Question about Crosley Audio Players & Recorders
45's won't play through
I just purchased a Crosley CR245 and the 45 records won't play all the way through. The needle automatically picks up before the record finishes playing. I called the Radio Shack where I purchased it and they say there could be an adjustment that needs to be made, but don't know how or where. Of course, I can't get away from the Crosley phone number in the manual. Any help???
  • MooT BooXLe Dec 27, 2008
    Man! I'm having the same problem! I bought mine from a place that's going out of business, so I figured there'd be no returns, and I'm an audio engineer with some electrical know-how - I took it apart (voids the warranty I suppose but oh well...), for a few reasons.
    One, I want to see if there is a trim pot coming from the phono preamp, so I could adjust the level it outputs to the CD recorder. When I open up audio in my mastering software that I have created by recording CDs from vinyl on this Crosley machine, the level is way too hot - it clips quite often. Not good. Analog clipping: no big deal. Digital clipping: very, very bad. By clipping I mean the meter going "into the red", or past 0dB full scale.
    The other thing I wanted to see if I could fix is disabling the automatic return on the tone arm. That's annoying! Good turntables that I grew up with (and probably you did too) didn't do this - the needle just got caught in that run-out groove loop at the end over and over and over and over until you finally got up and manually put the tone arm back in its resting place, and turned over the record.
    That's the way I want this one to work! I SHOULD DECIDE when the record's over, Mr. Crosley, the impatient DJ! Not you!
    If I do figure out a simple way to fix this problem, I'll let ya know!
    How's that?
    Cheers,
    Matt Baxley
    Naples, FL
I FIGURED IT OUT! Here's how to fix the problem. 1. Remove the c clamp that holds your turntable in the box. Do this slowly so you don't over stretch or break your belt. 2. There are 3 screws holding the entire record player mechanism in the box. Take those out. 3. Look just under where the arm (the thing that holds the needle stylus) attaches to the mechanism. See that long wire rod that runs from that spot to just about the center of the turntable? It's being held at the arm by a little plastic piece that has a screw. The screw needs to be tightened. Once you tighten the screw, that will make is so that the arm has to be moved less to the right to start the record, and more to the left to turn it off. This makes it possible for you to hear the end of your songs! 4. Screw the mechanism back in the box (not too tight, you want those shock mounts to work). 5. To get the belt back on the wheel, first look under the wheel. See the big circle that is about half the size of the wheel? Place the belt around that. 6. Now look further out on the wheel. Do you see a plastic peg (actually 2 pegs....they are across from each other on the wheel)? Stretch the belt to one of the pegs. 7. Place the wheel back on the mechanism with the stretched part over the motor. Now spin the wheel slowly until the belt falls onto the motor. 8. Reattach the c clamp on the wheel and you're all set. Oh, I forgot to mention that you should put a record on and make sure you adjusted that screw under the arm enough. I had to do mine a couple of times. Hope this is helpful! Here's a video I found that better explains how to get the belt back on. http://www.youtube.com/watch?v=QaW84Z6GMVs
Posted on Dec 29, 2010
Crosley troubadour stops before record is done
Check to see if there is a switch setting for 7", 10", and 12" records. Sounds like a switch setting to me. Does it always pick up at the same physical location on any record? If so, that is the likely cause. Personally, if you have an extensive collection of vinyl, a Crosley is definitely NOT the best turntable to be playing them on. You'd get way better fidelity and save your records from physical groove damage by investing in a better turntable. If you want the collection to stay in good shape and retain their value, ditch the Crosley ASAP.
Dec 03, 2017 | Crosley Audio Players & Recorders
My crosley keepsake turntable has been having a lot of static and the sound is very low, I can only hear it if I turn the volume all the way up. I'm not sure if the needle is the problem or there is s
I would check the wires to the cartridge. It might that one or more is off or loose.
If you turn down the volume completely and listen with a record playing you should be able to hear (with your ear) the stylus in the grooves of the record playing the track. Pick a loud (rock) record for this. If it does that OK the stylus is good.
Dec 26, 2014 | Crosley Keepsake USB Turntable
Record player repair
The top arm that swings over the spindle will control the automatic return. Leave the unit off. Swing the overhead holding top arm over and manually load a record. Now switch the top arm over the niddle spindle. Make sure that the switch is set for 7", 10" or 12" (45, 78, or 33). Manually place the tonearm at the start of the record and flip switch to 'play' (not reject or auto). It should play the whole record and automatically eject at the end and then shut off. Leave the arm swung over the middle after you loaded the record. Good luck. Let me know if you have any more questions.
Aug 18, 2014 | Audio Players & Recorders
I got a crosley recently and it has been working great up until now. Whenever I play a song on the record everything works great it is just the sound. its horrible. I think it has something to do with the...
The Needle may need replacing, if after replacing the needle and you have the same problem, it could be a connection from the needle pick up to the recever.
Feb 09, 2014 | Crosley CR249TA Turntable
Record skipping despite new needle
It could be something to do with the turnatable's platter. Is the matt that the record sits on faulty. Does the platter wobble up and down with no record on it? If you can see this happening you might need to check the platter out. If it's a belt driven the belt can come out of position causing such problems. Also objects can get stuck inside the platter. Especially if you have small children in the house!!!
Feb 28, 2013 | Crosley Cr704 Audio Shelf System
One side of my vinyl record will play fine but the other side won't spin right and the needle gets stuck on the record
The only thing you can do is clean the record with cleaning fluid. You will find special cleaning fluids for records on Amazon. If the record is warped you can try a weight pressing down on the record. But sadly if a record is warped bad there's no real cure.
Dec 28, 2012 | Crosley 0187SST Turntable
Wurlitzer lyric wont play after selection
my lyric selects the record and plays but wont reste at the end the needle just stays there and it keeps spinning??
thanks craig
Apr 16, 2012 | Audio Players & Recorders
Need the manuel original lost or misplaced and can not find. want to record cassettes to cd's
Insert a blank CD-R or CD-RW into the unit. Press the Function button on the remote (key above Vol+ on the bottom right of the remote) or the turntable itself (top left of the control panel) until the unit is in Phono mode. Then insert the pre-recorded cassette and press Play to advance the tape to where you wish to start recording. With the cassette playing, press the CD Record button (recording will flash on the display). The CD Record button is to the left of the fast reverse button on the unit; it is labeled Record on the remote and is below the Stop button. When one side of the cassette finishes playing, press Stop. Wait for the display to return to Phono. Then eject and turn over the cassette to play side 2 (if you want to record both sides of the tape). Press Play again to advance the tape and then press Record. When this side finishes, press Stop and then Finalize. Finalize is at the bottom left of the remote buttons and to the left of the stand by indicator on the turntable.
The manual is available at Crosley: http://www.crosleyradio.com/Product.aspx?pid=1790 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR248_Manual.pdf . Recording a cassette to CD is on page 11 (page 12 of the pdf).
I hope this helps.
Jun 10, 2011 | Crosley CR248 Turntable
Cr79 tone arm stops too early
I have a 1956 stereophonic Motorola record player, and it turns off right when I press "on" I noticed that the record speed was 33 1/3 I used 33. Does this make a difference??
/uploads/images/cr79-tone-arm-stops-early-34896944-4-1.jpg
May 09, 2010 | Crosley 0187SST Turntable
I have an older 78 record, and the arm automatically returns before the recorded track is finished playing. Anyway I can bypass the auto return?
There should be some kind of screw on the arm to adjust it. You might have to experiment, or get a service manual. When adjusting, try doing it without the platter powered, by hand movement only.
Nov 27, 2009 | Crosley CR248 Turntable
1,095 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
