either too hot or cold not in between. Kitchen sink does not give hot water
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Posted on Nov 29, 2008
I have the same problem in with my shower faucet. My solution is to use a bucket. First fill half ice cold water and then remaining half with scalding hot water. This gives warm water. You can use a mug to finish your shower (I don't know what else you call it). This also saves water.
Posted on Nov 07, 2012
    Problem Solver:
  • 17 Answers
This indicates that perhaps the temperater is as you thought flow regulated. the more the flow the lower the temperature.
this could also indicate a lack of linear controll in the heater unit (i wonder how old it is) if the unit has two heat settings ie high and normal/low try setting it to a lower input wattage.
here in uk we normally have 2 settings 4 kw and then watever the maximum is
if you wish give me the exact model no and age etc. and i will contact manufacturer on your behalf and ascertain problem
Posted on Nov 30, 2008
  • larry rosen Nov 30, 2008
    k you can get new items defective lol i will contact them on your behalf and check with tecnical
5 Suggested Answers
  • 234 Answers
SOURCE: Sensor broken - E 71 - Stiebel Eltron WPF water-water heat pump.
I would check the connect first may sure it is not loose.
Posted on Mar 14, 2009
SOURCE: my water heater water not warm enough
You may need new heating elements or you could have a thermostat bad as well.
Posted on May 11, 2009
  • 7 Answers
SOURCE: Where do I find the reset button on the Stiebel
On the Tempra 29 there is a "safety thermal cut-out" on the top of each of the heating elements within the box. I have had to open it up before to push the breaker. They are a small red plastic push button on the top. Carefully press the braker button without touching the electrical wiring inside. I hope that works for you.
Posted on Jan 03, 2010
SOURCE: The water heater "Stiebel Eltron
I am a free answerer, and I specialize in giving you resources for free
The paid answerers may have a person who knows your product and the problems associated with your model.
I believe they offer a refund if the 'fix' doesn't work.
The manual might also have troubleshooting.
Each day I see 20-25 unanswered questions about tankless water heaters.
And the day before, there were same number of unanswered questions about tankless products.
The number of questions shows the complexity of the machines, the brand-specific-ness of the problems, and the inability of the manufactures to take care of their customers.
If I understand correctly, the manufacturer will refer you to the installer.
There are not many ways a do-it-yourself-er can fix a tankless.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Posted on Oct 31, 2010
Tonight I noticed a blue light flashing on the top of my Stiebel Eltron tankless water heater. What does that mean?
Go to the website and find the manual from your heater. In the Troubleshooting section, it tells you what the sequence of the three lights is. This is a similar model.
operation and installation - Stiebel Eltron
https://www.stiebel.com.au/products/downloads/7water supply"). Cold water flows briefly while hot water is being drawn. The air sensor detects air in the water and the ap- pliance's heating output is ..... The flow sensor (DFE) is faulty. Check the flow sensor and replace if required. Flashing green light and steady yellow light. No hot water at flow rate. > 3 l/min. The high limit ...
Downloads Stiebel Eltron
Apr 28, 2018 | Stiebel Eltron Water Heaters
Stiebel Eltron 221094
Stiebel eltron model 221094 hot water is not as hot as it was before,
only warm water coming through. Do I need to replace unit?
Oct 05, 2013 | Stiebel Eltron DHC 10-2 Electric Tankless...
Eletric water heater not heating up to 125
Include product brand, model and type for best possible answer.
Include if this is new installation, or installation that worked before and stopped working.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 03, 2012 | Stiebel Eltron Stiebel TEMPRA24PLUS Eltron...
Not hot water
click the site then go to costumer service,they might help you.. http://www.pexsupply.com
Mar 26, 2011 | Stiebel Eltron DHC 8-2 Electric Tankless...
No hot water!! For some reason it is not heating the water!?
is the heating element still good. Was it on when no water was running thru it?
Jan 25, 2011 | Stiebel Eltron DHC-E 10 Electric Tankless...
Hi, I just got my new DHC 10-2 today, the installation was easy but I have a problem. The problem is that heating is not constant. Once I mix the cold and hot water I should have an uniform temperature but...
This electric demand water heaters has one heater element. The flow switch turns it on. The thermostat cycles it on and off according to temperature. There is no medium.
You need to run the sink on hot while you take a shower. This kind of cancels out the savings on electricity.
Or get a higher flow shower head. Your screen on the shower head may be partially fouled.
Here is the brochure. It shows the flow rates for the different models.
http://www.stiebel-eltron-usa.com/sites/default/files/pdf/brochure-dhc.pdf
Dec 14, 2017 | Stiebel Eltron DHC 10-2 Electric Tankless...
Oct 30, 2010 | Stiebel Eltron DHC 10-2
Tank rattles when hot water drawn out of any tap in the house.
sounds like water hammer 1/cold inlet pressure to high2/ loose pipes 3/ silicone washer check ballvalve washerand replace or cold water tap washers best of luck
Sep 26, 2009 | Stiebel Eltron Tempra 24 Electric Hot...
Water Heaters Logo
2,939 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
