Question about Kyocera Mita FS-1020D Laser Printer
Printer not responding after a jam
I had a jam last week and now printer will not respond to anything. 3 out of the 4 indicator lights are flashing (all except the last one)I have removed all inner pieces cleaned the machine out and still no response? I have even tried to put in a new toner cartridge to see If I could get it to load new toner and nothing?
  • Anonymous Feb 26, 2009
    we had a paper jam, cleared it. now the first and third lights continuously flash and there is no response when we try to print.
  • 3 Answers
When You have 3 lights blinking: lights 1- 3 (counting 1-power 4-waste toner indicator)
light 4 stays off all the time its
Communication error (F040 error)
Contact your Kyocera Mita dealer
You coud try to check all connectors attached to printers motherboard and see if it would help
as for 1,3 blinking solution
There is no paper in the MP tray.
Add paper to the tray. Press the key to resume
printing.
Feeding the paper having a paper size
which does not match the current paper
size from the MP tray can cause paper jam.
In other words just put Your paper cassete correctly in (there are known problems with the paper casete sensor not always detecting it correctly. You might also try to stick something - small sticky note fragment- onto the microswich to make it react somewhat earlier)
Posted on Jul 24, 2009
    Novelist:
    Champion:
  • 202 Answers
Http://files.oce.com/nl/download/printers/PP20D%20Operation%20Guide%20(Engelstalig).pdf Here is the link to the pdf manual for the printer. They show some light sequences and mention something about the old toner cartridge may need to be emptied/replaced. I'll let you know if I think of anything else. Tim
Posted on Jan 30, 2007
How to clear paper jam in Epson Workforce 520
If your printer is indicating a paper jam and it's not jammed, turn it Botton might not respond so off, if necessary, disconect phisically.
If still unresponsive, remove USB cable. Turn off, reconnect.
Last resouce, remove in cartridges and inster one by one; if you have some unused, test.
If sill indicates paper jam, it's defective, take to repair service.
Aug 22, 2015 | Epson Office Equipment & Supplies
Red lights flashing
check you have nothing jamming the printer spool, i fixed one of these last week only to find that the person kept it on the floor and had dropped peanuts inside, once cleared obstructions printer working fine
Aug 19, 2009 | Epson Stylus C84 InkJet Printer
Mp160 flashing error E then 3
E3 - paper jam!
check paper
chek sensors
Jun 19, 2009 | Canon PIXMA MP160 All-In-One Printer
MP 160 flashing error E then 3. doesn;t respond to anything I try to reset it
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
mbhd13
Jun 19, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I cant print
i need software for my hp deskjet 3745 printer
Oct 21, 2008 | HP DeskJet 3745 Printer
Printer Not Responding, 7 orange flashes
Don't replace the print head soooo fast...
Take the print head out first and clean the gold contacts...
I used a very fine sandpaper like emery cloth...
You might get 4 yellow blinks after that.
That is because the printhead was turned upside down to clean and the ink looked low and/or out.
Just wait a few minutes after cleaning and reset...
Mine worked fine after that.... smile....
Aug 09, 2008 | Canon S900 InkJet Printer
Problems with printing
Make sure all cables are properly connected and not damaged. Try connecting it to a different port on your computer to make sure the port isn't at fault.
I suppose lights seem to be n"normal" on it? No flashing lights that may indicate problems or anything like that?
Nov 07, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon s520
The number of orange flashes between green flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action. Two flashes: Out of paper, paper jam or paper feed error Replace the paper correctly and press the RESUME/CANCEL button. If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL button. Three flashes: Paper jam If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button. Four flashes: Empty ink tank One of the ink tanks is empty. Replace it. If all of the above won't help, unplug the printer from the power cable, wait a while, and plug in. If that didn't fix you, I guess it's time to get in touch with canon, or a repair lab you trust. Good luck
May 16, 2006 | Canon S520 InkJet Photo Printer
Printer doesn't respond
The Power light can flash for several reasons: - The printer cover is open. - The printer is out of paper. - There is a problem with the printer, such as a paper jam or a problem with a print cartridge. if no error message appears any where: 1. Go to maintenance . 2. Click any of the four main buttons. This will tell the software to check the status of the printer. 3. Read any error messages explaining the problem and its solution. good luck!
Oct 31, 2005 | HP DeskJet 3550 InkJet Printer
Kyocera Mita FS-1020D Laser Printer Logo
488 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
