Question about Crosley CAWC529JQ Top Load Washer
Spin Cycle/Machine makes noise and moves
I have Crosley top load washer. It washes fine, but when it gets to the spin cycle it spins but i think the tub isnt hooked on tight anymore and the faster it spins the more noise the machine makes and moves. I want to know how do i tighten up the tub to make it stop moving around and making the noise?
  • 2 more comments
  • Anonymous Mar 13, 2014
    took clothes out--- still very wet. The tub can be moved around & there is a gap between top of outside rim & tub
  • Anonymous Mar 18, 2014
    Makes clicking noise
  • Anonymous Mar 26, 2014
    Terrible noise when spinning
  • Anonymous Mar 31, 2014
    spin cycle makes noise
  • 641 Answers
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Posted on Jul 26, 2007
What causes my frigidaire top load washer to vibrate and make rattling noise during spin cycle
There are springs and bumpers/shocks in the machine that hold the tub. When they break or come loose, the tub wobbles.
Jan 03, 2016 | Frigidaire FAHE4044MW Affinity High...
Hi my washer moter works but spin cycle is not working Every thing else is O. K Thanks
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 29, 2011 | Crosley CAWC529JQ Top Load Washer
Washer will not spin in wash cycle
I have a Kenmore washer that will not spin or drain.
May 31, 2010 | GE WBSR3140DW Top Load Washer
Crosley CW6000 Washing Machine. When my washing machine is in the spin cycle, it shakes severely and the machine on the floor
My Crosley Cw6000 wash will not spin the water out, I lift the lid to watch the spin cycle, it spins but the water does not drain..
Sep 02, 2009 | Crosley CW6000 Front Load Washer
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
Kenmore 110 Heavy Duty 70 Series Washing Machine won't spin
Can you move the basket by hand...if so you need a basket drive. If not you have a bad clutch or gear case
Jun 07, 2017 | Kenmore 24032\24036 Top Load Washer
Clicking Noise
You have a broken drive coupling. This video will show how to cahnge it.
Mar 27, 2009 | Whirlpool Ultimate Care II GSQ9669L Top...
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Crosley CAWC529JQ1 top load washer sounds like a cement mixer!
sounds lik the main bearings are faulty and needs a strip down to replace parts otherwise another machine may be in order
Nov 21, 2007 | Crosley CAWC529JQ Top Load Washer
Crosley CAWC529JQ Top Load Washer Logo
526 people viewed this question
Top Crosley Washing Machines Experts
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
